anyone familar with pn50a550s1fxa power supply? i have two bad diodes heatsink mounted.ds824 and ds825. i have no luck with the schematic or service manual. plenty of hits on reviews. long story but previous owner states dog gnawed thru power cord and after replacing cord it was dead.can post pic but there appears to be no physical damage but the diodes are shorted. they have weird numbers and i cant cross them to anything.
samsung pn50a550s1fxa power supply
Re: samsung pn50a550s1fxa power supply
Whereabouts on PSU are they? Primary/Hot or Secondary/Cold side?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search. -
Can you trace what voltage output they are on? What are the markings on the diodes?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
100V 30A Dual Schottky diode probably. You can't follow the usually labelled power outputs to find what output they are on?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
And they go into some caps... which have a voltage rating of XYZ... (maybe through an inductor... and then some caps which have a voltage rating of XYZ...) and then into a connector... which has a labelled voltage of XYZ...
Replace "XYZ" with appropriate values.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
i just got it running, its a temp job to see if anything else was fried. good news is she is 100%.took two 5amp 1000v switching diodes and made one the other came out of an old computer supply. gonna try and order diodes tomorrow morning. thanks, guess i was looking for an easy way out.Comment
Try 300V fast recovery 10A like this.
http://search.digikey.com/us/en/prod...WGI-ND/1147822Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
time to update this a bit, finally found a pair of diodes that work, they need to be insulated from the heatsink though. they are available at mouser electronics, so far with these no problems.mur1620ctrg is com dual anode andmur1620ctg common dual cathode. these are 16 amp 200v original was 10 at 200v.so far they are doing the job. I used the silicone type pads instead of mica for insulators.Comment
Do you think mur1620ctg will work as the FCU10UC30 replacement if the rectified voltage is 202v?
I'm currently looking at these SDURF2030CT https://www.digikey.com/scripts/DkSe...17855932124438
A bit higher recovery time but overall good matchLast edited by zape; 09-23-2017, 04:49 PM.Comment
Assuming...7 Photos -
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... -
by sam_sam_samI have been working on this concept for quite some time now with limited success but recently I found a switching power supply that is setup for the voltage that this soldering station needs to operate at however it also needs part of the secondary circuit from the original switching power because you need several voltage rails
I once tried to get a ZD-915 desoldering station to work on a 18 volt battery power supply but unfortunately things did not go well but I did find a work around but I might try this idea again but going at a little differently more about this another time... -
by cheeky2This Samsung combined power supply and inverter was replaced a while ago from a Samsung 37inch LE37B530P7W TV. However I would like to repair this one.
I have replaced the Mosfets Q1820 and Q1821 ( FDPF7N50U) which were both blown and the fuse FM802S. The schematic for this power supply that is attached doesn't relate to this power supply as the driving transistors and diodes are D1830, D1831, D1832, D1833, Q1811 & Q1810 are nowhere on the schematic!
Does anyone know what the components for D1830, D1831, D1832, D1833, Q1811 & Q1810 should be? I ask as I did change the Mosfets... -
by JimBanvilleThe sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
Opened it up and discovered the power supply is making a faint clicking or ticking sound.
I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...-
- Loading...
