pioneer plasma PDP-435PE
    Has any1 here ever worked on 1 of these sets..when powered on the led flashes from green to red continuesly..when pressed power button at the side the red led flashes 2 times pause then 2 times..thats with & without the media receiver box connected..on the receiver box the red & green led are on solid when connected to tv..ive not worked on a plasma before was hoping to find bulged caps but all seem ok..the psu is PCB2524 A06-125581
    Re: pioneer plasma PDP-435PE
    Service manual:
    Page 58.
    Red LED flashing two times indicates MR-AC power off (media receiver power off.) This probably indicates a fault with the AC detect, PFC stage or perhaps another part of the power supply. It may also indicate a media receiver fault.
    Start by taking pictures.
      I love Pioneer stuff. You need to find a Pioneer 5090 to fix and keep Tom they are awesome!
      Fixed so far : 1 Home cinema system, 16 LCD Monitors, 4 LCD TV's
      How to resize your pictures guide click HERE
      Retiredcaps Ideal post example click HERE
        I haven't yet fixed a Pioneer or a Sony. Both I am looking out for. I also want a Panasonic LCD - after fixing a Panasonic plasma as I've seen how well they are built.
          http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=290682203608
          Why don't you see if you can get this one nice and cheap! He has listed it twice. I would have it if I lived closer.
            Service manual:
            Page 58.
            Hi tom..how do i download that manual..some pics of the pin outs..am i testing the voltages with all the plug leads in thx
            http://i1068.photobucket.com/albums/...5/P1000937.jpg
            http://i1068.photobucket.com/albums/...5/P1000936.jpg
            http://i1068.photobucket.com/albums/...5/P1000935.jpg
            http://i1068.photobucket.com/albums/...5/P1000938.jpg
            http://i1068.photobucket.com/albums/...5/P1000933.jpg
              Use Manage Attachments to add pictures.
              Click "Get Manual" after about 30 seconds, appears near bottom of page.
                Sos for not using manage attachments it wasnt working properly last time..do you only need psu pics for now..thx
                  Nope, I'd look at the media box. Do you have the whole set?
                    Yes ive got full set..ive already opened up media box was growing a carpet inside it was that dusty..will open it back up and take pics..thx
                      taken readings from 16pinout of media box
                      all seem ok apart from 14 & 16 reading 2.461vdc & 2.690vdc..wtf
                        Pics or it didn't happen .
                          http://i1068.photobucket.com/albums/...5/P1000965.jpg
                          http://i1068.photobucket.com/albums/...5/P1000970.jpg
                            Tom i was taken all the pin out readings & pics but keep getting timed out on this site..is there a setting on this site cos it does my box in..i aint a fast typer lol
                              It is because your pics exceed the restrictions below. Use manage attachments.
                              --- begin sig file ---
                              --- end sig file ---
                                I keep getting upload failed when using manage attachments..you guys will have to bear with me on this 1..its all opened up on my bed & wife doing my head in...i need a workshop with a hammock..lol
                                Gonna get some more pics sorted
                                  Obviously, first step check all supply voltages to media box.
                                  How does the media box connect to TV? Does TV have any inputs on rear, or is it just one IO cable between media box and TV?
                                  I have my own shed, dedicated to TVs...
                                    Its a PDP-R05FE media box connects to tv with 1 cable split in 2..
                                    http://i1068.photobucket.com/albums/...5/P1000992.jpg
                                      Okay one DVI and one PanelLink cable. Fun, custom interfaces.
                                      Check for good supply voltages - 3.3V, 6.5V, 12V, 17V.
                                      Read service manual troubleshooting flowchart... follow all the steps.
                                      Especially check the AC detect signal.
                                      Plug the DVI output into a DVI monitor if you have one available... check if you get video.
                                      If no DVI monitor use a DVI-HDMI cable and plug into a HDMI TV.
                                        If i press both tv & receiver box power buttons at same time the tv led is solid red(standby) & receiver both green & red both solid..took measurements from receiver box & voltages seem to be correct on all boards...cant test the leads got no other source to try on..does it sound like tv at fault & not receiver..thx
                                        The AC detect pin being 2.690vdc does that seem to high??
