Re: Instruments/tools needed for TV repair
BK Precision just rebadge cheap crap from China - I'd avoid after seeing inside some of their analog scope offerings.
Theres a oscilloscope localy on craigslist
http://batonrouge.craigslist.org/tls/3000267272.html
I probably wont get it unless someone here knows that model (BK Precision model 2125) is a really good, amazing oscilloscope.Leave a comment:
That is the trace, the copper lines between components.Leave a comment:
What exactly is the trace? Isn't the trace the lines on the board under the green sheet that connect the components?Main thing about soldering iron, you need 40~60 watts capacity, low wattage will not hold up the heat well when the tip make contact with what you are trying to solder, especially when you try to solder the board with large copper area, it will suck the heat from the iron and you will end up lifting the trace because you will be waiting for the temperature of the tip to recover.
I have heard several times people say don't overheat the board or you'll damage the trace, but I never understood what the trace actually was.
I use a 30watt iron to desolder with a solder sucker, it works fairly well as long as I tin and clean it right before using it.Leave a comment:
Thank you, I will remove them.Leave a comment:
If you are measuring two in parallel, you expect to get around 2000uF +/-20%. ESR will also be in parallel so the caps could have 0.18 ohms each or in the extreme 0.09 ohms and 100 ohms.) You should remove capacitors to get a definitive answer.I have got Mike's ESR meter yesterday(Thanks Mike!) and I have measured some caps with it and I'm a bit confused.
I have measured two 1000uf capacitors and they showed like 2240uf and 0.09 ESR, that means it's bad or I'm picking up some other component's value?
(budm, I'm talking about the Vizio's PS)Leave a comment:
If your going to spend money on ESR testers .........
Then spend a few extra quid on a small range off NEW HQ
caps for calibration of said meter ,OUT OF CIRCUIT test...its the only way you will ever know,If its Accurate !
Known Calibration is essential.
IMHO IN Circuit testing of Capacitors is a practice frought with disaster...
No matter what the blurb says !
Seems no one's mentioned A "sometimes essential tool"
Called a "SCHEMATIC"
Or you could be there for years !
Or just or just give up !Last edited by S2udio; 05-02-2012, 11:20 AM.Leave a comment:
He probably meant to sell it for more. The guy knew how to get it calibrated so he cant be a total idiot / not know what quality it was. He also listed it as great condition and with RMS with some excalmations so seems to have known well what it was / does.
Unless there is chinese fakes or something, and the seller is scamming whoever bought it.Leave a comment:
Maybe he didn't know what he is selling.
I don't mind paying more, at least I will know that nobody abused it, I have the lifetime warranty and it's brand new and tomorrow I will have it.
In my opinion if you can afford a new meter then buy the new one. Instruments are tools in which you want to trust.Leave a comment:
Is that for real? How can it go for that low?Leave a comment:
UNBELIEVABLE!!!! $20 sold for working Fluke 87V.
http://www.ebay.com/itm/330725073380
If the seller meant $200, I wonder if he HAS to sell it for $20?Leave a comment:
I thought that it might creep up in price.
I would love to get hold of the fluke 87v next. I'm pretty sure I should really be looking at an oscilloscope before buying a second fluke multi meter though.Leave a comment:
I use 2.6~3mm tip for de-soldering as well on my good old Weller soldering station.Leave a comment:
Start at 28:26 into this video and see how the tip size makes a difference.
http://www.eevblog.com/2011/07/02/ee...torial-part-2/Leave a comment:
I have a 1.6mm not a 2.6mm.Leave a comment:
So that is my problem, that I'm using a to small tip? If I remember well I'm using a 2.6mm one.
I will get one and try it out before I get another station. At work we have an old Weller and with that I can unsolder anything with a sharp pointy tip.Leave a comment:
http://danshardware.wordpress.com/20...l-899d-review/
Did you get these?
http://danshardware.files.wordpress....2-21-41-42.jpg
If yes, use the bigger tips for desoldering.Leave a comment:
by sam_sam_samI have been working on this concept for quite some time now with limited success but recently I found a switching power supply that is setup for the voltage that this soldering station needs to operate at however it also needs part of the secondary circuit from the original switching power because you need several voltage rails
I once tried to get a ZD-915 desoldering station to work on a 18 volt battery power supply but unfortunately things did not go well but I did find a work around but I might try this idea again but going at a little differently more about this another time... -
by chth96hello.
A few months ago,I have purchased 0.1mm Soldering Iron Tip of below aliexpress link,But I noticed that It is totally impossible to use this 0.1mm iron tip in the T12 soldering station
https://ko.aliexpress.com/item/4001275635593.html
Is there any good soldering station which is possible to use 900M-TJ-I tip and have inexpensive or reasonable price in aliexpress?
Any reply would be appreciated. -
by acedogblastThis is a guide that I am writing for helping others to replace their MEC1503 EC chip if it breaks (or to get around an inconvenient prompt to the BIOS). This forum has been extremely helpful to me so I would like to contribute to help others. I will tell you right now that this task is very difficult to do. You MUST have experience and tools to do precision micro-soldering, BGA reballing, trace repair, and general laptop repair skills.
There are some specialty tools needed to do this task. The replacement MEC1503 chips can be acquired from Aliexpress. Do not buy the bare chips as... -
by mkbehbehI purchased this soldering station when it was on sale at amazon. It had a slew of one star reviews, but the price was low enough that even if the controller and PSU were toast, the handle tips and stand were worth more than the price. All of the reviews mentioned that the unit was either DOA, or died on the first use. I looked on Aliexpress and the first clue was that KSGER still sold the 220V version of this station, but all of the 110V versions had been discontinued. I figured That there was a problem with the 110V on the power suppply and the controller would be fine.
I am... -
by Peter_1402Hi Everyone,
I bought a Yihua 992DA+ hot air gun and soldering iron unit from a used market.
1. Soldering iron works great
2. There is a burnt mark on the hot air gun handle.
I am a bit concern by the look of the melted plastic. I opened the hot air gun handle and took some readings with a multimeter.
Heating element ~ 75ohm. (Similar reading taken from a spare heating element that came with the unit.)
Thermocouple ~ 1.5ohm. (Similar reading from the spare heating element.)
Reed switch tested ok with a magnet.
From the above test, I can conclude... - Loading...
