Sanyo DP42545 no video, has sound . Ready to try some tests.
  • Jimmy Nolins
    • Feb 2012
    • 41
    Hello , On my Sanyo DP42545, I have sound but no picture and was hoping someone could walk me thru checking some things .
    I have checked 2 fuses on board 1 , 1 on board #2 , 1 on board #9 .A green led lights up on the front of the tv and board #1 and remain that way till i turn the tv off. Caps all appear flat and not leaking.
    On board #4 ,Logic Main Board has 4 leds -- the second one ( from left to right ) marked led2002 on power up blinks a couple times then goes and stays out ... the last one ( from left to right ) marked led2000 is the one that blinks all the time . I have found some info and says if no video on any input check :
    line: ic2001 - ic301 - ic7001 - pdp Panel
    Parts: Around IC2001 ( DIGITAL DECODER), IC301 (SCAN CONVERTER),IC7001 (LVDS Interface),PDP Panel
    How and what do i do to check them ? Any other thoughts you may have to check also ? I thought i seen a post on here saying to remove the YB UP board from the y main and yb low but can't seem to find it now .
    I will be working on this after work in a few more hours
    Numbered in photo
    1: TV POWER SUPPLY # LJ44-00092F
    2: x MAIN Sustain # LJ41-02246A
    3: -----
    4: Logic Main ( BEHIND BOARD 6) # LJ41-03075A
    5: TCP F-BUFFER # LJ41-02244A
    6: J3TR Main Board # B10N11600
    7: TCP E-BUFFER # LJ41-02243A
    8: Digital Tuner (SANYO) # B10N11600
    9: Y MAIN Sustain #LJ41-02247A
    10: YB UP #LJ41-02248A
    11: YB LOW #LJ41-02249A
    Re: Sanyo DP42545 no video, has sound . Ready to try some tests.
    It looks like a Hitachi panel... but it could be a Samsung, that panel sticker looks familiar.
    First check would be PSU output voltages, including plasma panel voltages (Vs and Va, or whatever they are called on this set.) If those are present, check fuses. Post a closer picture of the PSU if you're unsure where to probe.
    • Jimmy Nolins
      • Feb 2012
      • 41
      Yes its a Samsung mostly parts it seems :PDP says model s42sd - yb05 and also says sdi :s42sd-yb07
      Yes , i don't know where to test , which board # do you need a closer pic of ? I have a yellow fluke meter if i can fiqure it out .
      Jimmy
      • retiredcaps
        • Apr 2010
        • 9271
        Post a picture of it.
        --- begin sig file ---
        --- end sig file ---
          Jimmy
          I would like a closer pic of the power supply
          • cmj21973
            • 267
            Here's the SM for your set:
            • Jimmy Nolins
              • Feb 2012
              • 41
              ok its a 87 III True rms multimeter
              Not sure if you mean board # 1 or # 3 in my picture , here is both .
              Cmj21973 , thank you . That must of been where i see to check lines:
              Also readded the picture from first post = bigger with the numbers i put on the board , might be more clear now
              • retiredcaps
                • Apr 2010
                • 9271
                That is one high end multimeter. I sure hope you know how to use it.
                I don't have any hands on with plasma so I'm not the best person to be directing you, but do keep in mind that you will be dealing with voltages close to 200V DC or more.
                The Fluke 87 is forgiving of mistakes, but try not to let the probes slip or touch anything including the heatsinks which may be/are live.
                • Jimmy Nolins
                  • Feb 2012
                  • 41
                  My grandpa gave me it about a year ago . I have never used it , iam lost with it
                  • retiredcaps
                    • Apr 2010
                    • 9271
                    You are one lucky guy. You should thank him for it.
                    It is one of Fluke's highest end multimeters. A replacement will cost you close to $350 new. Treat it with respect.
                    I suggest you set DC volts (that is the DC with the flat dotted and solid line) and start measuring AA, 9V, etc batteries to get used to it.
                    An excellent and quick tutorial is at (less than 5 minutes)
                    http://www.youtube.com/watch?v=bF3OyQ3HwfU
                    • retiredcaps
                      • Apr 2010
                      • 9271
                      I should explain that 200V DC or more may be enough to get your family calling 911. If you are going to measure these voltages, I suggest having someone close by monitoring your work in case something goes badly wrong.
                      Regulars here write clear easy to understand instructions with the target audience in mind, but obviously, we can't be held responsible for your lack of comprehension, attentiveness, or carelessness.
                      If you are unsure, ask for clarification.
                      • cmj21973
                        • 267
                        Fluke 80 series III manual.
                        • Jimmy Nolins
                          • Feb 2012
                          • 41
                          So i read some other posts again and thought at least let me check the y upper and y lower buffer boards . I recalled reading here about coppell blog and a write up they did. So i found it , but my buffer board connectors are different then the black ones shown . How do i test the style i have ?
                          • Jimmy Nolins
                            • Feb 2012
                            • 41
                            Looks like iam gonna strip the tv and take what i can to the scrap yard .
                              Can you show a picture of your buffer boards, and around the power supply near where the wires go out to the sustain boards?
                              • Jimmy Nolins
                                • Feb 2012
                                • 41
                                I can see the spots for Vs and Va . I can grab more focused shots if these aren't good enough when i get back . I also located a board replacement if i decide this one is bad.
                                The TV is sitting a garage , and thou its older and likely not worth alot . I am thankfull for the help i am getting as this is a learning experience .
                                • Jimmy Nolins
                                  • Feb 2012
                                  • 41
                                  Alright, got me a magnify glass to assure i was doing what needed to be done ... I checked the VA and VS = VA is 70.3 , VS is 207.3 , VE shows 109.8 .
                                  pdp say should be VA=70/VS=207/VE=109 ... So far this appears within specs.. What would be the next step
                                    Those seem in spec. How do the fuses check out?
                                    • Jimmy Nolins
                                      • Feb 2012
                                      • 41
                                      i removed the 4 i could find ( seperately tested each ) , 2 on main board and 1 on z main and 1 on y main . I did a continuity with the dmm and it showed zeros , i didn't check them on the board .
                                      • rpgruss
                                        • Jan 2012
                                        • 124
                                        If you have a non-contact infrared thermometer, turn the TV on with everything connected. Give it a few minutes, check the temperatures on the Y and Z sustain board heatsinks. They should be warmer than room temperature. If one of them is room temperature then that is likely your defective board.
                                        • ChaosLegionnaire
                                          by ChaosLegionnaire
                                          09-13-2022, 09:02 AM
                                        • hugocarmo
                                          Sanyo VHR-D4710G VCR no sound.
                                          by hugocarmo
                                          Hi again guys.
                                          Today I have a problem with this Sanyo VCR.
                                          I bought it online, It worked sometimes.
                                          I recap the Power supply and it started working fine.
                                          Image is perfect and all digital effects too.
                                          All of a sudden it stopped outputting sound. I checked for dried solders an all boards and soldered when needed, no fix.
                                          I have no sound on playback, on tuner, or aux in.
                                          On symptom I noticed is when it was working fine, the HI-FI led was on when I power up the VCR, now is OFF, A-B leds are on but when I put a tape they go off.
                                          On one of the sound processing...
                                          01-23-2024, 12:58 PM
                                        • LEECH666
                                          Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                                          by LEECH666
                                          Good day ladies and gentleman!
                                          I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                                          This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                                          I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                                          01-19-2024, 05:46 PM
                                          HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i5-9500T Specification for Upgrade or Repair
                                          This specification for the HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar boardview and ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                          09-12-2024, 02:30 PM
                                          HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i5-9500 Specification for Upgrade or Repair
