Samsung LCD TV Screen Image Retention / Burn-In
    Hi guys, was given this Samsung LCD TV by a family member because it would not come out of standby which turned out to be a faulty T-Conn board. The TV is now fully operational but has some very slight screen image retention, apparently caused by a SKY logo or something? This image was present before the repair. If I were keeping this TV it would not bother me too much as it's very slight but I'm looking to sell it on.
    My question is, is there some way of rectifying this problem?
    Model number: LE32R87BD
    Year: 12/29/2007
    Thanks,
    Al.
    Re: Samsung LCD TV Screen Image Retention / Burn-In
    It will go away usually in a couple of days - LCD burn in is usually temporary.
    If the T-con was faulty and held the image static for a long time (without the AC reversal a working T-con provides) - it may have electrolysed the LCD (which only takes 10-20 minutes before visible burn in appears.) You can try applying strong flashing patterns to the screen to attempt to fix it, but there are no guarantees.
      As I'm a 'newbie', how doe's one apply strong flashing patterns to the screen?
        Do you have a computer which you can connect to the TV?
        Though I would say a couple of days of "normal" TV should get rid of it for good.
          Would a laptop work via HDMI cable?
            Should be fine.
              What do I have to do next after connecting the laptop to the tv?
                Can you create, e.g. a PowerPoint presentation which flicks between black and white every second?
                Has the burn in decreased from normal use?
                  To be honest, I've not had this tv running for a couple of days normal use. Maybe I should leave it on when I get home tonight to see if the burn-in fades out? I'll also have a go at the PowerPoint presentation you mentioned.
                    I think you should use it - you'll find that it will decrease usually within a couple of hours, at most a day...
                      get one of these,works great for getting rid of image retention (burn).
                      http://www.ebay.co.uk/itm/Plasma-LCD...#ht_3646wt_932
                      wont work on mura effect though,still trying to work that one out
                      fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
                      please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!
                        I laughed a bit at the description though as it claims to be able to improve lagging/response time...
                        Defect in either the backlight or the LCD panel itself.
                          wont work on the lagging/response time,i was a little taken back at how that could fix that myself too!,i got one of those disks,great for screen burn and does work.
                          but...
                          dont sit in front of the tv watching it run,it feels like you have had 8 joints !
                          shortly after ,i got me pink floyd Lp out
                            Will this disc fix sunburn? Only joking guys! I've used the t.v now for a while and to be honest, the image is still the same, just noticeable. Only wish there was somehow I could take a picture of it?
                              Got myself one of those Calibration, Screen Burn DVDs. Run it twice through the screen wash (2hrs) Still a bit of burn there so now trying it on the color wash section. Maybe you have to listen to 'Sgt Peppers Lonely Heart Club Band' to make it work?
                                pink floyd you mean!,it takes a good 6 hr running time to get rid of image retention,it did with an lg i was fixing,but it did go
                                  Not sure if you can see the image I'm talking about in the photo? In the middle of the screen, the image looks like a square box of circles?
                                    Looks more like mura, defect in the LCD itself.
                                      Is it repairable of terminal?
                                        that is mura,not image retention,your disk wont get rid of that
