Westinghouse LTV32W4 HDC no backlight
  • eagle00799
    • May 2012
    • 322
    I have this this lcd tv that has sound and image but no backlight. I have read some posts about the inverter and some about the backlight being bad. I have checked the voltages on the 2 connections going to the inverter and if someone knows if these look good or bad can you please advise?[LIST]
    Connection 1, pins 1-5 24.8
    pins 6-10 are ground
    Connection 2, pins 1-5 24.8
    pins 6-8 ground
    pin 9-SEL 00.0
    pin 10 E-PWM .7
    pin 11 1-Pwm 48. mv
    pin 12 BLON 28.2
    Here are a few pics of the boards.
    Re: Westinghouse LTV32W4 HDC no backlight
    Under the plastic shield on the left hand side is the inverter... looks like you need to take the frame off to get it, but there is usually a fuse on the inverter board.
    • eagle00799
      • May 2012
      • 322
      I get 24.8 at both fuses.
      • retiredcaps
        • Apr 2010
        • 9271
        1) You have 8 ICs on the inverter board (3 pin leg). What is the part number?
        2) Do you even see a brief flash of the backlight?
        3) Is there a part number of the inverter transformers?
        --- begin sig file ---
        --- end sig file ---
        • eagle00799
          • May 2012
          • 322
          1)There are 2 different part numbers on the 8 IC's, IC number 1,3,6 and 8 are D454 BE5Z1B and IC's 2,4,5 and 7 are D413 BE652Z.
          2) I get no flash at all from the backlight.
          3) The part number for the transformers is like this, T51 0038 21257 0611 01 2 K
          • retiredcaps
            • Apr 2010
            • 9271
            See if the mosfets are shorted between G-S, G-D, and D-S.
            http://pdf1.alldatasheet.com/datashe...D/AOD454L.html
            Check the resistance between S1 and S2 for all of them. List all your measurements as they should be within 3% of each other. They should be around 1K ohm according to
            http://www.lcdparts.net/TransformerD...ProductID=2817
              Can I get closed up pictures in the two areas? CMO Inverter usually has another small black fuse that looks like a surface mount resistor for the PWM IC section.
              The two fuses you checked, are they labeled with F1, F2?
              • eagle00799
                • May 2012
                • 322
                Budm, The 2 i checked where f2 and f3 then i checked f4 and f5 which are real small they are on each side of f2 and f3, F1 i found by the cn2 and it has a 20 stamped on it. i get 24.8 on one side and 0 on the other side.
                • eagle00799
                  • May 2012
                  • 322
                  The mosfets seem to be same on the D454's and the same on the D413's and the transformers have a high reading of .960k and a low of .939k
                  • Mr Bill
                    • Nov 2011
                    • 648
                    Have you checked F1? If your getting 24v on the one side but 0 on the other would indicate it is open.
                    • eagle00799
                      • May 2012
                      • 322
                      so can F1 just blow for no reason or did something make it blow?
                        That is the common failure for this fuse for the PWM circuits in CMO inverter board, that is always the first fuse I check. I replace a lot of them before and never come back for repair again, it can due to inrush current. There should be current and voltage rating close to this fuse. You can put you meter in DC current mode and put the two probes on each end of the fuse, then take the reading and double up for the fuse value.
                        • eagle00799
                          • May 2012
                          • 322
                          so to order a new fuse does the 20 that is stamped on it mean 20amp? and it is a 24 volt fuse? i see no current and voltage rating near by for this fuse. to get the Value do i turn the power on and put the probe to each end?
                            I am afraid you may slip the probes, so, do you have any 1 Ohm 1/4 w or 1/2 Watt resistor that you can solder in place of the fuse, then you can take the voltage reading across the resistor to determine the current?
                            • eagle00799
                              • May 2012
                              • 322
                              no resistors here and my local repairman wont return my call, i left him a message asking if he could solder in a new fuse. I might have to put this on hold till i get properly equipt.
                                If I remember correctly, I use 1A LITTLEFUSE PICO II series through hole fuse.
                                Solder one end of the fuse to VBL PIN 1, 2, 3, or 4 of CN2 another end is soldered to top end of C11. No need to remove the old fuse since it is blown any way.
                                • lilmonk3
                                  • Apr 2012
                                  • 259
                                  Budm.. Would you happen to have a picture of this mod?
                                    I cannot find my pictures, the TV I took the pictures is not Westinghouse but it uses the same inverter board, and I have 1000's of pictures I do not remember which brand it was. Is the board the same one as shown in post13?
                                    See picture I made, use insulation such as tape under the left leg.
                                    • lostone
                                      Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
                                      by lostone
                                      Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
                                      First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
                                      When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
                                      05-19-2024, 11:40 AM
                                    • alro7779
                                      Westinghouse WD32HN1640-S black screen-no backlight, mainboard TP.MS3393.PB818
                                      by alro7779
                                      Hello, guys!
                                      I have this Westinghouse 32" LCD TV that turns on, standby led lights up (blue) but no image. If I knock on the screen there's no backlight present. I took the back cover off and injected voltage on the led connector using a Led TV Backlight Tester, and no light at all, so... it must be that there's some bad Leds, right? Or there is some another testing that should I have to do? Any guiding I'll appreciate it very much. Thanks in advance!
                                      Alex....
                                      10-03-2025, 05:49 PM
                                    • DanPoka
                                      Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
                                      by DanPoka
                                      I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
                                      Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
                                      This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
                                      02-15-2025, 05:05 AM
                                    • Comp_Pro
                                      No Backlight Macbook A1990 820-01041
                                      by Comp_Pro
                                      Hello all,
                                      Am trying to figure out this backlight issue with this A1990 Macbook Pro.
                                      Tests performed:
                                      There is no backlight even with a good screen.
                                      Backlight IC is receiving the correct support voltages.
                                      Fuse F8400 ok
                                      Current sense resistor R8400 ok
                                      Backlight IC is receiving 3.3V on enable pin.
                                      Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
                                      Backlight IC receiving 5V from PP5V_G3S
                                      Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
                                      I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
                                      05-06-2024, 10:23 PM
                                    • jimbofz
                                      lg 32LC46 backlight inverter board fault
                                      by jimbofz
                                      Hi this oldie had no backlight .after replacing caps on 24v rail ,
                                      still no b/l this uses inverter type:1315 B1-16A,
                                      im sure ive come across the same inverter in a samsung possibly le32r88bd ?
                                      all t/x in board test ok ,so i fitted 15k and led to pin 4 of oz964gn ic
                                      this allows protect to be temporary overridden.
                                      b/l now comes on
                                      but the left hand side of pic is gradually darker than the right side
                                      i have the cct for the tv
                                      but it does not have inverter cct.
                                      i opened it up to inspect the ccfl tubes
                                      and they dont have any...
                                      12-19-2021, 06:58 AM
