Plasma Y-MAIN board LJ92-01200A
    replied
    Re: Plasma Y-MAIN board LJ92-01200A
    The Y-main sends the same signal to both boards, so it's likely that you got a defective lower buffer.
  • Cailloux
    replied
    Sorry I do not know how to deleted this post.
  • Cailloux
    replied
    Originally posted by tom66
    You can't replace a high speed surface mount Schottky diode with a general purpose type! No matter how many "amps" it has.
    Hi Tom,
    I tried with a Schottky diode 3A 200V on D5022.
    I installed only the lower Y buffer.
    The diode shorted again but this time the lower Y buffer also short.
    Do you think the Y buffer was defective even though she had no short-circuit at the beginning?
    Or is it possible that the bottom screen is defective??
    Have a suggestion?
  • Cailloux
    replied
    Originally posted by cmj21973
    http://www.marsport.org.uk/smd/mainframe.htm
    F6 CMOZ3V9 CSC I SOD523 zener 350mW 5% 3.9V
    I'm 80% sure this is what your looking for, but I'd get a second opinion from someone more experience.
    In my research, I saw this suggestion in another forum. I do not think it is a zener on the board because it is indentifies D5022, not Z5022. It is connected from the anode to a transformer, and the cathode to a capacitor of 100UF-160v. Seems to be a circuit filter.
  • cmj21973
    replied
    Originally posted by Cailloux
    Hi Tom,
    You're right, I'll get a Schottky diode, but I do not know the values of amperage and voltage.
    What is strange is that the diode fail only with the lower Y buffer. She has no short circuit.
    I'll keep you informed. Thank you.
  • Cailloux
    replied
    Hi Tom,
    replied
  • Cailloux
    started a topic Plasma Y-MAIN board LJ92-01200A
    Hello, I need help to troubleshoot a Y-MAIN board LJ92-01200A (LJ41-02759A) at the component level.
    Prima plasma TV model PH42T7.
    Initially, I found the two Y buffers defective, on the Y main a short circuit mosfet Q5009 (One of these 7 transistors in parallel), and a diode short circuit D5022.
    D5022 is indentifies F6 5L.
    I bought two new Y buffers boards, LJ41-02761A / LJ41-02760A, Q5009 I removed, and installed a 1N4007 diode (1 amp) at D5022.
    I have not replaced Q5009 for now.
    I installed Y upper board, and the Y main.
    Turn on TV for 10 seconds.
    Top side of the picture is good and clear.
    I removed upper Y board, and installed lower Y board.
    Bottom side of the picture is very bad, garbage on screen.
    D5022 diode short circuit again. Something kill it.
    I checked the Y buffers boards, no short circuit on both.
    I tried a second time the same operation with a diode 2 amps, same thing.
    What's going on?? All fuses are good.
    Another component of the Y main is in fault?
    Is it possible that IPM module (the big IC) is defective?
    Thank you for help.
  • asr
    Finding replacement diode iPad Pro 3rd gen A1701
    by asr
    Hello, I am looking for help to replace a damaged diode. The tristar was replaced and a diode was damaged in the process. I have a picture of the diode but dont have an exact donor. I mostly have macbooks for donors and only a few ipad and iphone boards. Diode part number: DSF01S30SCAP
    Im not sure where to find the ipad board number. Anybody have an idea where else this diode is used on other boards? Thanks....
    07-09-2024, 06:24 PM
  • unimatrix93
    TV backlight zener diode
    by unimatrix93
    Hello everyone, I'm repairing an LG TV backlight and I noticed some strange behavior when I touching the backlight strip with a missing Zener diode.
    So I replaced the leds on the strips and they seemingly working fine, but soon as I touch the strip which has a missing Zener diode the whole backlight turns off for a few seconds and then turns back on.
    Is this caused by the missing diode? If so what kind of zener diode should I use to replace it?.
    The led strips has 9 6V leds.
    02-10-2025, 12:13 PM
  • NicRac
    monowheel repair,Is the diode the problem?
    by NicRac
    Hello everybody☺️ I am glad to be here and looking forward to a good discussion.
    First of all, I am new here. Therefore I will shortly introduce myself.
    I am Nico and currently I study Physics.
    In my freetime I like to build and repair stuff. Especially big battery's.
    A few years ago I got myself an electric unicycle, monowheel or however you call that.
    The battery bms was broken so I replaced and resolder that. Nothing big.
    I used this thing for some years and had a lot of fun. Unfortunately I used it last time in heavy rain. Usually everything...
    07-26-2024, 06:13 AM
  • dennis_elx33
    NO BODY MARKING Diode
    by dennis_elx33
    Hello Everyone,
    I have 1 diode on a circuit that I suspected to be faulty because the forward and reverse bias has a voltage drop reading.
    While compared to the reading of another diode from the next channel it won't read at reverse bias.
    Now the problem is; it does not have any body marking.
    So I tried to sketch the diagram and found out that it is connected to the base and collector of the C3632 transistor.
    What do you think is this diode?
    Can you please suggest what part number can i use to replace this faulty diode instead?
    Hoping that you...
    06-14-2024, 12:36 AM
  • eccerr0r
    Electric lawnmower...purpose of diode...
    by eccerr0r
    I was looking at an old battery powered electric lawnmower I picked up as the previous owner didn't want to buy a new board to replace a ruined old board. Tried to study how it was designed - it appears it has a huge 80A contactor...or rather, a 80A relay. It appears to be SPDT to control the motor. A 30A relay protects the circuitry.
    The weird thing I don't quite get is how this thing is connected. The common contact is connected to the motor. The NO contact is connected to the battery, which is expected, so when the relay is activated, the common is connected to the NO contact and...
    08-27-2022, 12:54 PM
