Need some help on Insignia NS-LCD47HD TV No Picture No sound. Blue led comes on.
  • organizddisastr
    • Jan 2012
    • 26
    Ok guys, this is what I have so far. I tested the power supply. All my voltages out are pretty much in range. I proceeded to the main board and started testing regulators. I came to U707. Voltage in is reading 3.23v. I'm getting a voltage reading of .33v out. I looked at the data sheet and i am supposed to have a 1.8v dropout. So i believe I should have 1.8v out?? Not .33v. I already ordered the part from digikey and replaced. I am still getting the same readings and still no luck with the TV. Now the regulator at U709 Is giving me a reading at .39v in and nothing out. I believe the problem would lie somewhere inbetween the U707 and U709. I am a newb at this stuff so any suggestions or help would be greatly appreciated. Thanks in advance.
    Re: Need some help on Insignia NS-LCD47HD TV No Picture No sound. Blue led comes on.
    Did you Ohm out the output of the regulator to see if it feeding into shorts circuits and it may take out your new regulator if the shutdown circuits of the regulator does not shutdown fast enough.
    • organizddisastr
      • Jan 2012
      • 26
      Not sure how to ohm it out. Can you help me out?
        TV unplugged and let the power supply capacitors drain out for 5 minutes, set the meter to Ohm mode, black lead to the chassis, red lead to the output leg of the regulator, see what you get.
        • organizddisastr
          • Jan 2012
          • 26
          Ok, I have mainboard out of the TV so I set my multimeter to ohms, black lead on ground around screw hole for chassis and red lead on tab of regulator on U707 here's what i got. 000.6 ohms..
          • organizddisastr
            • Jan 2012
            • 26
            Now how do I find where the short is??
              That is the hard part since it goes to lots of places, it the output pin the middle pin? P/N?
              You may have shorted CAP (MLCC TYPE). There should a lot of filter connected to the output of the regulator, you may have to remove them one at a time to see if shorts go away.
              • organizddisastr
                • Jan 2012
                • 26
                Yes the center pin is the output. Now, the first cap after the pin is labeled C743 and the last cap on the circuit before the next regulator is labeled C749. So if I am correct all banks on the circuit where the short is would be 743-749. Is it correct the circuit runs in numerical order??
                • organizddisastr
                  • Jan 2012
                  • 26
                  Basically I'm uncertain how to trace the circuit.
                  • ChaosLegionnaire
                    by ChaosLegionnaire
                    09-13-2022, 09:02 AM
                  • LEECH666
                    Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                    by LEECH666
                    Good day ladies and gentleman!
                    I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                    This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                    I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                    01-19-2024, 05:46 PM
                  • Ronald9
                    Insignia 42" LCD TV Blue Screen with Sound
                    by Ronald9
                    Hello all,
                    Trying to troubleshoot a problem with my Insignia 42" LCD TV, model #: NS-42E760A12 Rev B. When I turn it on, the screen is blue. The menu and input selection does not show on the screen. When I connected a PS4 device, I could hear sound and occasionally got a partial image (got lucky as the last input setting before it "blue screened" was on the HDMI port I used for the PS4). The partial image (when it shows) is on the right side of screen when facing the TV.
                    Would this be a T Con Board issue, Main Video Board issue, or something else? Powers...
                    12-30-2019, 09:51 PM
                  • mar1in
                    Samsung TU8000, backlight and sound on, stuck in blue screen
                    by mar1in
                    I've got this Samsung here that would be stuck in a boot loop.
                    After opening up and doing the tape block method, I was able to get it to turn on and play sound from the HDMI input, but with a blue screen.
                    Does that mean there is another combination of pins that I need to block in order to get a picture, or is there something more serious, faulty mainboard or faulty panel?
                    Thanks in advance
                    11-08-2023, 05:43 PM
                    Microsoft Surface Redbank i5/8/256 Blue Notebook Specification for Upgrade or Repair
                    This specification for the Microsoft Surface Redbank i5/8/256 Blue Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Redbank i5/8/256 Blue boardview and Surface Redbank i5/8/256 Blue schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                    09-07-2024, 05:50 AM
