RCA L37wd12
  • dhack61
    • Aug 2010
    • 33
    RCA L37wd12
    Having a problem with voltage drop going from SMPS 1W to the Scaler board. Unplugged from the scaler I have 5.3v standby on the SMPS 1w going out. As soon as I plug the scaler back up the standby voltage drops to 3.6.
    Any Ideas?
    Dhack
    Re: RCA L37wd12
    Please post good clear pictures of the boards using attachment so we can see how all the boards are connected together.
      Re: RCA L37wd12
      Some of these newer low power TVs change the standby voltage to a lower voltage in standby to reduce the power dissipation in standby mode, to help meet Blue Angel/Energy Star requirements. Is there a control signal on the PSU that might indicate this?
      • dhack61
        • Aug 2010
        • 33
        Re: RCA L37wd12
        Here is a copy of the interconnect Dia from the service manual. Its marked L32wd12 but its the same for both sets.
        The Voltage chart shows that 5.3v should be coming in to the scaler board.
        Dhack
          Re: RCA L37wd12
          Can you get hold of a 10 ohm 5W resistor?
          I do see a signal "PO" going to the 1W board. Can you post a picture of this 1W board?
            Re: RCA L37wd12
            I see, it has the same setup as the 26" version that I worked on years ago, the PO is the power on signal to turn on the relay on the main inlet board which supply 120vac to the input of the SMPS board.
            http://s807.photobucket.com/albums/y...RCA%20L26WD12/
            This one had bad main board, the relay click but no other action happen, then 6 months later, the inverter boards went out. After repalceing boards, the TV is still runing for 3 years now.
            • dhack61
              • Aug 2010
              • 33
              Re: RCA L37wd12
              That's pretty much the same set on smaller. I am not getting the click to start the 120V on the main SMPS. You said the main board was out. do you mean the Scaler board?
              • dhack61
                • Aug 2010
                • 33
                Re: RCA L37wd12
                Don't have a camera charged but I do have the Schematic for the board. If you still need a picture let me know.
                  Re: RCA L37wd12
                  Doesn't look like the PSU adjusts voltage in standby, so it's either a main board loading down the PSU too much or a problem with the PSU.
                  Potential causes with PSU:
                  - CP616 main output cap 470u
                  - CP613 Vcc cap
                  - RP613 Vcc run-charge resistor and;
                  - DP617 diode
                  - DP601 relay diode (rare, unexpected but don't eliminate it - maybe it's shorting PSU when PO turns on...)
                  Potential problem with main board is a shorted or low resistance component.
                  If you can get that 10 ohm resistor the main board can be eliminated if the power supply drops under load. Troubleshooting PSUs is much easier than main boards.
                  • lazuras
                    • Oct 2012
                    • u.s
                    Re: RCA L37wd12
                    i have a L32WD12 the power supply looks similar to the one shown here . my question is im changing the capacitors on them i change the three larger ones but i donot or cannot read or understand what the smaller three are. hopefully it will work. right know my tv turns on red light but thats it then turns off. i here a click . then off . and sometimes when it turns on still a red light but flickers.
                    • tvguy12012012120
                      by tvguy12012012120
                      02-07-2025, 05:13 PM
                    • fharris1977
                      Vizio D50u-D1 Dead Set No Standby
                      by fharris1977
                      Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
                      12-28-2023, 10:25 AM
                    • dkneyle
                      Onkyo DX-V500 Laser Disc Player - weird SMPS fault
                      by dkneyle
                      This relic from a technology path that came to a dead end (but still has historical interest) was brought in with a dead SMPS, which is based around a MK1210 device. I got it going after a battle. It seems to have a strange design - if it's not getting feedback that the secondary is OK it cause the big FET to go into full conduction and overloads resulting in a blown fuse at best or something worse! I'm using a Dim Bulb Tester (70W/230V) which thankfully has saved the day a number of times whilst repairing.
                      Now, it loads a CD OK. The motor voltage output (which is built onto the SMPS...
                      02-01-2022, 02:08 AM
                    • shamsudeen
                      Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                      by shamsudeen
                      Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                      I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                      i know that in linear power supply the noise will be very low comparing to SMPS supply....
                      07-19-2025, 07:14 AM
                    • eigma
                      Samsung UN40H5003 boot loop every ~8 seconds
                      by eigma
                      Hi, I rescued a Samsung UN40H5003AF (H = 2014 FHD) from the curb. Symptoms are: standby (red) light comes on, stays on for 8 seconds, flickers off, then comes back on, and the cycle continues.
                      Service manual: https://www.electronica-pt.com/esque...is-u8la-71272/
                      SMPS board: checked voltages, all seem normal (A13V = 12.8V, UD = 3.3V, PWM_BLU = 0.77V, PS_OnOff = 5.5V). Remove 10p cable to main board -> backlight comes on. I think this means SMPS board and backlight are good.
                      Main board: BN94-07592P / BN97-08922R...
                      11-20-2024, 10:31 PM
