Sharp lc-42sb45u no response... at all.
  • dood
    replied
    Re: Sharp lc-42sb45u no response... at all.
    Originally posted by Toasty
    ZD911 is a 160v TVS diode (surge suppressor). That looks fine.
    ZD910 is a 15v zener, but without the other parts working, tough to tell if that's a problem or not. Are resistors R976 & R991 okay?
    What do you read from Pins 1, 2, & 4 of IC903 to ground (pins 5, 6, 7, 8)?
    Toast
    IC903
    Pin 1 - 1.0VDC
    Pin 2 - 6.0VDC
    Pin 4 - 171.6VDC
  • Toasty
    replied
    Toast
  • dood
    replied
    Although the energy saving may be a factor, as randtek eludes to, I rather doubt it. The manual is way too specific.
    If you check the troubleshooting guide on page 33 of the SM, it specifically asks about the presence of the +5 volt line and what to check if not present.
    IMO, recapping the mainboard is a waste of time, until you get the PSU fixed.
    My suspects here are the zeners ZD910 or ZD911, the switcher IC903, or the cap at C969. Also check any chip resistors of <500Ω value for burns or discoloration, like R991(47Ω) or R976 (22Ω).
    What is the voltage across the mains cap C907? (strangely, no one asked this question...?)
    Should be present at the anode of ZD911 (junction T904 - pin1/C945/ZD911).
    Toast
    I'm reading main cap voltage at 170.9VDC. I have 85.8VDC across C945 and ZD911
    ZD910 has 5.1v...
  • retiredcaps
    replied
    Originally posted by dood
    Anyone have anything else for me to try? ?
    Waiting on results from post #32 from Toasty.
    replied
    If it's burn-your-finger-hot, it's probably bad.
    If it's quite warm, that's unlikely.
    Have you checked that pulling up or down the STANDBY control line will cause voltages to rise or fall?
  • dood
    replied
    Anyone have anything else for me to try? If not, which should I buy? Mainboard, or power?
  • dood
    replied
    I left the TV plugged in for the last 30 minutes or so. I don't have a temp probe, but I would say that the processor heatsink is "quite hot". Failed processor, maybe?
  • dood
    replied
    Originally posted by randtek
    Yes, we probably can do that. Start by hooking the power connector back up to the main board. Measure the voltage on the "Power On/Off" pin of CN902 on the power board. I believe it is pin 10, but go with what is marked on the board next to the connector.
    Let me know what that voltage is with the connector connected. I believe this pin to be active high (3~5v in standby) but it could be active low. Does it change when the power button is pressed? I know you have probably already stated what this voltage is, but I'm getting old and forgetful, so humor me!
    The main processor will probably be a little warm in standby mode, if it feels hot to the touch, it may be of some concern. I am rather skeptical that a general recapping of the main board will be a productive plan. an ESR meter would be a big help here.
    With everything hooked back up, I have 0.02v on Power On/Off. Pressing the button shows no change. On the mainboard, CN401, (To key pad board), pin 4 measures 0.00v, pin 3 measures 3.11v, pin 2 measures 3.11v, and pin 1 measures 0.60v. When the power button is pressed, Pin 1 drops to 0.00v, but no other voltages change.
  • randtek
    replied
    Is there some way to fool the supply into thinking the mainboard is good?
    Just to narrow the search for where to devote the efforts here...?
    >>the main processor does get warm when the TV is left plugged in.<<
    Is that unusual?
    Is recapping that mainboard really an issue? Or is it more the processor that we need to look at?
    Toast
  • Toasty
    replied
    Follow the SM tips first, before you go replacing those caps and verify the mains supply voltage. More concerned about the 5v line than the 24v. Need to have the 5v present before the 24v.
    Anyone -
    Is that unusual?
    Toast
  • dood
    replied
    Toast
    I did not replace the two 50v caps. They're on the +24v line, so for testing purposes I could replace them with 25v caps and they should be okay. Permanent replacements should be 50v, though. I'll replace them when I get home and check the other things that you mentioned.
  • randtek
    replied
    I misread your Power LED question. I'm pretty sure it does light red when unit is in standby, it turns on green when power is turned on.
  • Toasty
    replied
    Toast
  • Toasty
    replied
    Dood- to answer your question(s)...
    and, has this board been fully recapped now? (Except for mains cap)
  • randtek
    replied
    Power LED should be lit green when power is on for this model.
  • dood
    replied
    randtek - since you are pointing to the mainboard now, I will mention - the main processor does get warm when the TV is left plugged in.
    I'll try recapping the mainboard, if I have the appropriate values.
    Also, with this TV, is the power LED supposed to be lit red when the TV is in standby? Because as it is, the LED is not lit at all.
  • randtek
    replied
    You are correct retiredcaps. 12% would be out of tolerance in most cases. This idea they are using of lowering the standby voltages is a pretty new concept. The logic on the main board usually runs at 3.3v, so the main can still regulate 4.4v down to a stable 3.3. But running the standby voltage down decreases overall current draw when the unit is off.
    And about the "service manuals". Since the advent of flat panel TVs, The service manuals can no longer be considered adequate for troubleshooting. The schematics are considedrably simplified from what the circuitry in the units actually contain. The manufacturers do not anticipate/support component level repair, so they see no need to provide complete and accurate schematics. Also, Manufacturers often have numerous versions of the same model, with parts that may or may not be interchangeable. These differing versions NEVER show up in schematics, and rarely in service manuals.
  • retiredcaps
    replied
    I believe your problem is not on the power board. I work on a lot of these. It is normal for the 5v line to run a little low in standby mode.
    Hi Randtek,
    Obviously with your hands on experience, this is valuable insight.
    There is nothing in the service manual to even suggest that 5V standby can run as low as 4.4V DC and still work?
    I guess the interpretation of "a little low" varies. 4.4V is 12% lower than the usual 5V and wouldn't qualify in my books as a "little" low. If dood had reported 4.85V, I would have regarded that as "little" low (3%).
  • randtek
    replied
    I believe your problem is not on the power board. I work on a lot of these. It is normal for the 5v line to run a little low in standby mode. For Energy Star benefit, many newer TV designs drop the standby voltage down when in standby mode. Your problem is probably on the main board. If you need to order a board for this unit, try to find part numbers directly on the board. There are 2 versions of both the main and power boards in this model that ARE NOT interchangeable. The service manual only lists one of the possible part numbers for each board.
  • PlainBill
    replied
    I'm really horrible at this type of troubleshooting because I can't understand circuit diagrams and apply them to real life to save my own life... With my current level of frustration, an eBay power supply is looking more and more likely
    I use the 'arm waving' approach to analyzing this circuit. All components EXCEPT Q918, R920 and R947 are straight out of the TL431 application note. The simple explanation is until the voltage at pin 3 of IC913 gets up to 2.5 volts no current flows through the emitter of IC911, so the SMPS controller is driving to output full power. As soon as IC913, pin 3 reaches 2.5 volts current flows, and the SMPS controller throttles back. It's the electronic equivalent used in the first steam engine Edison used when he the Pearl Street generating plant.
    Q918 and associated resistors is an unusual addition. When STANDBY is low Q918 is turned off, so R947 has no effect. When STANDBY is high, R947 results in a boosted output voltage.
    PlainBill
  • advant
    by advant
    02-03-2020, 12:25 AM
  • sefoster
    Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
    by sefoster
    I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
    11-20-2022, 09:29 AM
  • gavenb
    Sharp LC-80LE661U 80 inch
    by gavenb
    Hi folks!
    I have a LC-80LE661U that had some interesting issues.
    Initially, it would come on and show the sharp logo and would show normal static before shutting off.
    I started troubleshooting by disconnecting the led lighting strips and turning it on. It would do the same thing - come on, show the sharp logo and shut off. After reading, it was suggested to replace the main board. That was replaced and the same symptoms resulted. After this and some reading, the parts cannon got loaded up. I replaced the power board, same issue. Replaced the Tcon board and now it...
    11-12-2023, 02:05 PM
  • SONY_E-WASTER
    Help! Sharp LC-70UE30U 3 long flashes + 3 short flashes.
    by SONY_E-WASTER
    Hello, I'm new to this forum. I like to tinker with Sony electronics, I have been lucky trouble shooting sony stuff, But I can't find much info on this Sharp TV.
    The problem; plug to power>white led power indicator light is on>it turns on to the red Sharp logo>
    then the android logo is displayed, lit fine then the android logo brightness varies, then lit normal, then the tv restarts and does the same startup logos over and over for 5 times then it turns off and the power indicator light flashes the trouble code 3 long blinks plus 3 short blinks .
    does...
    12-26-2021, 05:46 PM
  • Superbee_dad
    Sharp 80” long short flash backlight error - Help
    by Superbee_dad
    Hello Sharp TV experts
    Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
    > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
    > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
    01-24-2025, 11:51 PM
