50" Samsung Plasma (model number PS50Q91HD) - possible purchase
  • retiredcaps
    • Apr 2010
    • 9271
    #41
    Re: 50" Samsung Plasma (model number PS50Q91HD) - possible purchase
    How are you numbering the pins? If pin 2 is the only pin on one side, those diodes are definitely shorted. That means pin 1 and 3 are on the same side. If yes, both diodes are shorted.
    --- begin sig file ---
    --- end sig file ---
    • retiredcaps
      • Apr 2010
      • 9271
      #42
      Originally posted by psmedley
      Next question will be any tips on replacing SMD diodes???
      CuriousInventor makes an excellent series of soldering videos.
      http://www.youtube.com/watch?v=3NN7UGWYmBY
      • psmedley
        • Apr 2012
        • 144
        Numbered left to right - 1 to 3 - pin 2 is on a side by itself
        • retiredcaps
          • Apr 2010
          • 9271
          #44
          The diodes are definitely bad "in circuit". You can remove them and verify out of circuit. You will have to remove them anyway if they are bad.
          • psmedley
            • Apr 2012
            • 144
            http://preher-tv.blogspot.com.au/201...-clicking.html suggests "DS801 and DS802 are both 1SS184T5LFT, UFR dual package common cathode SMD diodes" I find these on mouser at:
            http://au.mouser.com/ProductDetail/T...sljcLw5w%3d%3d
            However RS in Australia has this as a discontinued product:
            http://australia.rs-online.com/web/p/rectifier/3174558/
            They have a list of 'similar' products - any recommendations?
            • retiredcaps
              • Apr 2010
              • 9271
              #46
              Need 48 spare? 50 for $6.00 + free shipping
              http://www.ebay.com/itm/160586650557
              • psmedley
                • Apr 2012
                • 144
                My only hesitation is the shipping time from the us to australia
                • psmedley
                  • Apr 2012
                  • 144
                  OK ordered the SMD diodes retiredcaps suggested.
                  Whilst I wait for them to arrive, I've been reading http://preher-tv.blogspot.com.au/201...-repaired.html on the other common issues on similar Samsung power supplies.
                  This mentions components like:
                  RX802, RX803, RX832 and RX833 are open or have a seriously increased resistance.
                  RX804 and RX805 are open or have a seriously increased resistance.
                  These all measure around 50 Ohms in circuit vs the stated values of:
                  RX802, RX803, RX832 and RX833= 20 ohm
                  RX804 and RX805= 10k ohm
                  Is this due to them being measured in circuit??
                  It also mentions problems on the sub boards:
                  QS803, QS804, QS805 and QS806 one or more shorted(check for open junctions as well)
                  DS823 shorted(may be open as well) check between pin 1 and 3
                  RS859 may be open or have a seriously increased resistance
                  Can these parts be tested in circuit?
                  QS803 and QS804= NPN 20V 2A SMD BJT(marking ZG)
                  QS805 and QS806= PNP 20V 2A SMD BJT(marking ZH)
                  D823= 18V 0.35W SMD zener diode(marking 8Y)
                  RS859= 4.7 ohm SMD resistor
                  Cheers,
                  Paul
                    Q's and D's can be tested; R's will need to be pulled.
                    Did TV show any picture before it shorted again?
                    • psmedley
                      • Apr 2012
                      • 144
                      I didn't get a chance to actually turn the TV before it shorted. I plugged in the AC, it wasn't clicking, so I made a quick pit stop, came back and it was clicking
                      Any tips on testing the Q's?
                      Is:
                      <quote>
                      POSITIVE PROBE TO: -----NEGATIVE PROBE TO: -----RESISTANCE READING-- CONCLUSION:
                      Emitter------- -- Base---------- Less than 150 ohm ------Transistor is NPN
                      Base --------------Emitter --------Infinity ----------------Transistor is NPN
                      POSITIVE PROBE TO: NEGATIVE PROBE TO: RESISTANCE READING: CONCLUSION:
                      -Emitter------------Base ---------Infinity ---------------- Transistor is PNP
                      Base --------------- Emitter --- - Less than 150 ohm ------- Transistor is PNP
                      Some defective indications of transistors: Resistance between any pair of the terminals is less than 10 ohms* means that the transistor is shorted. Resistance between base and emitter or base collector for both the forward and reverse application of ohmmeter probes is infinity (meter needle don't deflect)* means that the transistor is open. Transistors overheats (except power transistors) during normal operating condition means that the transistor is shorted.
                      </quote>
                      Sufficient?
                      • retiredcaps
                        • Apr 2010
                        • 9271
                        #51
                        I just do a simple all pins combination to see if they are shorted. For a 3 pin transistor, measure the resistance between pins 1-2, 1-3, and 2-3. Any reading under 30 ohms warrants desoldering and verifying out of circuit.
                        • psmedley
                          • Apr 2012
                          • 144
                          Tried to reply on Saturday but server upgrades got in the way
                          All transistor readings were higher than 30 ohms, so I'll assume the sub boards are OK.
                          I do plan on replacing the accompanying resistors as well as the diodes and mosfets before I try powering up again. ie all the parts described in http://www.ebay.com.au/itm/160644626388
                          I just need to wait for all the parts to arrive now - Adelaide electronics stores suck
                          • psmedley
                            • Apr 2012
                            • 144
                            Originally posted by tom66
                            If it helps, I *think* this is the schematic for your PSU.
                            The correct schematic is at
                              Someon's just contacted me about their Samsung PS42C7HD clicking - I might take a chance on it if it's just cold joints.
                              • psmedley
                                • Apr 2012
                                • 144
                                If you're lucky, it will be cold/cracked joints on either QS801/802 or QX801/802 worst case you'll be replacing mosfets, resistors and diodes
                                PS if you don't have easy access to 1SS184 diodes, I should soon have plenty of them
                                • retiredcaps
                                  • Apr 2010
                                  • 9271
                                  #56
                                  Canada and Australia are almost in the same boat when it comes to buying stuff online. I wait up to 60 days for my stuff to arrive, but I get it at very good prices. I try to anticipate my needs well in advance.
                                  • psmedley
                                    • Apr 2012
                                    • 144
                                    I hedged my bets on the 1S184 diodes - I found some in Thailand with expedited shipping today - Only $US6.50 so I should soon have a plethora (well 60) of them.
                                    • TheTVCoop
                                      • Jun 2012
                                      • 17
                                      Any news on this repair?
                                      • psmedley
                                        • Apr 2012
                                        • 144
                                        Not until parts I have ordered arrive
                                        • psmedley
                                          • Apr 2012
                                          • 144
                                          I hadn't mentioned it before, but there were 3 25v 680uf caps that were swelled/leaking on the X & Y main boards - replaced them today in anticipation that my diodes/resistors can't be too far away. They were well and truly knackered - ESR meters reports < 100uf and > 6 ohms. Oh and they were Samwha's
                                          • porfyriadhs
                                            Samsung Plasma PS51D6900DS Bootloop
                                            by porfyriadhs
                                            Hello . I have a problem with a samsung plasma tv stuck in bootloop . The TV is Samsung PS51D6900DS plasma smart tv .Need help if anyone have any suggestions
                                            Thanks a lot !!
                                            10-19-2023, 11:31 AM
                                          • ArMaaN376
                                            Samsung PS51E550 Plasma TV
                                            by ArMaaN376
                                            I am having Samsung PS51E550 Plasma TV. While the TV was working, a crackling sound heard & video went off with audio still ON. After switching it off & ON, the red LED on TV blinks six times & then off.
                                            Opened TV cover & observed foll
                                            a) Green LED on the small PCB blinks at @5-6sec ON & off for 3-4 secs. Red LED on logic board ON
                                            b)Vs & Va on power supply board raises momentarily to 209v & 58v resp & then drops.
                                            c) Cold test on Y-main board shows all 3 pins of FGPF4536 IGBT short to Grnd.
                                            How to confirm Y -Buffer board...
                                            06-19-2024, 04:05 AM
                                          • CDNBrewer
                                            Samsung Plasma PN43D450A2D No Power
                                            by CDNBrewer
                                            Hello, I have a Samsung Plasma TV - Model # PN43D450A2D
                                            This was my parents TV and the initial symptoms were that the display was hard to turn on with the display making various clicking noises until one day it would not turn on anymore.
                                            I took a look and found a couple 1000uF capacitors (i believe on the low voltage size) that had leaked out their electrolyte and did not test well on a tester. I replaced them but still no dice.
                                            When the TV is plugged in, there is no clicking, LED status lights (on PCB boards or the front display) and the power on button...
                                            03-02-2025, 04:59 PM
                                          • alltvrepairs
                                            Plasma Samsung PS-50C96HD Main board BN94-01223C switches off supply after few seconds
                                            by alltvrepairs
                                            I have this almost brand new Plasma was well stored. I would like to repair it for a friend of mine.
                                            I have noticed that it works for few seconds then switches Off the Power_ On signal. Have disconnected boards and left maion board and power supply and still the same. The power supply with PS_ON and VA signals On stays on so it is not a problem in the power supply.
                                            Any one met this problem in the past?...
                                            10-08-2025, 07:34 AM
                                            09-07-2024, 05:50 AM
