Vestel based 16" LCD: PSU ticking
  • notallbad
    • Oct 2012
    • 1190
    Re: Vestel based 16" LCD: PSU ticking
    Hi Giag
    I suggest you start your own thread with tv make and model in title and then describe your fault with pictures of the boards in the message, you will get help!
    This is an old thread and doubt the original poster will reply with a response.
    Good luck.
    • giagiuf
      • Jul 2013
      • Italy
      OK!
      Thank you very much!!!
      Regards.
      Gianluca.
      • rafa805
        • Oct 2013
        • 19
        • Portugal
        Hello everyone. I have a problem with this exactly same board (17IPS16-3 V2), the problem is that one of the componentes has blown up and i cant identify it in order for me to change it, so i would like to know if anyone can help me with this, i uploaded a photo so you can see what i'm talking about:
        Best Regards.
          Schematic
          Look up part number (Qxxx)
          If Q802 is part that's blown also replace: D809, R825, R823, Q801, R827, IC805.
          • rafa805
            • Oct 2013
            • 19
            • Portugal
            Originally posted by tom66
            Schematic
            That's exactly the part that's blown, the problem is that in the schematic there are 2 references associated to this part in particular, MTP6N60E and SSP7N60A, so which one is the correct one? Or am i in any way misunderstanding this?
              Either is acceptable but I would choose 7N60 over 6N60.
              • rafa805
                • Oct 2013
                • 19
                • Portugal
                #27
                Would a P7NB60FP by any chance work here properly?
                  A quick inspection seems to show the major parameters are close enough for an acceptable substitution.
                  • rafa805
                    • Oct 2013
                    • 19
                    • Portugal
                    #29
                    I asked if that one could replace the official ones because in Portugal those were not available, however, this week I'm in Switzerland and I was wondering whether I can find the SSP7N60A here? I don't know any stores or even any place where I can search so I would like to know if you can help, do you know if I can get this here and where?
                    Best Regards.
                      I have no idea unfortunately.
                      • rafa805
                        • Oct 2013
                        • 19
                        • Portugal
                        #31
                        Thank you anyway.
                        • nick4275
                          Vestel Based JVC no picture, leds on
                          by nick4275
                          Hoping someone has troden this path before !
                          I'm looking at a JVC LT-39c790 - a vestel based unit.
                          So, the remote turns it on, led's light up but no picture at all.
                          I have a spare mainboard, so I know its not that. The PSU seems ok too.
                          On the AUO T-Con I've got 16v on HAVDD_H but nothing on HAVDD_L - which I'm assuming should also be 16v ?
                          So, Ive resorted to testing eveything I can on the board as I can't find any schemas for it (AUO 39T15 C04 Ctrl Bd) and I think I've found a diode gone short. it marked D005 on the board and E1 on the package...
                          11-21-2023, 04:43 AM
                        • Jaime Morillo
                          Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
                          by Jaime Morillo
                          Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
                          The TV was stuck on the logo and I couldn't access the update menu.
                          I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
                          The image result was good, but the image is inverted.
                          The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
                          Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
                          08-18-2025, 11:38 AM
                        • narf
                          Epson EB-U42 projector / Caps with 0.7 ohms ?!
                          by narf
                          hi all,
                          first of all: i'm a (motivated) newbie, so please forgive me any stupid question i may or may not ask
                          i'm currently repairing a projector: Epson EB-U42 that doesn't start (no lights, nothing).
                          what i've found so far:
                          - the PSU does its job and supplies 12V to the mainboard via the connector.
                          - shortly thereafter, there is a mosfet (TS420-600B) where i can test 12V on the one side (in the data sheet this side is called Anode), Gate 0V, Kathode shorted to ground
                          - not far away, there's the first cap with a resistance of 0.7 ohms....
                          07-02-2024, 03:53 PM
                        • France_53
                          Vestel tv, how to flip the image?
                          by France_53
                          Hello everyone from Italy, I'm here to ask for help on a Vestel TV, I've had a Vestel TV branded "XD" with a broken screen for years, but now I've found a Telefunken (still Vestel but older) and I've mounted the panel on the "XD" TV, it works, but the screen is upside down, given that Vestel does not allow you to rotate the image from the service menu, does anyone know how to solve the problem? the original panel is marked ves315WNDS-2D-N12 while the main board 17mb110, the panel I mounted instead in the tv (from the telefunken) is a ves315WNDA-02. ... It is not worth repairing...
                          05-12-2024, 05:22 AM
                        • lberkani
                          Request: USB firmware for Toshiba 65UL2163DG (Vestel 17MB180E) - panel VES650QNTX-N2-N42
                          by lberkani
                          I’m looking for the correct firmware for my Toshiba 65UL2163DG TV.
                          The mainboard is Vestel 17MB180E, and my panel is VES650QNTX-N2-N42.
                          The board I received is flashed for VES650QNDB_N41 and shows double “No signal”.
                          I need the correct USB update package (upgrade_mb180.zip / upgrade.bin) for:
                          - Toshiba 65UL2163DG
                          - Vestel 17MB180E mainboard
                          - Panel VES650QNTX-N2-N42
                          - Version V1.28.100.0 if available
                          If anyone has the file, please share a download link (WeTransfer, MEGA, Google Drive) and include version.txt...
                          11-11-2025, 12:37 PM
