Magnavox 26MF605W/17
  • rickybennett
    • Jun 2012
    • 26
    • usa
    i have a magnavox 26MF605W/17 lcd hdtv it has 4 bulging caps and one blown cap
    i found this caps do you thank this would work good in it ??
    http://www.parts-express.com/pe/psho...0-1738&scqty=2
    http://www.parts-express.com/pe/psho...0-1740&scqty=1
    http://www.parts-express.com/pe/psho...0-1750&scqty=2
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: new hear need some help please
    Don't use lelon caps unless you want to repeat the recap again.
    The caps you need can be found at the badcaps.net store and are of much better quality. be sure to replace all of the bad branded caps.
    Another note- please do not use offsite images... attach them to the post instead using "manage attachments".
    (also moving the thread and fixing the title).
    sigpic
    (Insert witty quote here)
      Re: Magnavox 26MF605W/17
      I would get PANASONIC caps FM/FC/FR series from Digikey instead. They should be low ESR type.
      http://search.digikey.com/us/en/cat/...panasonic%20FM
      • rickybennett
        • Jun 2012
        • 26
        • usa
        so what about these??
        http://www.digikey.com/product-detai...2384-ND/613745
        http://www.digikey.com/product-detai...2405-ND/613766
        http://www.digikey.com/product-detai...2379-ND/613740
        • retiredcaps
          • Apr 2010
          • 9271
          Assuming the height and diameter fit your board, the above will work fine.
          --- begin sig file ---
          --- end sig file ---
          • rickybennett
            • Jun 2012
            • 26
            • usa
            will it make a difference if they are a little bigger or smaller other then not fitting in the space it needs to go in if it is to big
            • ratdude747
              Black Sheep
              • Nov 2008
              • 17136
              Not really. Other than mostly negligible differences in ESR, can size doesn't matter that much.
              (Normally I would suggest supporting the forum and buying the caps here, but Topcat doesn't carry 2200uf 25V caps at this time).
              sigpic
              • rickybennett
                • Jun 2012
                • 26
                • usa
                is the ohms ratings important suss i have know idea what the ohms rating is on the old ones is ??
                • psmedley
                  • Apr 2012
                  • 144
                  the lower the ohms rating the better...
                  • rickybennett
                    • Jun 2012
                    • 26
                    • usa
                    ok my next question is how do you figure out the exact size of them ?? sorry for the dumb question im bad at math
                      Ruler? Calipers?
                      • psmedley
                        • Apr 2012
                        • 144
                        physical size or capacitance (uf) and voltage?
                        for physical size - a ruler or vernier calipers - for capacitance/voltage - read the values off the old caps
                        • rickybennett
                          • Jun 2012
                          • 26
                          • usa
                          sorry i have not been back my stupid internet has been out
                          any ways i got the caps and installed them and my tv is working good now thank you for the help
                          the 2200uf was a little longer but it works good
                            Glad to hear! Another one saved from the dump...
                              by momaka
                              03-12-2025, 03:42 PM
                            • eryjus
                              by eryjus
                              05-10-2023, 11:21 AM
                            • Paxman_Swede
                              by Paxman_Swede
                              Hello!
                              01-14-2025, 09:51 AM
                            • captain150
                              by captain150
                              03-16-2025, 07:34 PM
                            • Foetuss
                              Gigabyte GA-6OXT :: caps question
                              by Foetuss
                              Good evening
                              I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
                              Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
                              But I was also suprised about the bigger boys, which are 330µF 25V.
                              Could it be they used 25V caps because they were cheaper / available at that time?...
                              02-11-2025, 12:22 PM
