Sony KDL 52W3000
  • shorteddiode
    • 221
    Sony KDL 52W3000
    The standby light flashes 5 times when the TV is pluged in, and will continue to give the 5 flashes. Pushing the power button the green light comes on for about one minute then the set turns off , I have no sound and no picture or backlights. I checked the voltages and they all are correct except goint to the tcon board. I am supposed to be getting 12 volts to the tcon and when checked with the DVMM it bounced between 4 volts and .3 volts. The tcon connects to the FB1 board. The FB1 board is getting the proper 12 volt input voltage. My question is, The sercive manual says 5 flashes is either a bad tcon or bad screen. If I am not getting the needed 12 volts to the tcon wouldn't I be safe in thainking it is the FB1 board? I think the FB1 is also called the logic board. Every board except the tcon has the proper input voltage. I can provide a link to the service info if needed.
    Thanks Everyone
    Re: Sony KDL 52W3000
    Possibly a shorted T-con - can you check if it gets good 12V with T-con unplugged.
    • shorteddiode
      • 221
      Should have mentioned, I unpluged the tcon from the FB1 board and I am not getting the 12 volts foe the tcon from the FB1 (logig) board. That's why I felt the logic board was at fault.
        That would make sense. Does it still only rise to 4V. It may be repairable - do you have schematics of the main board?
        • shorteddiode
          • 221
          Yes go up to 4 volts then drops, then back up to 4 volts then drops. Continues to do that until the TV shuts down. Yes on the schematic
            Can you attach the schematic?
            • shorteddiode
              • 221
              Here ishttp://elektrotanya.com/sony_kdl-52w3000_fix2-
              chassis.pdf/download.html the link for the service info
              • shorteddiode
                • 221
                Well I replaced the FB1 board and now it's up and running, and 12 volts to the tcon.
                  Great. Though sometimes with Sony it seems a board swap is the only way forward.
                  • Hakuu
                    by Hakuu
                    Hi There,
                    More Details
                    TV Model - LG OLED77G1PUA
                    07-12-2023, 02:37 PM
                  • advant
                    by advant
                    02-03-2020, 12:25 AM
                  • m1ch43lzm
                    by m1ch43lzm
                    05-12-2025, 08:37 PM
                  • howardc64
                    by howardc64
                    07-24-2025, 05:17 PM
                  • delpiero3
                    Sony Vaio SVS MBX-261 board failure
                    by delpiero3
                    Hi everyone, newcomer in this forum, i watched tons of video from Sorin, i like the way i calmly explain things, i did quite some console repair, i am not that bad at micro-soldering, but troubleshooting where the issue is, is definitely where i still have progress to make. Usually i was able to fix the console because the failure was obvious, or because i was able to find someone with similar measures on the board and was pinpointing what to replace that way.
                    Nevertheless, let's say, i don't come as a total beginner.
                    I have this old laptop, which suit perfectly my needs, with the...
                    10-29-2024, 06:16 AM
