LG plasma 42PC1DA Half left screen
  • Cailloux
    • Feb 2012
    • 26
    Hello, I need your technical assistance.
    I have a LG plasma TV 42PC1DA defective.
    Symptom: No picture on the left side of the screen, right side picture perfect.
    What I did, replaced the control board & the XR board.
    Replaced the cables. Checked the DC supply, +5 V and Va on the XR board, correct voltage, checked fuses. Same problem.
    Is it possible that the main board is faulty?
    Thank you.
    Re: LG plasma 42PC1DA Half left screen
    Reseat the cable for the XL buffer.
    Or replace the XL buffer.
    Does your TV suffer from the dreaded "sparkles" problem? (Flickering green, red and sometimes blue pixels in the corners of the screen, visible in darker portions.)
    • Cailloux
      • Feb 2012
      • 26
      Hello, on the front left side, half the screen in dim light, with red sparkling, but more in the center bottom. Sparkling also appears on the right side of the screen.
      At the back of the TV, the XR board is on the right side.
        The sparkling is an unrelated symptom, but it will get worse over time. LG released a software patch for the control board to fix this problem but it requires someone with the right control jig (expensive.) I think there is a member on these forums who does program these boards for a small fee.
        I think the problem is more likely to be XL because it's on the left hand side of the screen, but I'm not sure if the labelling is from the back or the front of the TV. Either way, consider replacing the X buffer for the failed side of the screen.
        • Cailloux
          • Feb 2012
          • 26
          I have already replaced X board, labeling XR for the left side.
            Check the control cable from the buffer to the control board is correctly seated.
            • Cailloux
              • Feb 2012
              • 26
              Problem solved. Faulty screen, right side (rear view), burn spot on all COF (chip on flexible cable).
              I do not know the reason, the circuit XR is in good condition, nothing to suspect.
                Possibly a failure in the XR board damaged the panel COFs. It is sad that the COF are not replaceable and failures condemn the panel.
                • Cailloux
                  • Feb 2012
                  • 26
                  Fortunately I had a TV 42PC3D, plasma screen is the same as 42PC1DA. So I transferred all the boards on the other screen.
                    What did you do with the old plasma panel? There's a guy on YouTube who blows up bad panels with a microwave transformer. Work of art until the panel cracks!
                    • Zelek11
                      Panasonic Plasma screen interference on left half of screen
                      by Zelek11
                      My Panasonic Plasma model P55VT50 has started displaying "interference" on just the left half of the screen only (left when facing the screen). Sometimes it's concentrated in about the first 30 seconds after startup, then disappears. Other times it's fine at startup and then randomly does it later on. When it flashes the interference it's very quick and doesn't stay on the screen unless it flashes repeatedly in a row.
                      This image is a screen shot from a video I took. This is an example of the interference at its worst. Often the interference is much smaller...
                      10-14-2022, 04:54 PM
                    • armoured_smiler
                      Panasonic Tx-40cx400b top left half screen not displaying correct
                      by armoured_smiler
                      Trying to work out if this is TFT problem or TCon issue.
                      The TV powers up but the top half of the screen, from the right it is OK, but as you look across to the left halfway across it starts get duller and duller until it is very dark on the lefthand side, currently I trying to clean the remote as it seems to have something film wise on the pads stopping it from registering buttons pressed.
                      Also when changing the screen size of Windows PC display to say to a smaller pixel sizewindow, the original window displayin the top left stays/takes a few seconds to disappear?...
                      04-08-2024, 03:40 PM
                    • Chrissygizmo
                      by Chrissygizmo
                      02-10-2025, 12:33 AM
                    • Ryan.man
                      by Ryan.man
                      02-04-2025, 12:23 PM
                    • ravi_1617
                      HCL Laptop SCREEN SIZE SHRINK LEFT SIDE AROUND 2 INCHES
                      by ravi_1617
                      Hello to all ,
                      I have this HCL ME LAPTOP K 41 ,screen image is shrieked clock /speaker left side approx. 2 inches .Its 14.1 LCD SCREEN. I have replaced lcd screen ,found no difference
                      Its blank that area blank and bottom of Task bar is rolled at bottom displaying top portion image . In bios /setup also getting same problem
                      on external VGA port image is perfect /normal , Attached image...
                      07-25-2025, 12:07 AM
