vizio vf55 power surge
  • scottafl
    • Jul 2012
    • 16
    • US
    Re: vizio vf55 power surge
    me...
    • scottafl
      • Jul 2012
      • 16
      • US
      just on another site and they stated that the 12v and 24v or any of the high voltage does not come on until the TV is turned on, and that my problem is most likely on the main board. what do you think?
      • Mr Bill
        • Nov 2011
        • 648
        You can force the power supply on by putting a 3.3k ohm resistor from the pson pin and 5vsb. Do this with nothing hooked up to the power supply. Check voltages and see if you have 12v & 24v. If you do then the mainboard would be the likely cause.
          I was in bed have you checked PSON?
          • Dani_2024
            by Dani_2024
            10-28-2024, 05:06 PM
          • PantherDave
            by PantherDave
            Hi all!
            05-29-2024, 02:01 PM
          • GLISIT
            by GLISIT
            01-16-2025, 02:29 PM
          • mkdj
            Acer TravelMate P214 - N19Q7 main power rail shorted to ground
            by mkdj
            Dear all,
            I have taken out the motherboard of a Acer TravelMate P214. There is a short to ground on the main power rail (19V). I don't have the schematics or boardview for this board (DAZ8IMB1AA0 REVA). But I have found 4 MOSFETS close to the main power rail : 2 N-Channel and 2 P-Channel.
            I have checked resistance across each of the 4 MOSFETS. I have the following readings:
            Both N-Channel Mosfets: nothing odd
            P-Channel MOSFET number 1:
            source - drain : 117 kOhm
            source - gate: 96 Ohm
            gate - drain: 117 kOhm
            P-Channel MOSFET...
            08-20-2025, 06:08 AM
