Vizio vp322 - excessive current on 5v circuit
  • Persist2
    • Jul 2012
    I am attempting to repair a Vizio vp322 plasma tv for a friend. (My first foray into TV repair occurred recently when I used YouTube videos to replace capacitors on another friend's LCD TV, and I successfully repaired it.)
    Anyway, my friend's plasma TV has been broken down for months. According to his memory, it had the clicking sound for some time, and then it went totally dead.
    I replaced two bulging caps on the power board - all the others looked OK. However, the tv was still dead. There was no standby light and no observable response to pressing the tv's power on button.
    Then I tested the 5v, 12v, and 16.5v circuits. All showed correct voltages on my multimeter.
    Then I discovered a 3A hardwired Littlefuse on the main board was blown. Labeled F3, it was located where the 5v line from the power board enters the main board. I rigged a blade fuse holder with a 3A fuse. The fuse blew when I connected the tv's power cable.
    So I decided to check the amps coming from the power board's 5v circuit. It is putting out around 8 amps, so, obviously, this is why that 3A Littlefuse had blown on the main board.
    So my question is: In what way could an initial capacitor problem lead to excessive amps on the 5v circuit?
    Any help would be greatly appreciated.
    Ken
  • jetadm123
    • 2169
    Re: Vizio vp322 - excessive current on 5v circuit
    If the bad cap(s) was a DC filter cap, then the excessive AC ripple that it's allowing through will cause the components on the 5V rail to work harder and thus overheat and eventually short out.
    If the bad cap(s) was used to set frequency, then a change in the capacitance value can affect the frequency, again, causing a mosfet or diode to overheat and short out.
    Assuming you replaced the buldged caps, try looking for shorts on the 5V rail using your meter.
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • SS454
      vizio e650i-a2 backlight flashes then turns off
      by SS454
      vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
      panel: au optronics T650HVN05.4
      72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
      link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
      Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
      https://www.shopjimmy.com/vizio-56-0...-power-supply/
      Vizio 55.75J01.001G (91.75J10.004G) Main Board...
      08-20-2020, 03:57 PM
    • Astonished
      Fixing the Charge Circuit of the Batteries of the DC Motor
      by Astonished
      Hi friends of electronics
      What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
      The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
      Please help me fix this circuit.
      (the datasheet of the IC: https://pdf.datasheet.live/28...
      01-28-2025, 06:24 AM
    • rddube
      Lenovo L490 Ram voltage circuit malfunction
      by rddube
      Hello friends,
      Looking for some guidance here. The RAM voltage circuit on this motherboard keeps burning out PU301 which is a RT8231AGQW. Copy of the board with the burnt chip attached with some voltage measurements and copy of the schematics also included.
      I think I've checked almost every component in the circuit, but when I change the RT8231, the laptop starts I have 1.2V on the inductor for about 10 seconds and then the RT8231 goes south and no more voltage on the inductor. All other voltages on the laptop are good, this is the only one conking out for a reason I...
      07-15-2025, 04:41 PM
    • mrtek
      Vizio M65-C1
      by mrtek
      Hi.
      picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
      When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
      This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
      07-14-2025, 07:28 PM
