Vizio VX32L no 12v
  • Mr Bill
    • Nov 2011
    • 648
    Vizio VX32L no 12v
    I've been searching threads all morning but haven't found anything that helps me with my issue. The Tv turns on from amber standby to white but after 2 seconds it goes back to standby. I'm getting 5v standby but nothing for 12v. In the 2 seconds the tv is on i can check all the regulators on the main board and they are all correct.
    The service manaul lists in dc-dc converter flowchart 12v present with the power turned on to check J7 pin 1 (Ps-On) is getting 3v. I'm getting zip (0v) at the ps-on pin. I disconnected the tcon to see if the ps-on would go higher but that did nothing. I then disconnected the inverter and again nothing on the ps-on pin. I pulled the caps on the power supply and checked the esr and capacitance and they are all good. Checked diodes and they are good. Resistors are good too. I don't know where to go from here. The large cap reads 159.6v in standby and 384v with the tv on for the 2 seconds.
    There are 2 fuses on the mainboard. Both read 0.00 ohm. With the tv on for 2 seconds i get 5v at the one fuse but nothing at the other. I'm assuming the second fuse that i'm getting non reading on should be 12v. SO i'm thinking that this is a power supply issue. I uploaded the service manual for anyone that needs it. Its 4.74 MB though.
    Any suggestions would be appreciated
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Vizio VX32L no 12v
    I'm not suggesting you are making this mistake, but the last time someone wrote the above regarding the voltage regulators, he was dead wrong. Luckily for him, I asked to post the actual readings, and he fixed his TV for 52 cents. Now if I can only find that thread (sigh only 2,610 google hits).
    Edit: found it (from post #1 - "All my voltage regulators are testing perfectly.")
    https://www.badcaps.net/forum/showthread.php?t=21269
    So I prefer people list the part number and the voltages of all pins so we can verify. For example,
    U10
    AS1117-33
    pin 1 = 0.0
    pin 2 = 3.3
    pin 3 = 5.0
    You can try disconnecting all your boards and jumpering PS-ON with a resistor. Like so
    https://www.badcaps.net/forum/showpo...1&postcount=45
    If 12V comes up, then some other board is dragging down the 12V rail or the main board isn't sending PS-ON. If it does not come up, then something on the power board is dragging it down.
    --- begin sig file ---
    --- end sig file ---
    • Mr Bill
      • Nov 2011
      • 648
      Here is the regulator values
      U2
      AS1117
      pin 1 = 2.050
      pin 2 = 3.296
      pin 3 = 5.0
      U4
      AS1117
      pin 1 = 2.068
      pin 2 = 3.312
      pin 3 = 5.0
      U7
      AS1117
      pin 1 = 0.0
      pin 2 = 1.249
      pin 3 = 3.326
      U8
      AS1117
      pin 1 = 2.067
      pin 2 = 3.312
      pin 3 = 5.0
      U9
      AS1117
      pin 1 = 0.253
      pin 2 = 1.549
      pin 3 = 3.326
      U33
      AS1117
      pin 1 = 2.067
      pin 2 = 3.327
      pin 3 = 5.0
      U10
      1084
      pin 1 = 1.324
      pin 2 = 2.574
      pin 3 = 4.98
      All the regulators are adjustable. I replaced U7 with a brand new one from digikey. The old one was reading .768 on the adj/gnd pin but now the new one reads 0. I tested U7 from Vout to GND and i'm getting 96.1ohm which is what prompted me to change U7 but i'm still getting the same 96.1 ohm. The dc-dc converter flowchart claims U7, U8, & U10 should have 1.8v on pin 2.
      I would pull the power supply and run a resistor but i am unsure which pin i ps-on on the supply (pic 3). The legend on the board doesn't specifically state a ps-on pin.
      • retiredcaps
        • Apr 2010
        • 9271
        What part number did you order from digikey?
        Are there any markings on the backside of the powerboard?
        • Mr Bill
          • Nov 2011
          • 648
          497-1244-1-ND is the part i ordered. THere is nothing on the bottom of the power supply.
          • retiredcaps
            • Apr 2010
            • 9271
            Is CN3 the connector to the main board?
            • retiredcaps
              • Apr 2010
              • 9271
              Where is J7 pin 1? If you can find it, put your multimeter on continuity and "ohm out" the board connector. Once you find it that should be your ps-on.
              • Mr Bill
                • Nov 2011
                • 648
                I ohmed out J7 pin 1 back to the power supply and it is a ground pin. I thought this is odd so i ohmed J7 pin 1 to the chassis and its 0.000, so is this right? I don't want to short anything out. J7 is on the main board, it's the connector that goes to the tcon board.
                • retiredcaps
                  • Apr 2010
                  • 9271
                  Can you post a close up picture of this?
                  • retiredcaps
                    • Apr 2010
                    • 9271
                    Btw, looking at some other VX32L threads, it seems to me there is more than one version of the power board which is not surprising. In another thread, the ps_on pin is clearly marked. See last picture in
                    https://www.badcaps.net/forum/showpo...7&postcount=13
                    • Mr Bill
                      • Nov 2011
                      • 648
                      Let me know if you need anymore.
                      • retiredcaps
                        • Apr 2010
                        • 9271
                        I must be blind, I can't see the pcb designation J7? Maybe the angle of the picture is hiding it?
                        • Mr Bill
                          • Nov 2011
                          • 648
                          That's my fault. The marking is under the connector that was connected so it couldn't be seen. According to shop jimmy there are 2 power supplies for this tv.
                          • retiredcaps
                            • Apr 2010
                            • 9271
                            1) On J7, see if pin 1 and 2 have continuity to ground.
                            2) Are J7 pins 1 and 2 have a black color wire?
                            It isn't universal, but if pins 1 and 2 are black colored wires, it might represent gournd?
                            3) If shopjimmy owners are saying there are 2 power supplies, I think the service manual you posted may be the wrong one for your power supply.
                            4) See if there is another V32XL service manual.
                            5) Does your TV have more than just VX32L in the part number?
                            • retiredcaps
                              • Apr 2010
                              • 9271
                              6) Also, pins 1-4 on J7 usually carry ground/power to the t-con and it would be strange to find ps_on on that connector.
                              • retiredcaps
                                • Apr 2010
                                • 9271
                                7) From looking at the other boards (post #10), I think your black wire (pin 13 or pin1 depending on where you start) labeled REMOTE on CN3 is your ps_on. I came to this conclusion because your main boards are the same (0171-2272-2174). You can see if I'm right or not.
                                https://www.badcaps.net/forum/attach...5&d=1322285466
                                • Mr Bill
                                  • Nov 2011
                                  • 648
                                  The model number is VX32L nothing else and the service manual i uploaded is vx32l. I have been wondering if the service manual was incorrect. There are some differences in the dc-dc converter flowchart, U5 & U6 aren't LDO regulators to start with not to mention the J7 pin 1 that you have pointed out. I believe i saw this morning someone stated using a VW32L servce manual but i'm trying to find that post.
                                  • Mr Bill
                                    • Nov 2011
                                    • 648
                                    I put a 3.3k resistor from "remote" to 5v stb. The power supply did turn on but i'm still getting 0 for 12v. I checked the large cap and its at 386v so the pfc is activating. So i'm guessing that something in the power supply is bad.
                                    • retiredcaps
                                      • Apr 2010
                                      • 9271
                                      1) See if D7, D8, and D9 are shorted.
                                      2) Can we also get a pic of the underside of the power supply?
                                      3) We are looking for a SMPS IC for the secondary voltages. It might be an 8 pin IC.
                                      • Mr Bill
                                        • Nov 2011
                                        • 648
                                        Here is a picture of the bottom of the power supply. I removed D7, D8, & D9 and they are good. I think i may have found something but you be the judge. On the top of the power supply hidden under a heatsink is a DIP-8 ic (A6252M), the datasheet lists it as a flyback switching regulator. If i measure pin 1 (Mosfet source/overcurrent protection) to ground i get 0.006 ohm.
                                        Maybe this is what is causing the power supply to shutdown and 12v not be present.
                                        • SS454
                                          vizio e650i-a2 backlight flashes then turns off
                                          by SS454
                                          vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                                          panel: au optronics T650HVN05.4
                                          72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                                          link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                                          Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                                          https://www.shopjimmy.com/vizio-56-0...-power-supply/
                                          Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                                          08-20-2020, 03:57 PM
                                        • mrtek
                                          Vizio M65-C1
                                          by mrtek
                                          Hi.
                                          picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                                          When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                                          This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                                          07-14-2025, 07:28 PM
                                        • howardc64
                                          Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                                          by howardc64
                                          Failure Symptom
                                          No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                                          Where is the short?
                                          Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                                          Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                                          05-27-2025, 02:56 PM
                                        • howardc64
                                          Vizio SmartCast TV software bug that looks like hardware
                                          by howardc64
                                          Bug looks like hardware so thought I posted it here. Exact same behavior on 2 different model 4K Vizio TVs running their SmartCast smarttv software. After launching youtube app, press vizio button on remote to return to the smarttv menu, once in awhile, a column of bad pixels will show for few seconds on the left hand side.
                                          It seems the vizio software is reinitializing hardware when returning to the smarttv menu. In general, SmartCast software isn't very good. Also will randomly (relatively infrequent) get no network connection when on wifi and require reboot....
                                          11-16-2024, 05:17 PM
