Samsung LE-46M86BD Picture Issues
  • Jasgriff
    • Feb 2012
    • 578
    Just picked up this this TV.
    The reported issues were lines down the left hand side of the screen and no sound.
    I have plugged it in and can see the lines down the left hand side of the screen. As you can see in the picture though the whole screen seems to be ghosting and suffering from interference.
    It also looks like when you push on the screen some of the interference goes but the lines and the ghosting remains.
    I am going to have the back off shortly to try and reseat the cables and see if that has any effect.
    Fixed so far : 1 Home cinema system, 16 LCD Monitors, 4 LCD TV's
    How to resize your pictures guide click HERE
    Retiredcaps Ideal post example click HERE
    Re: Samsung LE-46M86BD Picture Issues
    Looks a lot like a T-con problem. The ghosting is probably caused by insufficient OFF voltage, which is used to turn off the pixels in the LCD. Budm might be able to help here.
    To eliminate the main board and cabling (to T-con), you can try the trick of changing the LVDS format.
    • retiredcaps
      • Apr 2010
      • 9271
      momaka discusses t-con troubleshooting for a LCD monitor (post #13 - different problem), but the principle should be the same for a LCD TV.
      https://www.badcaps.net/forum/showthread.php?t=17904
      --- begin sig file ---
      --- end sig file ---
      • Jasgriff
        • Feb 2012
        • 578
        Yeah I looked in the menu but couldn't find the LVDS option I will get back into the menu and see if I can find it. I have found out why there is not sound.... Someone has removed the speakers! There were also some wedges in the top of the screen so someone has tried to remove the ghosting with them.
        Looks like I have a right dog here.
          I have some spare speakers for a few TVs if you are interested.
          • Jasgriff
            • Feb 2012
            • 578
            If I can get the picture sorted then I will definitely be interested. just going to clean the ribbons and then try again. IF not then I will get back into the service menu. Hopefully all before tea arrives
            • Jasgriff
              • Feb 2012
              • 578
              I will have a read through this also.
              • cashkennedy
                • Aug 2011
                • 666
                Jeez no one mentioned this yet????
                46 and 52" samsungs and sonys > from 2008-2010 , samsung brand panels
                These all get tab bonding issues where you get a darker picture and ghosting. usually its the top left tab and pressing on it, or twisting the whole tv will fix the picture. The wedges were probably an attempt to fix tab bonding issues, but they could have put too much pressure and missaligned the tab at the top > causing your lines.
                This is generally not fixable.
                Fixed so far 12 lcd's , 1 plasmas, 5 monitors, 0 dlp's (plan to keep the dlps at 0). and 3 atx power supplies, and 2 motherboards.
                • Jasgriff
                  • Feb 2012
                  • 578
                  I thought it might have had something to do with the tab bondings.
                  twisting makes it better but does not cure it. I assume they have damaged it. Oh well I am sure I can get something back for the T-com, main board, power supply and inverter boards.
                    If possible can you save the diffuser sheets from the LCD panel in case someone, or myself, needs them to repair mura?
                    • Jasgriff
                      • Feb 2012
                      • 578
                      yeah can do.
                      Im gutted that I managed to get rid of the black lines by playing with the tab bond but then when I put it all back together it resulted in a solid thick black line.
                      • Jasgriff
                        • Feb 2012
                        • 578
                        diffuser sheets are out. I will try and find something to store them in.
                          You can probably roll them up and store them in a cardboard tube. How many were there? There is usually a light guide plate (thick 2mm-3mm plastic), a prism film or two (very effectively amplifies light), and a few diffuser sheets. Cheaper LCDs omit a few diffuser sheets and the prism film. You can probably get rid of the light guide plate. It's a nice lens though.
                          • retiredcaps
                            • Apr 2010
                            • 9271
                            2 hours of soldering yesterday even with a fan blowing doesn't help my brain function.
                            At least I got one power supply recapped and got a few spare components from desoldering something else.
                            • Jasgriff
                              • Feb 2012
                              • 578
                              You seem to have a few bits to work on recently!
                              Tom,
                              I have kept the sheets and will try to get a tube to store them in ready for shipping if needed. I will also try and pick up something to fix whilst dumping the remainders of this tv.
                                09-07-2024, 05:50 AM
                              • TR103
                                by TR103
                                - it keeps rebooting
                                01-22-2025, 04:12 PM
                              • JJAAMM
                                by JJAAMM
                                Problem
                                07-06-2023, 06:01 AM
                              • Mgiffune
                                by Mgiffune
                                06-09-2024, 10:28 AM
                              • Dodgethis
                                Samsung QN75Q6DRA, No Picture, Has BL, and Sound
                                by Dodgethis
                                Hello all,
                                This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
                                09-11-2024, 07:39 AM
