Hp/sharp 32,37" lcd and most sharp lcd blinking green light problem
  • electronicsurplus
    • Jun 2012
    • 210
    Sharp 32,37 and many sharp LCD blinking green light
    See below for test
    Just worked and wanted to share the info
    Electronic Surplus
    This Forum absolutely the best and, the most helpful forum I have ever found anywhere. thanks to all the fantastic members here
    Help keep these from the landfills
  • electronicsurplus
    • Jun 2012
    • 210
    Re: Hp/sharp 32,37" lcd and most sharp lcd blinking green light problem
    This works for MOST Sharp Aquos and HP LCD televisions
    Other LCD use chennel - and vol + while plugging in
    The power light is an error code that tells me exactly what is wrong with the TV. Count how many times the POWER led flashes per second? (Dont worry about the OPC led)
    1x per second (constant steady blink) = bad inverters/lamps
    2x per second = bad power supply
    3x per second = bad main board
    If its 1x per second, try doing the factory initialization to get the TV back on to confirm a bad lamp/inverter.
    Try doing the Factory Initialization (WARNING: THIS GIVES YOU ACCESS TO THE SERVICE MENU. DO NOT ADJUST ANYTHING IN THE SERVICE MENU OTHER THAN WHAT I PROVIDE YOU IN THESE INSTRUCTIONS. IF YOU DECIDED TO ADJUST ANYTHING OTHER THAN WHAT I PROVIDE YOU IN THESE INSTRUCTIONS, I WILL NOT BE RESPONSIBLE IF ANYTHING WRONG HAPPENS TO YOUR TV.)
    unplug tv
    press and hold at the same time “Vol –“ and “input” button on the TV set.
    while holding those buttons, plug the tv back in
    the tv should turn on by itself, keep holding the buttons until the letter “K” appears. Then let go.
    Once the TV turns on, take a look at the screen. Does it flicker then shut off? Or do you hear a buzzing noise from the right edge of the TV? If so, then you have bad inverters or lamps. Once youre done, unplug the tv to get it out of the service menu.
    If it is 2x per second or 3x per second, then those boards are just bad and they need to be replaced. There isnt anything you can do right now to fix it.
    • joens
      • Jun 2013
      • 7
      • Sweden
      I have tried to find someone else that have the same trouble as med.
      I have a fault code that shows like the power och OPC blinks simultaniously, both just once.
      At first the power only blinks but when pressing "menu" on the controller OPC also starts to flash.
      The servicemenual says thats its a communication error. I dont know what kind of error...
      I'm thinking of one thing, the only colour i've seen on the power-led is green and orange(when updating firmware).... is it suppost to be red sometimes?
      Sharp (non-Vestel) (some models)
      Power LED is RED in standby. When turned on, LED turns green. If an error occurs, the LED will go red and will flash along with the OPC LED. The combined error code greatly narrows down the issue: an error of 2-5, for example, indicates a main board 5V failure. (One can wish for other manufacturers to implement this... but they haven't.)
      • cesetar66
        • Jul 2013
        • usa
        sharp aquos lc32..
        Tried all that's been said on this post..
        no sound... blue screen... barely see the "analog" and "inputs" on the top right hand.. goes to the blue screen on an input setting.. then a yellow flickering screen on other setting... but no sound and no video... power seems to be ok.. no bad capacitors as far as I saw on the power board... since there is no sound at all and messed up video..(blue or yellow) can I be closer to assume that is a main board issue?
        Thank you for your help guys..
        • Jmackz
          • Sep 2014
          Hey so I did what you said and my Tv turned on and was working. After I get into the menu what do I do? As soon as unplug it starts to flash again.
          • Jmackz
            • Sep 2014
            Hey so I did what you said to do and my tv starts to work. What do I do once I'm in that menu? As soon as I unplug my tv it goes back and starts flashing again
            • Armstrong46
              • Oct 2015
              unplug tv
              If the POWER led on my set is flashing 1X per second and I'm not able to get the screen to come on after completing the factory initialize steps mentioned above, is my next step to replace the inverter board? My TV is a Sharp Aquos Model LC-52D62U.
              • jxrepman
                Asus X453MA won't turn on and green led light blinking
                by jxrepman
                Hi there,
                I have this ASUS X453MA Laptop that's not turning on. When I plug in the charger, the green light just keeps on blinking and pressing the power button does nothing.
                I have checked the charger and it is giving 19+ V
                I have disconnected the battery and pressed power button for 30 seconds.
                I tried another RAM stick.
                Tried disconnecting the keyboard and touchpad.
                Tried disconnecting the HDD and the wifi adapter.
                The problem persists.
                Hope you could help me out on this one. Thank you.
                12-14-2024, 06:40 AM
              • MOSSEP
                Monitor Audio RSW12 - Green light, but no sound
                by MOSSEP
                Hi
                Im hoping someone might be able to give me some idea of what may be wrong with my Monitor Audio RSW12 Sub.
                Ive owned it since new in around 2002, so would really like to keep it running if I can, it was the first ‘decent' bit of audio equipment I ever purchased and is a little sentimental.
                The issue I had was that it would power up with the red light, but sometimes the green light would not come on and I would get no bass from it. If the green light did come on though, I would get sound out of it.
                I have already tried replacing all of the...
                01-26-2025, 08:33 AM
              • MOSSEP
                Monitor Audio RSW12 - Green light but no audio
                by MOSSEP
                Hi
                01-26-2025, 08:18 AM
              • lcdcaps1
                820-2610-A Sys onewire help, no green light. Please help from the gurus
                by lcdcaps1
                Hi
                I have an 820-2610-A motherboard that has no green light.
                I have noticed is when I do a SMC reset the light on the Magsafe blinks.
                From My understanding, the sys onewire circuit is responsible for the green light on the magsafe
                The sys onewire circuit on this model and others is more involved
                I was hoping if anyone knows about this and how it works, can reply and let me know
                I know this is an old model but I am sure there are people who still works on these or knows about them
                I get 1.1v on the C7771 capacitor and will replace...
                11-06-2023, 01:28 PM
              • naddaw000
                Toshiba 55U7863DG - green light blinking (17MB130S)
                by naddaw000
                Hello, I am trying to bring back to life my Toshiba 55U7863DG, which has never been the most reliable device - keep on annoying me with its slowness and some random start-up/shutdown issues requiring to unplug the AC. But yesterday it finally said goodbye and decided to not turn on again. Green light is blinking, I've seen this behaviour before and thought that these are some temporary whims again, but unfortunately not this time.
                I have checked that my TV is build based on the 17MB130S board, which seems to be quite popular and easy to buy as a used one. Still I would like to ask...
                12-02-2023, 01:35 PM
