issues with 17pw26-3 tv boards
  • planetsource
    • england
    hi all,17pw26-3,power to board and thats all,anybody who has dealt with this board and fixed all problems,please give details,many thanks
    Re: issues with 17pw26-3 tv boards
    It's a Vestel... In my opinion, those boards are replace on sight. So many problems!
    • electrickal1
      • May 2014
      • Ireland
      Guys, I have a Vestel 17PW26-3 which is giving a weak washed out picture, I was told to replace D821 (33v zener) but this board is missing this diode!!
      Can anyone tell me where to start to repair this piece of garden fertilizer......
        The PSU should have very little to do with that fault. Can you supply a picture of the fault? It could be a panel problem or a t-con board problem.
        • electrickal1
          • May 2014
          • Ireland
          Hi Tom, yes I will post it tomo as I am currently not at home. This 26 inch Hitachi set had swollen caps on the PSU and one clearly vented, TV turned on ok but goes to a pale washed out picture and very blue almost like a negative photo effect.
            Hmm, good chance of a tab bond fault. I've had it on a 26" Sanyo/Vestel LCD before (using a Chimei V260B1 panel.)
            • masaudio
              • 16
              • England
              On one at the moment, original fault was blown fuse and shorted Q803.
              after this was replaced it was getting red hot, not coming out of standby..
              Tried the control IC802, still nothing until the Q803 failed again.
              Then discovered mains smoothing cap C819 was totally open circuit.
              Replaced the cap, transistor and fuse all again and now the set sits in standby ok, no overheating.. but when you turn it on it tries to come on then shuts back to standby again. to be continued....
              • masaudio
                • 16
                • England
                next step.. if i unplug the inverter connector the set comes on and stays on, with sound etc so seems to be the 24v output to the inverter is tripping the power supply off again.
                • vinceroger69
                  • Mar 2012
                  • 6714
                  what invertor board is the set using in a post the otherday someone else was having the same issue can you force on the psu and place a load on the 24v rail and see if it still shuts down.
                  • masaudio
                    • 16
                    • England
                    its using an LG display, with an LG Innotek inverter board.
                    • dick_barton
                      • Aug 2015
                      • 6643
                      • Wales
                      Have you a photo of your power supply. A nice sharp image would be useful.
                      • jb_Bak
                        by jb_Bak
                        CN6401
                        Pin 01 NC
                        Pin 02 NC
                        Pin 03 "BL_ON": 0V
                        Pin 04 "N/C"
                        Pin 05 "STBY 3.3V": 3.5V
                        Pin 06 "GND": N/C
                        Pin 07 "AC_OFF"...
                        09-27-2021, 04:52 PM
                      • howardc64
                        by howardc64
                        07-24-2025, 05:17 PM
                      • howardc64
                        by howardc64
                        Problem
                        08-04-2024, 10:36 PM
                      • m1ch43lzm
                        by m1ch43lzm
                        05-12-2025, 08:37 PM
