I have a Panasonic TH-42PZ77U; I am experiencing the 7 blink power issue. I did the usual troubleshooting by trying a new outlet and unplugging all the cables from the plasma. Then I downloaded the tech manual and went through the troubleshooting steps. When I unplugged the SU board the TV powered up so I ordered an SU board. When I installed the new SU board the same thing is happening. Could the SC board be frying the SU board when I power it up? Your help would be very much appreciated.
Panasonic TH-42PZ77U No Pwr, Blinking 7 Times
Re: Panasonic TH-42PZ77U No Pwr, Blinking 7 Times
Panasonic has designed their plasma TVs so well that the buffers are isolated from the SC board and vice-versa. I have never seen a Panasonic with a bad buffer that was caused by a bad sustain or a sustain damaged by the buffers.
Anyway, the OP stated that the TV did not throw a blink code when powered on without the SU board attached confirming that the SC board is fully working.Comment
When I unplug the SU board and turn on the TV as the tech manual requested the screen turns on and I can see the menu. But I can only see the bottom half of the screen because the SU board is out. If the panel was bad would it power up and the screen turns on? As soon as I put the SU board back in the screen does not turn on and the power light flashes 7 times then pauses and repeats. If it is a buffer board how do I figure out which one?Comment
Here is a service bulletin on these models. The SU is the buffer board that I was referring to. When the SU or SD boards go bad then you must replace the plasma panel as well as the culprit board (SU or SD). So unfortunately the TV is not economically repairable.Attached Filesif you find these attachements useful please consider making a small donation to the site
Followed the service bulletin, looks like the SC board is the problem. I removed the board and would like to check the 5N2307 FETS. How do I do this?Comment
I have a 42P700U with the 7 blinks. I have gone thru the troubleshooting steps and now with the SU board disconnected it stays powered up. My question is can I hook the board back up and just disconnect the 4 ribbon cables that feed the display panel? I want to make sure it is not my panel that is bad. My thought is if the SU board is in fact defective it will still give me the 7 blinks with the panel disconnected.Comment
If the panel really is defective the SU will have been damaged by the short and you should get 7 blinks but this also indicates an SU board failure so you have to take a chance.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
So what you are saying is I should change the SU and see what happens? Maybe waste alot of money. Can the SU be disconnected from the panel side and not damage it?Comment
After doing a visual inspection on the display panel I found a spot where the lines are broken. It looks like a small cross where there are no lines. What is this? Is this possibly a shorted panel? I am still waiting for my new SU board and I am afraid that if this is a short in the panel I am just going to fry the new board. I tried to take a picture of the defect but it is impossible due to the reflections. When I shine a light on the panel it is easily seen. I estimate the size as .09 wide by .06 up and down.Comment
That doesn't sound too good. Do a resistance check on the ribbon that goes to the buffer board where the defect is. Look for shorts to groundDid I leave the soldering iron on?Comment
OK I checked from chassis ground to all the pins on the ribbon cables using my digital ohm meter. All checked open.Comment
Just received the new used SU board and installed it. Same problem. Disconnected board and set powers up normal and stays on. I guess I got a bad board or there is something really crazy. I even disconnected the 4 ribbon cables going to the display and it does the same thing, 7 flashes of death.Comment
There are some 2N5307 or 2N3995 transistors on your board. Have you checked those for shorts?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Assuming...7 Photos -
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
by sam_sam_samI did not have any 27uf @ 50 volt capacitors but one nice thing is that it has enough room for two capacitors in parallel a 22uf and a 4.7uf @ 50 volts 22 plus 4.7 equals 26.7uf which so very close to 27uf I will show some pictures of it sometime tomorrow
After all of... -
by SLB007I get no image nor backlight, standby light blinks 13 times then stops. Any clues what it could be no evidence of damaged components11-02-2025, 04:08 PM
by howardc64All left and right refers to looking from rear of TV (or looking from front with TV upside down)
- TV came with vertical bars and no image. Found faulty TVS on left buffer board. Also replaced T-Con (may have damaged the original while hot air removing components, board has slight warp) and have full image but few horizontal lines on the screen. Some of the lines appears to be 2 pixel tall while others are 1 pixel tall.
- Disconnecting left and right buffer board potentially reveals problems on both sides with different signals (unless this T-Con require jumper like Samsung FB_TRDY1&3) Fault
- Loading...
