Samsung-LE32B530P7W-Intermittant Back Light
  • selldoor
    Slow Learner
    • 7870
    Re: Samsung-LE32B530P7W-Intermittant Back Light
    No I dont think there are - makes sense now see attached internet picture of
    this board.
    EDIT just as an afterthought there is a white fuse on the Tcon have you tested it.
    cant see it affecting the BL problem but see a fuse and test it is what I think.
    • AlbertRoss
      • Jul 2012
      • 181
      • United Kingdom
      The 8 flat tabs on the PSU slot into the 8 square holes on the long black vertical connector.
      • AlbertRoss
        • Jul 2012
        • 181
        • United Kingdom
        You beat me to it!
        I tried lifting the black connector but, only comes up a small amount because the tubes are holding on to it from inside the panel.
        • selldoor
          Slow Learner
          • 7870
          Yes - I see that now thanks - please see late edit post 21 re tcon fuse
          • AlbertRoss
            • Jul 2012
            • 181
            • United Kingdom
            I'll check that fuse shortly.
            Not sure how well you can see the photo but, the PSU has now parted company with the backlight connector. I've inserted 8 spade connectors into the black vertical connector which hold the tubes. On each one of these connectors I have a wire link which enables me to join the PSU to the black connector in any combination. So far I've tried all kinds of combinations but the backlight has always turned off after a few seconds.
            The weird thing with this TV is, it can work for days and then all of a sudden, the backlights fail?
            • selldoor
              Slow Learner
              • 7870
              #26
              I like it! What we are trying to do is to get one lamp to light/flash at a time
              ( It is often difficult to tell if there is a fault when they all flash on at once )so using your wires can you light each bulb in turn. I am not sure if there are going to be 8 bulbs or 4 "U" bulbs. If you can do that, as I said before try and observe the "colour " of the flash - pinkish suggests a bulb is failing.
              As you say I know it doesnt really seem necessary as the set is know to work then stop, but it is a matter of eliminating as many known reasons for 2 seconds to black as possible and these are normally the easy tests!!
              I dont recall, and it is easier for me just to ask than skim back through but have you read this guide by retiredcaps - it will help if it comes down to component testing - start at post 19 - its not as long as it looks.
              https://www.badcaps.net/forum/showthread.php?t=10419
              • AlbertRoss
                • Jul 2012
                • 181
                • United Kingdom
                #27
                The more times I turn on this TV, the backlights will fail to come and I have to leave it for some considerable time to re-test. I may leave it overnight and try again in the morning.
                Had a quick look at retiredcaps guide, lot of reading to catch up with.
                Thanks,
                Later.
                  Cold solder joint? Retouch all joints on the board that look suspect.
                  • AlbertRoss
                    • Jul 2012
                    • 181
                    • United Kingdom
                    #29
                    Will do!
                    • selldoor
                      Slow Learner
                      • 7870
                      #30
                      That is an important observation - possible sign of cold joint as Tom says.
                      Tomorrow perhaps try the hairdryer and or freeze spray/compressed air test.
                      • AlbertRoss
                        • Jul 2012
                        • 181
                        • United Kingdom
                        #31
                        Checked the board for cold solder joints, tried the hairdryer trick, don't have an freeze spray or compressed air.
                        What kind of coil readings would I expect to find on T1801S? The number on it is QGAH02092 SW
                        SW-02B 09 OSC.
                        I have 002.2R across the two upper pins which I believe to be the secondary windings (correct me if I'm wrong) and 000.9R on the two lower pins.
                          Retouch all joints on power components. Anywhere that looks like it gets hot or gets hot when running (test with TV off of course!)
                          • selldoor
                            Slow Learner
                            • 7870
                            #33
                            Cant find any info on that transformer tho you can buy one in Oz for 4$ish- perhaps
                            test the voltage on the primary side but have meter on 600v or higher if you have it.
                            Perhaps see if you can follow where that pin 23 invonoff goes to? - on both boards.
                            Could of course still be a duff cap somewhere -they look to be mainly Sam Young?
                            @Tom66 If the lower voltages "wobbled" might it be enough to switch on a protection
                            that closed the lamps down
                            • AlbertRoss
                              • Jul 2012
                              • 181
                              • United Kingdom
                              #34
                              I'm not to sure if it is the transformer! There is a Programmable Shunt Regulator - KA431AZ (ICP802) next to the transformer (TI801S). At first glance I thought is was a transistor of some kind so I started to probe it with my DVOM set on AC. When I touched the first pin on the left, the backlights turned on and my DVOM read 127.6VAC. Removed the red probe and the backlights stayed on for around 15s. Tried various times and same thing happens every time. I now have the wiring diagram and trying to figure out how the backlights come on using my DVOM?
                                Nothing touching other lead? Maybe cold joint under this IC and pressing it fixes it temporarily.
                                • AlbertRoss
                                  • Jul 2012
                                  • 181
                                  • United Kingdom
                                  #36
                                  After spending more time in trying to solve this backlight issue without sucess, I decided to take a chance and purchase another PSU from LCD TV Parts at a cost of £25.00 (free shipping) Since replacing the PSU on Friday morning, the TV has been working 100%
                                  It would have been nice to have found the fault on the PSU then just replace it. Just seems I've not gained any experience in just changing a PSU.
                                  Thanks again everyone for your help.
                                  • MOSSEP
                                    Monitor Audio RSW12 - Green light, but no sound
                                    by MOSSEP
                                    Hi
                                    Im hoping someone might be able to give me some idea of what may be wrong with my Monitor Audio RSW12 Sub.
                                    Ive owned it since new in around 2002, so would really like to keep it running if I can, it was the first ‘decent' bit of audio equipment I ever purchased and is a little sentimental.
                                    The issue I had was that it would power up with the red light, but sometimes the green light would not come on and I would get no bass from it. If the green light did come on though, I would get sound out of it.
                                    I have already tried replacing all of the...
                                    01-26-2025, 08:33 AM
                                  • dronerat
                                    Samsung UE48JU6400W - back light on, sound on, sometimes picture.
                                    by dronerat
                                    Hi Guys,
                                    This forum has been in great help to me, but I stumbled upon a strange problem with a salvaged Samsung TV that I am banging my head to troubleshoot.
                                    PSU: L48S6 FHS BN44-00807D
                                    T-Con: BN95-01937A
                                    Panel: CY-GJ048HGLVLH
                                    MB: NA (Currently as the TV is assembled and forgot to take picture)
                                    As I said earlier I have some issues with the TV I got from a friend of mine. The TV had no picture, but sound, back light and everything else was working fine.
                                    It was sent to an authorized service for repairs and returned with the...
                                    05-15-2020, 08:03 AM
                                  • rp93
                                    2018 Mac Mini A1993 LogicBoard 639-06830 No boot,Blank display,Fan blasts briefly
                                    by rp93
                                    I am trying to troubleshoot my 2018 Mac Mini. It all of a sudden would not respond/wake up. So i turned it off and turned it back on. When I power it up, the fan blasts hard for a second, then shuts off, power light may go off, then back on, sometimes blasting the fan again. It does this a few times then eventually(sometimes) the power light stays on and the fan runs at a normal speed, but with no HDMI/display. Nothing ever shows up on the display.(no sound, no chime, checked wifi router to see if it trys to connect, which it does not)
                                    I have the Mac Mini completely disassembled...
                                    12-04-2023, 06:51 PM
                                  • koby058
                                    vostro comes up with back light but no picture
                                    by koby058
                                    Hi people!!
                                    The owner said it showed bad picture once in a while (attached)
                                    I see that there is back light but no picture.
                                    I want to ask if it is possible to disable the NVIDIA GPU and use the intel one?
                                    Also attached schematic and BDV
                                    LINK to schematic & boardview - https://www.badcaps.net/forum/troubl...ll-vostro-5590...
                                    07-13-2025, 01:03 PM
                                  • kca
                                    Samsung UN60F8000BFXZA ~ No Picture or Sound - 5 Res Light Blinks
                                    by kca
                                    Hello all ~
                                    I’m working on this Samsung 60” LED and purchased a new main board a couple of days ago that did not fix the 5 blink issue. The original main board’s HDMI ports (all 4 of them) failed to work and no amount of reflow remedied that.
                                    This 5 red light blink code on the front panel LED is followed (about 15-20 seconds afterward) by an automatic reboot, and results in 5 more red light blinks. Then the entire cycle repeats itself indefinitely.
                                    No picture. No sound.
                                    I tested all the voltages coming out of the power supply...
                                    10-12-2023, 05:23 PM
