Hey everyone I am new to this so please bare with me. So a little background. I received this TV from a co-worker that was just going to throw it away so I decided to take it and try and fix.
Symptoms: I plug in the TV and the Vizio symbol turns Amber. I press the power and the Vizio light turns white. The backlight comes on and about 2 seconds later the backlight goes out and the Vizio light stays white.
I looked over the board and did not see and obvious blow caps. So I tried to read up on what to test and this is where Im at.
Attached are the photos that I took:
Entire assembly with covers off
Power Board
Main Board
Audio Board
And one other board I dont know (the one in the upper left of the full image) and help please.
So some basic testing I have done:
Once the TV is on no backlight and white Vizio symbol I took these readings:
The main cable from Power Board to Main Board
1: PS On/Off
2,3,4: 12v
5,6,7,8,9: Ground
10,11,12:5v
13: Dim
14:Inv On/Off
15:VBRA
So I took readings going into main board and they are as follows:
2,3,4: 11.68v
10,11,12: 5.07v
14:1.06v
*when power button is pressed it spikes to 3.28
15: 4.30v
Power Board to Audio Board:
24.06v over both wires.
From this it seems that the power board is working.
Next I have read through many threads trying to learn so I took some other readings of:
u16, u45 which are AZ7805T-E1 825D16
and
u19,u21,u22,u15 which are L032 G1117
How I tested I used black probe on TV ground/screw and then red probe on each post. Hopefully I did it right please correct me so I can learn.
u16:
vI:2.81v
G:.01v
vO:1.47v
u45
vI:3.24v
G:.03v
vO:2.08
Tested these same black probe on ground/screw and red probe on post left to right (1,2,3)
u15:
1: 2.06v
2: 3.30v
3: 4.99v
u19:
1: 1.26v
2: 2.50v
3: 4.98v
u21:
1: 0.0v
2: 1.24v
3: 3.31v
u22:
1: 4.92v
2: 3.30v
3: 2.06v
I also took readings for u33, since that seems to be a commong issue with Vizio Tv's
I did the same test black probe to screw and red probe to left side posts.
Diagram:
5678
1234
1: 4.91v
2: 4.91v
3: 4.92v
4: 4.93v
Now to test 5-8 I connected Red probe to 4 and then black on each post 5-8.
voltages remained same.
4,8: 4.93v
4,7: 4.93v
4,6: 4.93v
4,5: 4.93v
I am new to this so I could have taken those wrong but like I stated above I want to learn. So anyone that can assist me and help me get this TV fixed would be great.
Sorry for the wall of text but everything is fresh in my mind so I wanted to get it all down.
Let me know what my next step is or if you have seen this issue please let me know. Also let me know if I am missing something that you need to assist
Power Board
Main Board
Audio Board
1: PS On/Off
2,3,4: 12v
5,6,7,8,9: Ground
10,11,12:5v
13: Dim
14:Inv On/Off
15:VBRA
2,3,4: 11.68v
10,11,12: 5.07v
14:1.06v
15: 4.30v
and
u16:
vI:2.81v
G:.01v
vO:1.47v
u45
vI:3.24v
G:.03v
vO:2.08
u15:
1: 2.06v
2: 3.30v
3: 4.99v
u19:
1: 1.26v
2: 2.50v
3: 4.98v
u21:
1: 0.0v
2: 1.24v
3: 3.31v
u22:
1: 4.92v
2: 3.30v
3: 2.06v
Diagram:
5678
1234
1: 4.91v
2: 4.91v
3: 4.92v
4: 4.93v
4,8: 4.93v
4,7: 4.93v
4,6: 4.93v
4,5: 4.93v
