Opening remote controls?
+ More Options
Posts
  • mathog
    • Mar 2010
    • 2655
    The up/down volume and channel buttons on our Samsung TV's remote have died. We already have a Universal remote so the TV is still usable, but it would be nice to get the Samsung remote working again as it has a few extra buttons that are convenient.
    Of course the broken remote isn't held together with screws. Will post a picture when I get a chance. In the meantime, are there any tricks to opening remote controls? Or are these usually put together in such a way that they cannot be disassembled without destroying the plastic case?
  • cmj21973
    • 267
    Re: Opening remote controls?
    Should be at least one screw. If not on the outside, look in the battery compartment.
    Use a gift card, credit card, or one of those customer cards on your key chain.
    Wedge it into the remote seam and gently slide it appling force. They have press clips holding them together.
    instructional:
    http://www.ehow.com/how_7174006_disa...tv-remote.html
    • Krankshaft
      • Jan 2007
      • 2328
      Don't be shocked if you break a few of the clips they're not meant to be disassembled.
      • multimeter
        • Jan 2011
        • 739
        • united kingdom
        use a guitar pick,good for opening monitors too without breaking the clips
        fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
        please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!
        • cadiman
          • Mar 2010
          • 397
          If you can get them apart I just resolder the board and pull up the rubber button pad and gently clean the board.
          Remotes get thrown around alot and the heavier components on the board develop solder joint cracks.
          Also check to make sure the battery power is getting to the board.
          • mathog
            • Mar 2010
            • 2655
            Found a single screw in the battery compartment, but not in the usual place. It was in the very narrow separate slot where the battery cover hook engaged. Took it out. The seam is completely shut. Cannot get anything into it except at the front, where the clear plastic piece is over the IR Led. This remote isn't flat by the way, it is curved and the seam is also curved. Tried to take a picture when I got home but it was too dark and it didn't come out well. Will try again when the Sun comes up tomorrow.
            Using a very sturdy guitar pick the best I have managed starting at the front is to wedge the pick back about 2 mm down the side. At that point the top is deforming but nothing has snapped free.
              I had to disassemble a remote control from a TV I repaired, because the previous owners had been 50-a-day smokers it seemed. All the remote buttons were covered in this hideous yellow coating.
              I worked the case open with a screwdriver, careful not to crack it. (A small amount of force is required to disengage the clips holding the components in.) When I did this, I took the button pad out and gave it an overnight soak in some warm soapy water. I replaced the pad later (which now was a much more pleasant grey) and reassembled the remote.
              • 999999999
                • Sep 2006
                • 774
                ^ While I've seen tar stains on smoker's possessions, I've also seen a yellow gooey substance inside remote control pads in non-smoker's homes but only on the rubber buttons and PCB next to the buttons. My theory is certain types of rubber keypads decompose to form an oily substance.
                Opening the remote, it can help to warm the plastic with a hair dryer /etc, less chance of the clips breaking. Sometimes you can create a little more of a gap on an edge by putting the remote in a bench vise, with rubber pads around it so the finish isn't marked up. Compress one direction and the other free sides get a little bit of play in them... though of course if you compress too much damage can occur.
                If the battery compartment and screw is towards the rear, start prying it open at the rear or the side(s) near the rear instead of the front.
                  That's possible. But the remote control also had a bit of melted plastic on it, which looks to be from a cigarette, but I'm not sure - either way, it was disgusting.
                  • cmj21973
                    • 267
                    What's gross and disgusting are remotes and cell phones that are covered and packed with: soda pop, food, grease (food & automotive), hand lotions, sweat (body oils and skin cells), and anything else.
                    • mathog
                      • Mar 2010
                      • 2655
                      Finally got the darn thing open. Using two thick guitar picks worked from the front (the only place I could get them in) all the way around. The lower part of the case had thin bridge like bits of plastic, and it wouldn't release the top until every one of those broke off. However, there were also clips which came through intact and were functional enough for it to snap back together when reassembled.
                      The innards were remarkably clean. The circuit board looked like it had just come from the factory and the rubber pad was clean too. Later under a very high magnification and just the right lighting a few tiny spots on the contacts for the buttons which were not working were visible. So cleaned them off with a Q-Tip, and gently cleaned the matching parts of the rubber pad too. That minute amount of dirt was indeed the problem, once cleaned, all the buttons worked again. Reassembled and it snapped back together firmly, except at the front, where there was a 1 mm gap, probably from deforming the plastic due to all that prying. To keep dirt out a bit of Scotch tape was wrapped around the front, sealing that gap.
                      Thanks for the suggestions.
                      • cashkennedy
                        • Aug 2011
                        • 668
                        Some nicer universal remotes have learn functions, or even all the rarer buttons that samsungs usually have.
                        You might want to pick up a better universal though to use, and keep the samsung remote stashed away otherwise.
                        Just fixed a samsung with no remote though and was surprised that every single possible function worked on a universal remote, just using the standard codes. It is a philipps remote i think , and not an RCA, so RCA ones might not support as much though.
                        Fixed so far 12 lcd's , 1 plasmas, 5 monitors, 0 dlp's (plan to keep the dlps at 0). and 3 atx power supplies, and 2 motherboards.
                        • cstout
                          DeLonghi AC Remote only accepts 3V
                          by cstout
                          Hello all, I've been looking into this portable air conditioner's remote control and can't find what could be causing the problem - or possibly this remote is just terribly designed.
                          The remote only works at exactly 3V - if I drop it any lower, using my bench power supply, to say, 2.9V then the remote will not flash the display and turn off. I don't have any AAA batteries that are exactly 1.5V each so I'm not sure if this remote is designed this way - to only use the freshest possible batteries, or if there's a failed component in the mix.
                          I can't find any schematics...
                          06-03-2024, 03:53 PM
                        • rustinjust
                          Please help, where can I get a remote for my subwoofer?
                          by rustinjust
                          I’ve got a subwoofer that I’ve had for nearly 20 years, it did come with a basic remote which I’ve lost. It’s a generic make of subwoofer, I can’t see a brand sticker on it. It comes with 2 speakers.
                          Question recently I’ve connected it up to my tv which has greatly improved the sound on my tv, however I’d like to be able to mute the subwoofer when ads come on or just mute it when the phone rings etc. I tried using a cheap all in one tv remote on the subwoofer and the volume button would only work to increase volume but not turn it down or mute it
                          Is there...
                          10-28-2023, 03:43 AM
                        • jesterace
                          Samsung B2030HD IR Remote Receiver Dead, shorted micom?
                          by jesterace
                          I have this TV a small 20 inch that works perfectly except for the IR has stopped. I have confirmed that the remote control is fine and tried an alternative and even tried with IR blaster from phone. Remote 100% ok.
                          Tried installing latest firmware but no change.
                          TV won't respond to remote at all, not even to bring it out of standby. I have to use the touch sensitive front panel to operate, at which point TV is usable albeit with no remote.
                          Tried replacing the IR receiver diode/bulb on front panel and no change so put the old one back. After tracing...
                          10-26-2022, 02:20 AM
                        • Dannyx
                          "Kinetic" 433Mhz transmitter/receiver discussion
                          by Dannyx
                          Good day folks.
                          TL;DR: has anyone tried pairing one of THESE "kinetic" battery-less switches with THESE generic remote modules ?
                          Details: I recently got hit by this craze of wanting to add remote controls to the lights around my house, so I went with those generic 433Mhz remote relay modules found everywhere, which are really basic, easy to use and work well, since I used them before in other projects. What I like most about them is they accept all kinds of 433Mhz remotes that float around Aliexpress, since they're all the same under the hood, save for the...
                          03-08-2022, 11:01 AM
                        • codycowgill
                          Lost christmas tree remote
                          by codycowgill
                          I have a rgb "holiday symphony" 600 led tree that I got for free but it has no remote which basically neuters the tree with just one color option and no music. The original remote is as 433.96 mhz rf remote. Here is the fcc link: https://fccid.io/2APJZ-PDT0093V.
                          The manufacturer is Polygroup and are absolutely no help. As they offer no replacements to the most easily lost part. All they gave me was the model number of the remote and said google it and good luck. Of course nobody is selling them. Anyways I provided pictures of the reciever motherboard along with the rgb...
                          12-31-2022, 06:22 PM
