50" Samsung Plasma (model number PS50Q91HD) - possible purchase
  • psmedley
    • Apr 2012
    • 144
    Re: 50" Samsung Plasma (model number PS50Q91HD) - possible purchase
    Planning on ordering parts tonight, will also order caps to replace the ones on board.
    Looking for suggested replacements for the Samyoung KMX series 22uf 450v cap - datasheet at https://cdn.badcaps-static.com/pdfs/...0d392625c3.pdf
    http://au.element14.com/ doesn't have a huge range of 22uf 450v - and none seem to be low ESR.
    ESR of the cap that's currently on the board is 1.42 Ohms
    • tw2005
      • Oct 2011
      • 6458
      How about RS Components? Were those Transistors part of that heatsink arrangement out of curiousity?
      I always thought generally those larger caps rarely gave troubles?
      Sounds like you'll have this running again soon.
      http://australia.rs-online.com/web/c...ons=4294881167, 4294885866, 4294884262, 4294884421,4294722838,4294726026&lastAttributeSelectedBlock=4294960519
      • psmedley
        • Apr 2012
        • 144
        Yup the two transistors that are shorted are the top two ones that you highlighted. Need to figure out how to remove them too - going to be difficult to access the screw without removing all 4x mosfets and the heatsink. (Edit: a set of pliers worked to loosen the screws)
        I'm not overly fussed if I don't replace the 22uf 450v if people think it will be OK based on the ESR of it. My reference table suggests 3 ohms for a 22uf 250v, so the 1.42 should definitely be ok for a 450v
        • tw2005
          • Oct 2011
          • 6458
          Well I was going to suggest checking those ones out first. That smoked PSU I saw when it cycled came out directly in line with that heatsink I marked. I don't have enough experience so I refrain. It's hard enough fault finding let alone giving someone bad advice. Did you compare the cap datasheets? Notice the lifespan 5000hrs compared to 10 - 12000hrs for those top branded ones.
            In addition, the top branded ones will actually have a high-end endurance (for example, they will do 12k hours at maximum temperature and ripple current), but the low end ones will struggle to do 5k under ideal conditions!
            I wouldn't worry about replacing any of the 100V, 200/250V or 450V caps.
            • psmedley
              • Apr 2012
              • 144
              another question - the existing 18N50's had thermal tape between them and the heatsink - can I use Arctic Silver CPU compound or what do people recommend?
                If it is not electrically conductive (is it?) and you spread enough to ensure isolation, then yes, but a mica/rubber pad is probably a safer option.
                • tw2005
                  • Oct 2011
                  • 6458
                  I think there's a good chance they'll need to be insulated from that heatsink. On that Panasonic I fixed they use a thin silicon pad. In fact the guy I got the TV from at work had lost it and used a cut down TO3 mica but it arced through a hole and spot welded the mosfet. He blew that set up so many times he gave it to me in disgust.LOL
                  We laugh about it now but careless mistake on our part. Maybe you could take a photo of the setup and get more opinions from some of the other experts here.
                  Just had a quick look at prices for those FETs. Pretty cheap at RS. Where are you getting your bits from?
                  I know we had a little trouble finding the one for the PANASONIC and certainly not as cheap as these.
                  Looks like there are a couple of different package designs too.
                  • psmedley
                    • Apr 2012
                    • 144
                    OK sounds like the pad is important - will see if I can find replacements, or may even reuse the old ones.
                    Looking at FETs from element14 - http://au.element14.com/fairchild-se...220/dp/1495258 $4.30 ea
                    hmmmmm I see they're quite a bit cheaper at rs - glad I didn't click the order button last night
                    Planning on ordering replacement caps too to get rid of the Samyoungs, so will reprice my order from RS and order today.
                    edit: RS out of stock/discontinued on all 5 possible 18N50's
                      You can buy small quantities of ICs as "commercial samples" from many manufacturers. Just shoot off an email and you'll usually get a discounted price too and decent shipping rates, sometimes free if you can find a sales office in Oz.
                      I had someone contact me about a similar 50" plasma "clicking on and off" - but I think I low balled them too low at £40.
                      • psmedley
                        • Apr 2012
                        • 144
                        trying to find information now on mosfet packaging - an ebay UK listing suggests replacement fets that are TO-3P packaging, but I can only find TO-220 in stock not sure what the differences - I'd imagine it's physical size/shape
                        bugger it - RS has the TO-3P's on backorder - I'd rather wait and get the right size, than order the wrong size from farnell and have to root around making it fit...
                          TO-3P is a bigger brother of TO-220.
                          Do not get TO-3 and TO-3P mixed up... TO-3P is the same as TO-247. TO-3 is a metal cased power transistor, completely different form factor.
                          You can't really substitute them anyway as a TO-3P has a lower thermal resistance, essentially this means because it is bigger it can conduct more of the heat away.
                          I had a similar blown MOSFET problem with a Pioneer plasma, but I used a compatible FET and it worked fine... (only to find it had a vertical bar on the display, so unrepairable.) I used one which was better than the original. Remember like most consumer electronics it comes down to cost, so they'll choose the minimum cost components.
                          In a quick search I found https://cdn.badcaps-static.com/pdfs/...004f1f60b9.pdf
                          On-resistance virtually the same, higher breakdown voltage and better Qg (lower.) It's only rated for 13A -but- I doubt your set would pull that much even with full white.
                          Or,
                          https://cdn.badcaps-static.com/pdfs/...5a4135ad6d.pdf - high Qg, good current rating
                          https://cdn.badcaps-static.com/pdfs/...2bb90d52a3.pdf - okay Qg
                          https://cdn.badcaps-static.com/pdfs/...7bf7bf2936.pdf - okay Qg, higher current rating, lower on-resistance
                          https://cdn.badcaps-static.com/pdfs/...4a721cfa78.pdf - lower Qg, but limited to 16A, lower on-resistance
                          Seems like Samsung really liked to choose FETs made of Unobtanium!
                          • psmedley
                            • Apr 2012
                            • 144
                            This is what I ended up ordering:
                            http://australia.rs-online.com/web/p/products/671-4777/
                            Just ordered the 2x FETS and replacement fuse for now - will order caps later once this issue is resolved.
                            Good thing about RS is they have free delivery and no minimum order value - farnell (element14) is only free delivery if you order over $A45 - otherwise it's $12.95
                            Found a Fairchild drawing of their 18N50 - the parts I removed are definitely TO-3P
                            • tw2005
                              • Oct 2011
                              • 6458
                              Hope it all goes smooth, I've only ordered once from RS but when I found out the part was coming from the UK I cancelled because I did'nt feel like waiting 2 weeks for a fuse. One of the older more experienced blokes at work has and no issues.
                              Interested in how this progresses for you, glad you sorted out what package you need. I mentioned it just in case.
                              • psmedley
                                • Apr 2012
                                • 144
                                Well given the packaging - farnell don't have a suitable replacement... So... it was either ebay from China, the US or the UK, or RS with the parts on backorder.... (and maybe from the UK)
                                Just wish Jaycar sold mosfets so I could get something today :P
                                  If it helps, I *think* this is the schematic for your PSU.
                                  • psmedley
                                    • Apr 2012
                                    • 144
                                    uggh mosfets finally arrived from RS today.
                                    Installed them, plugged in tv - yippee - only one click from psu. Went for a quick pit stop, came back and the fuse had blown and the new mosfets are shorted Turns out I'd forgotten to tighten the screws securing the mosfets to the heatsink - however I wouldn't have thought being in standby for a couple of minutes could be enough to blow them???
                                    • psmedley
                                      • Apr 2012
                                      • 144
                                      Reading http://preher-tv.blogspot.com.au/201...-clicking.html - can anyone explain how to test DS801/DS802? it has three pins - not sure how to identify which pin is what.
                                      I get ~10Ohms across the pins and reversing the red/black gives the same value - so I'm assuming they're shorted? as being a diode they should be open circuit the other way around?
                                      • retiredcaps
                                        • Apr 2010
                                        • 9271
                                        #39
                                        If the diode looks like this -><-, treat it like 2 separate diodes when testing. That is, pin -> is one diode and <- is the other.
                                        Put your multimeter in diode test mode. Measure pin 1-2, then reverse the probes. Measure pin 2-3 and then reverse the probes. You should have 4 readings in total.
                                        In diode test mode, the unit of measure is volts, not ohms. So instead of 10 ohms, you have 0.10V (10 mV). That would be a shorted diode.
                                        --- begin sig file ---
                                        --- end sig file ---
                                        • psmedley
                                          • Apr 2012
                                          • 144
                                          DS801: (first pin red, 2nd black)
                                          Pin 1-2 = 0.006v
                                          Pin 2-1 = 0.006v
                                          Pin 2-3 = 0.006v
                                          Pin 3-2 = 0.006v
                                          DS802: (first pin red, 2nd black)
                                          Pin 1-2 = 0.006v
                                          Pin 2-1 = 0.006v
                                          Pin 2-3 = 0.006v
                                          Pin 3-2 = 0.006v
                                          So given in diode mode the reverse reading should be open loop I'll say these are bad?
                                          Next question will be any tips on replacing SMD diodes???
                                          • porfyriadhs
                                            Samsung Plasma PS51D6900DS Bootloop
                                            by porfyriadhs
                                            Hello . I have a problem with a samsung plasma tv stuck in bootloop . The TV is Samsung PS51D6900DS plasma smart tv .Need help if anyone have any suggestions
                                            Thanks a lot !!
                                            10-19-2023, 11:31 AM
                                          • ArMaaN376
                                            Samsung PS51E550 Plasma TV
                                            by ArMaaN376
                                            I am having Samsung PS51E550 Plasma TV. While the TV was working, a crackling sound heard & video went off with audio still ON. After switching it off & ON, the red LED on TV blinks six times & then off.
                                            Opened TV cover & observed foll
                                            a) Green LED on the small PCB blinks at @5-6sec ON & off for 3-4 secs. Red LED on logic board ON
                                            b)Vs & Va on power supply board raises momentarily to 209v & 58v resp & then drops.
                                            c) Cold test on Y-main board shows all 3 pins of FGPF4536 IGBT short to Grnd.
                                            How to confirm Y -Buffer board...
                                            06-19-2024, 04:05 AM
                                          • CDNBrewer
                                            Samsung Plasma PN43D450A2D No Power
                                            by CDNBrewer
                                            Hello, I have a Samsung Plasma TV - Model # PN43D450A2D
                                            This was my parents TV and the initial symptoms were that the display was hard to turn on with the display making various clicking noises until one day it would not turn on anymore.
                                            I took a look and found a couple 1000uF capacitors (i believe on the low voltage size) that had leaked out their electrolyte and did not test well on a tester. I replaced them but still no dice.
                                            When the TV is plugged in, there is no clicking, LED status lights (on PCB boards or the front display) and the power on button...
                                            03-02-2025, 04:59 PM
                                          • alltvrepairs
                                            Plasma Samsung PS-50C96HD Main board BN94-01223C switches off supply after few seconds
                                            by alltvrepairs
                                            I have this almost brand new Plasma was well stored. I would like to repair it for a friend of mine.
                                            I have noticed that it works for few seconds then switches Off the Power_ On signal. Have disconnected boards and left maion board and power supply and still the same. The power supply with PS_ON and VA signals On stays on so it is not a problem in the power supply.
                                            Any one met this problem in the past?...
                                            10-08-2025, 07:34 AM
                                            09-07-2024, 05:50 AM
