capacitor with no esr value
  • 1supertech
    • Apr 2012
    • 384
    Re: capacitor with no esr value
    Originally posted by 1supertech
    Update on my original post. I received my 47uf 50v cap and installed it, very encouraging when I saw the display light up now to put it back together and hook it up to my satellite. hope it works.
    New update all hooked up all I get is white screen I assume that's the back light. Well I think that's an improvement so far. any more Ideas would be appreciated.
      Check the cable from main board to T-con is properly seated.
      • 1supertech
        • Apr 2012
        • 384
        As I re seated tcon cable and re assembled all the wires I turned it on and nothing no display untill I unplugged a cable form power supply to mainboard
        here is a picture. Ihave no Idea where to check for know help.
          Do you have a multimeter? I assume since you have an ESR meter you will have one... Check the voltage on each of the pins going to the main board. I think this is a Harwa chassis - the wall mount bracket looks familiar.
          • 1supertech
            • Apr 2012
            • 384
            When checking voltage I am a real newbee can you explain how? to do so
            Thanks Jack
              Thanks Jack
              Place the black probe in a spare screw hole of the chassis, this is your ground.
              The red probe then goes on each voltage you want to measure. For the pins, you can apply a small amount of pressure to make contact with the metal surround in the connector.
              Set your meter to DC 20V, if it is manually ranging. If it is autoranging, use volts or DC volts, whichever is available.
              Repeat for each pin, noting down the voltage... don't round down report the exact value. If they fluctuate or change note this.
              • 1supertech
                • Apr 2012
                • 384
                Is this with power plugged in to wall ?
                Now am I checking voltage with wires plugged in power supply and to main board ? I am checking voltage on the mainboard side.
                  Yep. Be careful not to touch any of the heatsinks on the power supply. In the US, they can be at half supply voltage, or about 60VAC, which can give a nasty tingle.
                  • 1supertech
                    • Apr 2012
                    • 384
                    from bottom up pin3) 019.0
                    2)3.212
                    1) 000.4
                    • 1supertech
                      • Apr 2012
                      • 384
                      I decided to take a second volt reading form out of powersupply
                      pin 3)005.7
                      pin 2) 3.196
                      pin 1) 0441
                      • 1supertech
                        • Apr 2012
                        • 384
                        Here is a photo cap goes where the red mark is
                        Have a short circuit in wiring, if some on can follow this thread and help
                        me out I would greatly appreciate it
                        I have voltage reading with images
                        thanks
                          Does the power supply have any labelling near the connector indicating that is 3.3V output or something else? Are there any more outputs?
                          • 1supertech
                            • Apr 2012
                            • 384
                            No but here is a pic of connectors
                            • 1supertech
                              • Apr 2012
                              • 384
                              checking voltage form power supply at the problem connection starting at the top
                              I get
                              0.431
                              3.044
                              0.161
                              At the mainboard I get
                              004.5
                              3.288
                              005.0
                              I am assuming if a connection gets current from both ends that would be a short
                                What does 24V measure at?
                                • 1supertech
                                  • Apr 2012
                                  • 384
                                  QUOTE=tom66;242733]What does 24V measure at?[/QUOTE]
                                  First connector from right
                                  012.3
                                  012.3
                                  012.3
                                  23.36
                                  23.36
                                  second connector
                                  23.37
                                  23.37
                                  23.37
                                  01.08
                                  011.4
                                  011.9
                                  011.4
                                  011.3
                                  3.041
                                  04.31
                                  Third
                                  32.66
                                  010.1
                                  3.280
                                  010.3
                                  010.5
                                  11.59
                                  11.59
                                  010.08
                                  05.19
                                  010.7
                                  08.96
                                  • 1supertech
                                    • Apr 2012
                                    • 384
                                    I have a feeling that main board has a short I have checked all caps and they have good Esr values about .25 ohms
                                    Fuses on power supply test good all caps are good
                                    I have no idea what else to check
                                    • 1supertech
                                      • Apr 2012
                                      • 384
                                      Thought I would uplaod larger pics
                                      • 1supertech
                                        • Apr 2012
                                        • 384
                                        larger pics
                                        • 1supertech
                                          • Apr 2012
                                          • 384
                                          More images
                                          Finally got are hope they are large enough
                                          • MORETTIGIAN
                                            Capacitor detached from PCB – RTX 2070 Super Founders Edition
                                            by MORETTIGIAN
                                            Title:
                                            Description:
                                            During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
                                            I did not notice it detaching, so I am unsure of its original location on the PCB.
                                            Procedure performed:
                                            - Removed backplate
                                            - Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
                                            - Reapplied thermal compound
                                            - Reassembled card
                                            Observed behavior after reassembly:
                                            - GPU powers on and operates normally under...
                                            09-18-2025, 12:14 PM
                                          • devsigner
                                            identify capacitor for MacBook Pro with rare logic board 820-02037-06
                                            by devsigner
                                            Hi
                                            While messing around with my MacBook Pro, I stupidly pinged off a very small surface mounted component that I’m now trying to identify.
                                            resistance tests show a rising resistance value, indicating a capacitor.
                                            The laptop boots up and runs, however I'm choosing not to use it until I get it fixed.
                                            i can’t see any markings on the capacitor at 10x magnification using a professional jewler's loop.
                                            It seems like there's some damage to the capacitor - one side doesn't have "shiny bits" - can you tell I don't do this for a living!...
                                            Today, 01:39 PM
                                          • Prolog
                                            RTX 3080 FE Identifying capacitor
                                            by Prolog
                                            Hi people, I hope this is the correct spot to post this, I'm new to the forum.
                                            I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
                                            I hope these photos make it clear which component I am referring to:
                                            (yes, the soldering is a bit botched from removing the blown one, I know)
                                            I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
                                            12-01-2024, 08:27 PM
                                          • Agent24
                                            Dick Smith Q-1760 linear power supply filter capacitor question
                                            by Agent24
                                            I have acquired a used Dick Smith Q-1760 power supply - although the OEM is Manson Industrial
                                            It has at least one problem.
                                            The voltage control potentiometer VR2, 50K is faulty - going high resistance / open circuit in the CCW end and leading to the output voltage jumping around.
                                            I have already ordered a replacement potentiometer, so that's not an issue.
                                            Now, I want to replace all three electrolytics on the PCB as they are CapXon and I don't trust them so much, I will replace them with something better while I've got the thing apart anyway.
                                            All are CapXon...
                                            10-21-2025, 05:39 PM
                                          • chth96
                                            If I replace with inferior capacitor, Is it No harm to other IC components at all?
                                            by chth96
                                            I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
                                            Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
                                            It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
                                            So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
                                            I know that these capacitor will not last as long as nichicon capacitor...
                                            12-22-2023, 04:34 AM
