I retrieved a LC32EM1F from the dump and found that it draws current as I slowly bring up the AC using an isolated xformer. At about 40 VAC, the current rises to 2A. Power transformer has an audible buzz so started looking there after disconnecting the inverter board and the main board. Made sure that the FET attached to the primary transformer was good and then looked at each winding on the primary transformer. The primary side is good (~2 Ohms), but the secondary side looks like they are all shorted together. Other thing I noticed is that when I disconnect the main board, the current drops. The transformer part number is ltt2pc0xb043, but I could not find specifications for it. Anyone help with this one?
Funai LC32EM1F - blowing fuses
Re: Funai LC32EM1F - blowing fuses
This type of power supply is a self-resonating design so its current limiting is done via the main fuse! Very bad design in my opinion, hard to get cheaper than this. I would remove the fuse and briefly put a 100W bulb across it, then see if it stays lit. Check for shorted surge protection too. The secondary of a switching transformer will always read shorted.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search. -
Dis connect the Red/Black wires to the inverter board. Discharge that big cap first and then check the resistance reading between the +/- cap terminal to see if it shows really low resistance, the resistance should be rising as the cap is charging up by the meter. All those diodes in the secondary side are good? This looks the saem as SANYO TV (same company owns SANYO, EMERSON) I have seen in the forum before.
What resistance do you get measure between black and white power cable attached to the board?Last edited by budm; 08-16-2012, 03:27 PM.Never stop learning
With the inverter wires disconnected, I got about 20 ohms across the large filtering cap after discharging. The resistance was steady, without increase. When I measure the resistance across the AC plug, I get a very high value (500k ohm).Comment
Tha20 Ohms indicated you have short circuits. Are you sure that the MOSFET and the rectifiers are good? try removing the MOSFET, lift one leg of each rectifer one at a time, etc. Closed up pictures of the primary side of both sides of the board?Never stop learning
Replaced the FET with (K3563) with 65E6600 just to make sure. Still high current. I have not soldered the secondar side of the transformer back down yet either. Unsoldered each of the diodes on the primary side as well the the 10 or so closest to the transformer. All appear to be good. I also checked the glass/switching diodes nearest the FET. One (D612) looks shorted when soldered in, but turned out good when desoldered. Pictures below.Attached Filesif you find these attachements useful please consider making a small donation to the site
Back at it again. I disconnected the peripheral boards and then desoldered the secondary pins on the primary xformer. Current immediately rises as I turn up the AC on isolated xformer. The transformer buzzes pretty loudly and the heatsink for the FET gets hot instantly. Measured across all the zener diodes and though I had found a shorted one (D612), but was not the case. Unsoldered one side and still high current. Suggestions on what to check next?Attached Filesif you find these attachements useful please consider making a small donation to the site
That means the MOSFET is not swithcung on/off at high frequency like it should, so it can be that the Gate is getting steady voltage to turn it on instead of the pulses. I would suspect the IC next. When MOSEFT goes out, it will usually damaged the IC Gate drive circuit inside the IC also.Never stop learning
There is no IC in this design bud -- it's a self-oscillating converter using one NPN transistor and the MOSFET. It oscillates around the properties of the transformer. A rather ingenious design, I must admit, but a very bad one for several reasons. It tends to be unstable; it can go out of control and make the output voltage shoot too high. It's a pain in the *@#! to debug.
In general, I'd say the only way the MOSFET could fail by getting hot would be:
1.) it's shorted but high ohms short (a couple kohm would do it)
2.) it's got a drain-gate short
But the circuit has many other ways it can fail:
1.) if R5 goes too high in value (it dissipates about 1/4W) the MOSFET will not be efficiently switched and voltage will not rise high enough
2.) if Q1 goes open, the circuit will not oscillate (gate will remain at 18V, which wouldn't be good!)
3.) if R7 goes open or high in value (it dissipates about 1/2W) the circuit will not regulate the output voltage (it will go high)
4.) if R3 fails by reducing resistance (rare), current limit characteristics will change
5.) if C3 fails, output will go out of control (2-3x rated voltage)
6.) any bad caps on output will cause the circuit to be unstable
7.) snubber failure (as with any flyback)
8.) ... probably other ways it can fail too, just some I can think of
On these Funai TVs and similar TVs, they also use the self-oscillating circuit for generating the ~135W backlight supply, only slightly modified. I wish I was kidding.
Short circuiting the output of a self-oscillating converter will normally kill it, the MOSFET fails short.Attached Filesif you find these attachements useful please consider making a small donation to the site
Last edited by tom66; 10-25-2012, 01:12 PM.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
Thanks TOM, I just look at the bottom side of the board and see two transistors and an Opto connections.Never stop learning
Is Q602 the small NPN transistor?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
This is possibly a drain-gate short. Test the FET out of circuit.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
by Sik_6ty_SixxSo like the title says, I have an old Stereo Receiver/Amplifier that I picked up from the goodwill, it's a HH Scott Model A510. When I first got it home it had zero output. Opened it up, notice the fuses are missing. Pop in 2 new fuses (AGC4A 250V) and try again, within 5 seconds the L channel fuse POP! I don't see any visible indications of damage or arc burns on the PCB, no popped resistors or diodes, no burnt traces or blown out caps. So I decide to just try another new fuse, POP. Swapped around my R and L speaker wires, and checked the integrity of all wires and connections. Everything looks...5 Photos
TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...-
Channel: Common Parts Library - Datasheets
10-07-2024, 06:07 AM -
by sam_sam_samI was working on this machine yesterday and I now going to use an incandescent lights instead of a fuses to figure out what the issue is with it blowing control voltage rail but this not the only issue the coolant pump failed the meager test as well as the main motor as well this motor has 12 motor wire leads instead of the normal 9 wires
This metal lathe has a weird motor setup it has a soft start motor with a “Y” and a delta type of motor winding setup and it is not done in the motor pucker head enclosure it is with four different contactors wired in a configuration I have not... -
by mon2Hi. New to this side of the forum.
Have an audio amp (Gemsound PXA-105) that keeps blowing the 3A fuses upon power up. Owner stated that the amp was on when he plugged in the input (mixer board) and that started this chaos.
Would a schematic be available? Advice on what to check? Power supply / output amp transistors? Do see the power on green led turn on for a brief moment before the fuse blows.
Thanks.
10-30-2024, 08:33 AM -
by sam_sam_samAbout a month ago we had a transformer jumper wire that burned in two different places between two transformers caused over $200 thousand dollars worth of damage to VFD drives at least 10 of them and a memory card and quite a few power supply as well
Now we have most of the equipment that got damaged back up and running except a feeder that has issues and we are waiting for some parts for
Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the “E” stops and one switching power (24 volt) supply and a transformer... - Loading...
