This Guy was About to Put His Toshiba 37AV500U Into the Dumpster.....
  • Paul678
    • Nov 2011
    • 402
    .....Until he saw my Craig's ad for broken TVs........
    His TV has sound, but no picture.
    The repair kit on Ebay consists of both the Master and Slave
    inverter boards:
    http://www.ebay.com/itm/TOSHIBA-37AV...-/170554383879
    And there apparently are substitute inverter boards:
    http://blog.coppelltvrepair.com/2010...cement-in.html
    The Ebay kit is about $100 with the shipping, so
    that's a bit pricey, but isn't there a decent chance it's
    only a blown fuse, like on the Sceptre I recently worked on?
    And since he was about the throw the thing away
    anyways, am I being an asshole to offer him $5??
  • PlainBill
    • Feb 2009
    • 7034
    Re: This Guy was About to Put His Toshiba 37AV500U Into the Dumpster.....
    inverter boards:
    I'd give him a sawbuck, a double sawbuck if he includes the remote.
    PlainBill
      And no need to replace both boards. Most likely just one is failed and if it's a transformer or MOSFET, that should be easy to locate.
      • Paul678
        • Nov 2011
        • 402
        Do you think there's a good chance I can repair
        the bad inverter at the component level?
        It looks like most people sell the Master and Slave
        together, no separately, so that would be pricey.....
          Yes, I'm pretty sure you could repair it yourself.
          • Paul678
            • Nov 2011
            • 402
            Ok, the fella gave it to me for free!
            Cracked it open.....the main fuse on the power
            supply is MISSING! I could have swore the fella
            said no one has worked on this, but I'm not sure how
            a fuse can dissappear.
            The fuse is labeled T 4.0A H/250V.
            Should this one be a fast or slow-blow?
            Ceramic or glass, or it doesn't matter?\
            And should I be looking for shorted out bridge rectifier diodes,
            or shorted filtering caps?
              Should be time delay. That's what the "T" indicates.
              I bet the guy opened it up, took the fuse out and tested it (probably found it was okay) and forgot to put it back in or lost it and didn't know what to replace it with. But a free TV, can you complain?
              Filter caps rarely short; but a simple check would be to replace the fuse (buy a pack of five or so.) If it blows straight away (this is a safe failure mode), you have a power supply problem, which is usually fairly simple to find. (Shorted MOSFET, shorted bridge rectifier, etc.)
              • Paul678
                • Nov 2011
                • 402
                SWEET! It's a shorted D4SB S6:
                I'm trying not to get too excited here! But if it's
                just this rectifier and a fuse, life would be swell!!!
                  Nice. How did you determine the short? Could be a shorted MOSFET, for example, between the + and - pins.
                  Are you sure about that part? That's a 60V device. It would go pop on 115V mains which is 160V peak. Should be at least a 200V device, preferably 400V or 600V.
                  And I'm trying to figure out how you'd have sound but no picture with a shorted bridge rectifier and blown fuse.
                    You should diconnect all the load from the power supply first, yif you have shorted load, it could damage the new rectifiers, as TOM said, you have shorted loads.
                    You should use GFCI outlet when work on line powered products for safety.
                    http://s807.photobucket.com/albums/yy352/budm/Tools/
                    By the way, where uis this D4SB S6 is located?
                      I agree with Tom, per spec. this 60v bridge rating is not right at all, It should be 4~500v rating.
                      • Paul678
                        • Nov 2011
                        • 402
                        I always verify shorts by removing the component completely
                        from the circuit. I've had a shorted filter cap past a voltage regulator, that
                        made the rectifier look shorted in-circuit, so I'm well aware of this.
                        The peak for 120V would be about 170V, so yeah, I'm thinking whoever removed the fuse, may have done some more dirty work, like installing incorrect parts (the pads on the bridge indeed looked sloppy)! Luckily, the lady at the parts counter gave me a KBU4J, which has a peak reverse voltage of 600V.
                        Yeah, I could have sworn he said he still had sound, but
                        clearly this wasn't the case.......
                        My optimism is fading......but I'll let you know what happens....
                        Thanks for the input....
                        • rpgruss
                          • Jan 2012
                          • 124
                          There are two rules about people getting rid of broken TVs.
                          1) If they tell you what's wrong, they are wrong or are lying
                          2) If they say it's an easy fix, they are lying
                          I've fixed 25 TVs and monitors, and only one time was the seller correct about the failure.
                          If the bridge rectifier shorted, don't be surprised if more things are broken upstream. I have an epic thread going here about fixing a power supply that blew it's rectifier, looking back every single fault can probably be traced to that. The damage so far is the standby controller, couple resistors, and possibly the power factor controller...
                          • Paul678
                            • Nov 2011
                            • 402
                            Ok, the power supply is fixed!
                            Totally screwed up that someone put in the WRONG
                            bridge rectifier! haha!
                            Ok, now all PS voltages are normal, remote control works,
                            and manual ON/OFF button works correctly....but still no
                            picture, even though healthy +24V is getting to both
                            inverters.
                            The Master:
                            The Slave:
                            All +24V pins are good. Plus:
                            DIM pin = +2.2V
                            INV pin = +5
                            And one signal is +0.7V on the 10 line
                            synchronizing ribbon, while all the rest
                            are 0 Volts.
                            I found only one +24V fuse on each
                            board, and they are both good. The +24V
                            gets sent to what I believe is the drains of
                            Q1 and Q5 (in third picture), but when I
                            try to measure an AC voltage on the
                            primary side of the transformers, I get
                            nothing. So apparently the switching
                            action is not there.
                            Any advice greatly apprectiated....
                            • rayrod81
                              • Oct 2010
                              • 205
                              It is most likely the driver IC on one of the inverters that has gone bad. Sometimes one (or more) of the FETs go bad as well. I had one of these exact TVs and the Slave had a bad driver IC but the FETs were good. $10 and one BD9897FS IC later the TV was working great. Check the resistance across the FETs on both the master and slave. If you find a short or low resistance reading then that will confirm the IC is bad and needs to be replaced. I believe you can find a repair kit with the IC and a couple of the FDD8447L FETs for around $15 or less depending on where you order from.
                                Philips also released a repair kit for certain inverter boards to prevent the problem from occurring again. Might be compatible with this inverter?
                                • Paul678
                                  • Nov 2011
                                  • 402
                                  Thanks much, Rayrod. I found 2 bad FETs on the
                                  slave board. I assume because of the synchronize
                                  ribbon, if one IC or board doesn't work, then the other
                                  will not turn on either, which is why I didn't see
                                  any switching on either board, right?
                                  Wow, it's as low as $3.80!
                                  http://www.ebay.com/itm/1PCS-X-IC-RO...item3a71270002
                                  But the ship time is too long from China to the USA, so I don't mind
                                  paying $9 more:
                                  http://www.ebay.com/itm/HIU-813-M-HI...item25602e5f3d
                                  Coppell recommends here that you replace ALL 4 mosfets,
                                  even the ones that test good.
                                  The Slave IC chip looked bad to me, because even when I disconnected
                                  the bad FETs, one of the gate pads had continuity to multiple pins.
                                  On the Master board, each of the 4 gates went to one pin, which
                                  looked normal.
                                  Ok, the pitch on this chip isn't as bad as Plasma Y-sustain buffer
                                  ICs, but they are still pretty small! How did you handle the
                                  rework? Since I don't have a hot-air station, I'm probably
                                  gonna cut all the leads at the chip, remove the chip, and then
                                  remove each cut lead from the pads. Hopefully I don't tear
                                  any pads off. I'll try to solder the new one in by hand....it
                                  won't be easy. Professional solderers get your respect when
                                  you try to do their job!
                                  Worse comes to worse, I'll just buy this one:
                                  http://www.ebay.com/itm/HIU-811-S-Ba...item2a1a21a78e
                                  • randtek
                                    • Oct 2011
                                    • 280
                                    • US
                                    For removing these ICs, you should order a product called "Chip-Quik". It is a "solder" alloy that has a very low melting point. You just add a bunch of it all around the chip, it dilutes the regular solder. Then, you can run your iron around all of the pins quickly to melt it all, and lift the chip off of the board. I have used this product or about 15 years. I believe it is the safest method for removing many ICs and other SMD devices.
                                      I cut the leads on the IC when I need to remove the bad one. I would also repalce all 4 MOSFET's at the same time. They use Bridged output setup topology for driving the inverter transformer.
                                      • cmj21973
                                        • 267
                                        SM soldering is like painting. It's all in the prework before painting/ soldering.
                                        Just take your time and don't be in a rush.
                                        http://www.bing.com/videos/search?q=...st=0&FORM=LKVR
                                          09-06-2024, 05:27 AM
                                          09-06-2024, 05:59 AM
                                          Toshiba Portege Z30-C Notebook Specification for Upgrade or Repair
                                          This specification for the Toshiba Portege Z30-C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Z30-C boardview and Z30-C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba Portege...
                                          09-06-2024, 05:33 AM
