Sony KDL 52W3000
  • shorteddiode
    • 221
    Sony KDL 52W3000
    The standby light flashes 5 times when the TV is pluged in, and will continue to give the 5 flashes. Pushing the power button the green light comes on for about one minute then the set turns off , I have no sound and no picture or backlights. I checked the voltages and they all are correct except goint to the tcon board. I am supposed to be getting 12 volts to the tcon and when checked with the DVMM it bounced between 4 volts and .3 volts. The tcon connects to the FB1 board. The FB1 board is getting the proper 12 volt input voltage. My question is, The sercive manual says 5 flashes is either a bad tcon or bad screen. If I am not getting the needed 12 volts to the tcon wouldn't I be safe in thainking it is the FB1 board? I think the FB1 is also called the logic board. Every board except the tcon has the proper input voltage. I can provide a link to the service info if needed.
    Thanks Everyone
    Re: Sony KDL 52W3000
    Possibly a shorted T-con - can you check if it gets good 12V with T-con unplugged.
    • shorteddiode
      • 221
      Should have mentioned, I unpluged the tcon from the FB1 board and I am not getting the 12 volts foe the tcon from the FB1 (logig) board. That's why I felt the logic board was at fault.
        That would make sense. Does it still only rise to 4V. It may be repairable - do you have schematics of the main board?
        • shorteddiode
          • 221
          Yes go up to 4 volts then drops, then back up to 4 volts then drops. Continues to do that until the TV shuts down. Yes on the schematic
            Can you attach the schematic?
            • shorteddiode
              • 221
              Here ishttp://elektrotanya.com/sony_kdl-52w3000_fix2-
              chassis.pdf/download.html the link for the service info
              • shorteddiode
                • 221
                Well I replaced the FB1 board and now it's up and running, and 12 volts to the tcon.
                  Great. Though sometimes with Sony it seems a board swap is the only way forward.
                  • Hakuu
                    by Hakuu
                    Hi There,
                    More Details
                    TV Model - LG OLED77G1PUA
                    07-12-2023, 02:37 PM
                  • advant
                    by advant
                    02-03-2020, 12:25 AM
                  • m1ch43lzm
                    by m1ch43lzm
                    05-12-2025, 08:37 PM
                  • gersrt
                    Ordered Wrong TCON Board For Sony TV, Can I flash Epprom
                    by gersrt
                    HI
                    Made a mistake and ordered the wrong TCON board to replace in my KDL-46HX823, the board I ordered was Sony PLY 1-883-893-11 which is sort of correct.
                    But later realized this board is used in 4 or 5 models, any way the one i got sent was for KDL-55HX820.
                    Physically these boards are identical, everything on the board is the same. I havent put this board into the TV yet, but am I right in saying all i would have to do is copy the Epprom from my faulty board and transfere it on to the new board, or is there still something else that may stop this working....
                    01-27-2021, 05:49 PM
                  • howardc64
                    by howardc64
                    07-24-2025, 05:17 PM
