Samsung Plasma -no picture/sound -just clicks
  • Cornboats
    Dave
    • Oct 2010
    • 232
    Samsung 42SD 5SD plasma 42"
    No picture or sound. Turn it on, clicks and the neon flashes 5 times and then goes off. re-cycles until you turn off at mains.
    It did have picture and sound but had vertical lines and occasional horizontal dashes. I never got to the bottom of the first fault before the second one took over.
    I've disconnected Z-sus and Y-sus boards 1 at a time but no difference.
    Va and Vs voltages as per label.
    Where do I go from here?
    Anyone offer any adivice-it would be welcome.
  • randtek
    • Oct 2011
    • 280
    • US
    Re: Samsung Plasma -no picture/sound -just clicks
    Here's a trick that may help you. It will immediately tell you if you have a main board problem, or a panel drive board failure.
    1) Unplug the TV from AC.
    2) Disconnect the power supply cable going to the main board at the main board end.
    3) Look at the legend on the power supply board to determine which pin is PS-ON, usually pin 1. Stick a wire in this pin of the connector cable you disconnected from the main board, and short it to ground.
    4)Disconnect the LVDS cable going from the main to the Digital board.
    5) On the digital board find 4 test point pins sticking up from the board in a square pattern, about 1/8" across. Short these pins together.
    6) Plug the unit in to AC.
    This process will generate test patterns from the digital board. If you see the test patterns begin to cycle on the screen, you know everything is working properly except your main board. If you do not see the test patterns, you have an issue in the panel drive circuitry.
    • noahc72
      • May 2012
      • 63
      I had the same problem with my Samsung PN58. Changing the main board fixed the cycling problem on mine, although now I have a different problem.
      Haven't tried this test pattern trick yet, but I will try it later today.
      • Cornboats
        Dave
        • Oct 2010
        • 232
        Thanks for your test tip.
        I'm a bit confused so I'm checking as I don't want to blow the boards up.
        The main board your refering to is referred to in Samsung manual as Video board.
        PS-ON is pin no 7 on CN810. This block goes from main smps to digital board not the video board.
        So I'm not disconnecting any cables from the video board only the digital board and the the LVDS which connects the video board to the digital board?
        theres a strip of 7 pins in a row,
        6 pins in 3 doubles ( 2 pairs are jumpered)
        4 pins in 2 doubles (1 pair is jumpered)
        The last on above is the one I want I reckon.
        As pins 1 and 2 are already jumpered I'll just jumper 3-4.
        • TR103
          by TR103
          - it keeps rebooting
          01-22-2025, 04:12 PM
        • Mgiffune
          by Mgiffune
          06-09-2024, 10:28 AM
        • Ierwin
          by Ierwin
          05-13-2025, 03:31 PM
        • jchang
          Samsung UN70NU6900F no picture and no sound
          by jchang
          Hi all
          I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
          Symptom:
          No picture no sound.
          When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
          No sound at all.
          What I tried:
          1. I tried unplugging the left or right ribbon...
          01-09-2023, 06:28 PM
        • Dodgethis
          Samsung QN75Q6DRA, No Picture, Has BL, and Sound
          by Dodgethis
          Hello all,
          This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
          09-11-2024, 07:39 AM
