screen protectors and tint
  • tvduude
    • Jul 2012
    • 67
    two part question about a screen protection for my 42" LCD.
    was wondering if theres an inexpensive route other than just buying a big slab of plexiglass at my local hardware store. something with more optical
    clarity sold by the square inch maybe?
    and along the lines of tint. surely some of you have been watching tv
    at night and notice the backlight is TOO BRIGHT even when adjusting the settings to lowest bright levels the whites are blasting.
    i was thinking that a tinted screen protector would drop the white levels a bit
    while theres still alot of levels range to boost from the picture settings to compensate loss of color
    "vibrance" ..is that word i'm looking for?
    so has anyone considered tinting their screen protectors?
    Re: screen protectors and tint
    Many Panasonic plasmas have a tint-screen glass plate on the front; this significantly improves contrast but at the disadvantage of reducing white levels a bit. It also provides protection against impacts on the screen, Wii controllers etc may break the front glass but not the plasma panel.
    • Ryan.man
      by Ryan.man
      02-04-2025, 12:23 PM
    • reformatt
      by reformatt
      07-31-2025, 08:37 PM
    • smic717394
      by smic717394
      07-25-2024, 10:16 AM
    • Chrissygizmo
      by Chrissygizmo
      02-10-2025, 12:33 AM
    • spice_disc
      Vizio TV M50-C1 reboot cycle and static on screen
      by spice_disc
      I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
      The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
      09-08-2024, 02:37 PM
