sony KDL-46s2000 bad inverter board
  • ntehicks
    • Mar 2011
    • 272
    I wanted to know if it is possible to repair a bad inverter board. the one I have is PCB2699 A06-126437D RIGHT UPPER INVERTER BOARD. one of the fuses on the boad is bad and the entire rail that has the capacitors on it has a short. I have tested the lower board that is good and it has no such short. I am hoping to find some direction on what to test first. thanks.
    Re: sony KDL-46s2000 bad inverter board
    I think the MOSFET's are shorted out, not the caps, that is caused the fuse to blow. The MOSFETs may have failed due the bad high voltage transformers. I would look to see how much the replacement board is, try shopjimmy.com, then you can figure out how much time you will want to spend troubleshooting down to component level, and I hope you do have good tools and experience at working on surface mounted components.
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • m1ch43lzm
      by m1ch43lzm
      05-12-2025, 08:37 PM
    • jb_Bak
      by jb_Bak
      CN6401
      Pin 01 NC
      Pin 02 NC
      Pin 03 "BL_ON": 0V
      Pin 04 "N/C"
      Pin 05 "STBY 3.3V": 3.5V
      Pin 06 "GND": N/C
      Pin 07 "AC_OFF"...
      09-27-2021, 04:52 PM
    • howardc64
      by howardc64
      07-24-2025, 05:17 PM
    • delpiero3
      Sony Vaio SVS MBX-261 board failure
      by delpiero3
      Hi everyone, newcomer in this forum, i watched tons of video from Sorin, i like the way i calmly explain things, i did quite some console repair, i am not that bad at micro-soldering, but troubleshooting where the issue is, is definitely where i still have progress to make. Usually i was able to fix the console because the failure was obvious, or because i was able to find someone with similar measures on the board and was pinpointing what to replace that way.
      Nevertheless, let's say, i don't come as a total beginner.
      I have this old laptop, which suit perfectly my needs, with the...
      10-29-2024, 06:16 AM
