Goodmans 42" Plasma standby to green but no pic - help me!!
  • shepp
    • Mar 2012
    • 377
    • England
    Goodmans 42" NR GTV42P PLASMA
    my first plasma ive got in, doesnt come on, red standby light goes to green but nothing happens then theres a little red LED on the power board that comes on when out of standby and also a green one thats on all the time near where the 240v plugs in, i have no idea where to start, ive tried to check voltages at the plugs but there is none?? not 100% how these work, but i am willing to buy new board if i new which board to buy or test i will post pics later as i have to pop out
    Re: Goodmans 42" Plasma standby to green but no pic - help me!!
    It's just an 852x480 plasma; how much did you pay for it? This chassis is made by Beko, and I think it uses LG PDP parts. Post pictures!
    • shepp
      • Mar 2012
      • 377
      • England
      its just took me 45mins to get these pics available for upload!! stupid phone!
      the green lights are when tv is switched on, then i hear a relay click then the red light on the far left of the board comes on (power board)
      • shepp
        • Mar 2012
        • 377
        • England
        paid £18 so not too bad
        • shepp
          • Mar 2012
          • 377
          • England
          R8010 is blown ceramic fuse, but just trying to see whats caused it.....any ideas guys?
          i cant find Q8016 and Q8018 any one point me in the right place??
            Okay, Samsung PDP.
            You'll have to point out the fuse for us.
            If the fuse is blown on either sustain board, I would normally consider it an expensive repair. It may simply be the fuse ageing, but it is more likely a failure on the board in some way.
            • shepp
              • Mar 2012
              • 377
              • England
              on the power board to the left are 2 white ceramic fuses far left, its not letting me upload the edited photo, its the one on the left thats gone, there is a repair kit that contains these and 2 big transistors, but i cant find the transistors on the board? ill up load a closer pic after ive eaten my diner
              • shepp
                • Mar 2012
                • 377
                • England
                found them..... tested and there both ok, so im thinking maybe its just the ceramic thats gone....fingers crossed, if anyones got any other ideas of what to check before i order them it would be helpful
                its R8010 thats blown, which is the ceramic on the left of the first pic
                  Common failure - seen it fail on Hitachi PDP's too.
                  • shepp
                    • Mar 2012
                    • 377
                    • England
                    Do you think any thing else will need changing? will be a good buy if that's all it needs
                      Should only be those resistors but could be a shorted fet on PSU.
                      • shepp
                        • Mar 2012
                        • 377
                        • England
                        I'll let you know when I've fitted it. Thanks again tom
                        • shepp
                          • Mar 2012
                          • 377
                          • England
                          fitted resistors just now, and 3 green lights on the board come on then relay clicks and the red light comes on and the 3rd green led goes out, are all the voltages on these DC i mean the feeds to the other boards?
                          its as if its waiting for a signal for something then when it doesnt recieve it its clicking off, the green light on the front of the tv stays on green though
                            Check for 170-210V Vs and 50-70V Va.
                            • shepp
                              • Mar 2012
                              • 377
                              • England
                              DC or AC ?
                                Dc
                                • shepp
                                  • Mar 2012
                                  • 377
                                  • England
                                  right.... im getting 5v on D5VL,
                                  15v on Vcc
                                  4v on Vs
                                  and on Va it shoots up fast but then drops down again probably because of Vs voltage not present
                                  what should i check next?
                                    Try testing Vs and Va without Y and Z sustains connected.
                                    Vs and Va are independent supplies; they shouldn't influence each other.
                                    • shepp
                                      • Mar 2012
                                      • 377
                                      • England
                                      done that and they do the same, i have noticed that one of the bigger caps 250V 1000uf looks swelled compared to the other 3 that are on the board, the tops are flat on the others
                                      i have just been through all the diodes and transistors and they are all ok
                                        If you can press the bulging disc down, the cap is okay. The plastic disc will sometimes bulge without the cap failing. Right now I would replace the startup cap for the Vs.
