anyone know of a source for mp2361d. used on digital board in hitachi set. pin 5 and 10 are shorted. switch to ground pins. thanks dewey
any body have a parts source in us for mp2361d
Re: any body have a parts source in us for mp2361d
You could try the manufacturer?
https://www.monolithicpower.com/Page...sContacts.aspx
They have 3 distributors listed for SC (only 1 has a website) and mouser who are on 8 weeks. You can of course go out of state.Please upload pictures using attachment function when ask for help on the repair
by LvsitanoI am having some trouble with troubleshooting a Asus X532FL rev 2.0 motherboard, which does not power on. So at the first MOSFET, I am getting 19V at the drain, and then 3.2V on both gate and source (compared with ground). Of course, the 2nd MOSFET's source will have 3.2v at source.
First MOSFET is a QM3056M6 and 2nd MOSFET is a QM0930M3
I already checked first MOSFET and source and gate are not shorted (drain with source not shorted either). Also I have 1.7V at the LDO rail (measured at the keyboard connector, as the power button is on the keyboard).
First... -
Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
The TV was stuck on the logo and I couldn't access the update menu.
I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
The image result was good, but the image is inverted.
The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in... -
by wolf1976hi
i have the above tv and the display starts distorts the display at only in applications like you tube
after and on the didital channels
now without connect the antenna only the image of itsselfs tv i have the image i have in attach
i have read in another forum someone else with similar problem with mine changes tcon card and motherboard and the problem remains
can you tell me someone what is the reason that can causes that problem ? is the same the sisplay ?... -
by 2elwHey, I find it very absurd that the SVOD4 costs so much and has zero documentation. I had no other choice than to buy it to unlock ECs, if there was any documentation or firmware avalible I could've made it or something simmilar. Anyways here are some of the most important parts:
STM32H723VGT6 MCU - It's a microcontroller by STMicroelectronics and its the whole brain of the SVOD4. It has flash memory for the firmware which can be updated by the SVOD4 program. Its also powered by the AMS117 which converts 5v into 3.3V. 7€ on AliExpress.
GW1N-UV9UG169C6/I5 FPGA - Its a...07-04-2025, 12:23 PM -
I recently found myself the proud owner of a later-model Samsung plasma (the PN59D7000 for those keeping score at home) whose panel was, unfortunately, damaged in transport. I'm now preparing to part it out, but am curious as to whether or not any damage would have come to any of the components by attempting to power it up with the panel being broken. I read in one Avsforum thread (for whatever that's worth 😂) that the "scan driver boards" (by which I assume he means buffer boards) could be impacted by doing so. Is that actually the case? If so, since I don't intend on selling bad...
- Loading...
