Sony KV24fs120
  • SEAWOLF
    • Nov 2011
    • 177
    • Barbados West Indies.
    Sony KV24fs120
    Sony kv24fs120 powers up and displays picture for a short while and then
    shuts down and standby light displays 2 blinks.
  • ivtec
    • Dec 2008
    • 1967
    Re: Sony KV24fs120
    2 blinks is B+ over current protection(OCP) a short in the power supply.
    you can check R590,R595, C514,C672,and D503.
    • SEAWOLF
      • Nov 2011
      • 177
      Re: Sony KV24fs120
      The problem has been solved,R595 a 470k 1/4watt resistor was opened.
      Thank you very much.
      • Nicktronic
        Sony XBR-65X850D 2 Red Blinks
        by Nicktronic
        I have the subject TV and it will work normally sometimes but suddenly go black and give the 2 red blinks blink code. When this happens, I check the power supply board voltages and all I have is the Standby 3.3V and BL_ERR 2.2V. When it's working normally, all power supply board voltages look normal and stable. I've checked the backlights with a tester and they all test good. I've also read that the 2 red blinks is a faulty power supply board, so could it be throwing up an erroneous BL_ERR?
        Any Sony experts out there that can help??...
        11-19-2023, 06:51 AM
      • DynaxSC
        Extreme High Current & Low Voltage Short Killer ??
        by DynaxSC
        Hi Folks
        I'm looking for a extreme high current short killer solution for a reasonable cost.
        I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
        After taking off the socket, the shorts dissappear again.
        The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
        10-15-2024, 10:13 AM
      • dumbdd
        Sony 75X9400E TV.. 5 Red blinks
        by dumbdd
        I was using this TV for 5 years before it stopped working. I like this TV and would love to fix it myself.*
        When I press the power button, the white led comes on (sony calls the module smart core) and then it switches over to 5 red blinks. No screen, no backlight, no relay click, nothing. I have disassembled the tv and found the service manual for 75x940e online. The manual suggests a faulty power board, TCON or the panel.**
        The standby pin is at 3.3V. Fuses on the mainboard and TCON are fine. Caps on TCON also seem to be fine. When I turn on the tv the white led...
        07-01-2023, 08:54 PM
      • Nicktronic
        Sony XR-55X90J 4 blinks
        by Nicktronic
        Hey guys, got this Sony that turns on momentarily and then goes black with 4 blinks of the standby light. I can't find a service manual, but best guess was the Local Dimming board based on a similar TV saying LD_ERR or BCM_ERR. I found a replacement, but it didn't work. Before I put more money into replacement boards, Im wondering if anybody has seen this issue and what worked for them, or has the service manual for this specific TV.
        Thanks!...
        02-13-2024, 07:01 PM
      • x_orange90_x
        Sony KD-60X690E 6 Blinks, no image
        by x_orange90_x
        I just got this today and it has the infamous 6 blink code. I've read it's quite possibly bad backlights, and I intend to check them soon. However, I was just curious if the Sony logo should it's shouldn't be appearing briefly between powering on and the light starts flashing. I've read at least one other person had the logo flash quickly, but mine does not show anything at all, not even a flicker. The green light comes on and after about 5 seconds the red light flashes. So I'd expect in this 5 seconds to see the logo. This leads me to believe it could be a power supply issue.
        I...
        12-10-2024, 09:10 PM
