Samsung ln-t4065f - vertical lines
  • ahickman
    • Jan 2012
    • 233
    Just had a Samsung LN-t4065F 42" dropped off by a friend that powers up but displays only vertical color lines. Have not opened it yet, but looking for suggestions on where to start looking. Loose T-con controller cable?
    aaron
    Re: Samsung ln-t4065f - vertical lines
    Definitely looks like T-con. I had a similar problem with a Samsung which turned out to be a failed voltage regulator on the T-con.
    • ahickman
      • Jan 2012
      • 233
      Thanks. Just got back to my desk and decided to try something I recalled from another thread. Held in the Menu button and powered on. Fired right up and clear picture from VGA source. I did notice a few pixels were striped, but went away as the image refreshed. Nice to know that it is not totally disfunctional. Taking the back cover off now.
        That may be a coincidence. When I saw the mentioned Samsung TV, it was faulty. When I got it home it actually worked - the regulator was intermittently failing. If the output voltage of that regulator is low, the T-con may be becoming confused, and the Menu button may be resetting it...
        • ahickman
          • Jan 2012
          • 233
          Curious as to how you identified the failing regulator. I assume it was a three pin type regulator (Vin, Vout, GND)? Did you see ripple on the Vout or just watch the pin with a scope, looking for voltage level changes? Recall, which regulator it was?
          • ahickman
            • Jan 2012
            • 233
            Opened it up this AM and right away noticed the bad caps on the PS. It is a Hansol BN44-00167A board and I found right many threads on various forums. Looking at the 1000uF @ 10V caps, I found ESR's in the 2.2 range. CM807, CM807 and CM809 had decent ESR readings of 0.1x - 0.2x and the main filtering cap was also 0.2x ohms.
            All I have in my parts drawer are some 1000uF @ 35V / 105 deg. capacitors. Can anyone tell me if the higher voltage rated caps can be used in place?
            • truep
              • Aug 2010
              • 373
              The 35V caps will work if they are low ESR caps and IF they will fit.
              • ahickman
                • Jan 2012
                • 233
                Thanks. Just replaced four of the 1000uf 10V with 1000uF @ 35V and turned it on. Big Bang Theory is playing now! Thanks for the help guys.
                  Curious. I have heard of bad caps causing picture freezing and possibly lines on Samsungs... but never seen it before in person or on the forums.
                  On my board it was a standard 1117 regulator with a 2.5V output voltage, measuring close to 1.3V. The output voltage presumably would occasionally stabilise (as it worked once), but most of the time would be stuck at 1.3V.
                  • Falki
                    Colorful LCD Vertical Lines on Samsung ue55es8090
                    by Falki
                    Hello there, ive recently found an older 55inch Samsung SmartTV.
                    A similar issue has been posted as well but also with no actual response ...
                    08-12-2025, 04:19 AM
                  • Stanley1843
                    by Stanley1843
                    06-29-2024, 11:54 AM
                  • pni
                    LG 49uf695v vertical coloured lines
                    by pni
                    Hi guys…I need your help. My cousin ask me to fix her tv. The tv when I went to pick up showed 3 horizontal black line. So I know it was a bad panel issue but I could try to fix with the tape method so I said her I could fix easy. When I come back to home, I turned on the tv and now the tv show vertical line colored….and the problem is that I unplug the ldvs cable, first the right side then the left side I still have the lines. The lines never disappear. When the right side is plug in I don’t have nothing on the screen only this vertical lines, when the right side is unplugged I have picture...
                    11-14-2025, 03:15 AM
                  • polaro
                    Thin stable coloured vertical lines on Samsung UN65NU6900FXZC come and go
                    by polaro
                    Greetings,
                    I've bought a used Samsung UN65NU6900FXZC LED TV. It worked fine for some time and then developed, at first, a single very thin (1 pixel) vertical stable blue line, from top to bottom, close to the left edge of the screen. Now it's 3 lines on the left. When I connect HDMI sources the number of the thin lines grow. After disconnecting and cold discharging I am back to 2 lines. The lines disappear at a rate of 15-20 minutes per line. So it does not look like a damaged LED panel. Any advice? Thanks...
                    08-27-2022, 08:46 AM
                    09-07-2024, 05:50 AM
