LG 42PX5D-EB ‘Power Issues’ Please Help
  • DOOGYREV
    • Jan 2012
    • 6
    My Plasma TV will not turn on, Please help!
    I need some advice with regards to my plasma TV, after a lot of googling I thought that blown capacitors might be the problem, but on visual inspection they all seem to be fine, so further searching led me to this forum where I thought I would find the answer, but after reading a lot of other posts can't seem to find exactly what I am looking for, so as you seem a friendly helpful bunch I thought I might as well ask, as you never know.
    My electronic knowledge is basic (I built a radio, a calculator and some knight rider flashing lights at college 20 years ago on a breadboard) I can use a soldering iron and have a multi-meter.
    I have owned the TV from when it was new at least 5-6 years now.
    The last thing to happened before it stopped working, was that the power got (accidentally) switched off at the wall socket while the TV was on, the TV was plugged into a basic 4 socket gang which was plugged into the wall (no surge protection)
    I hadn't wanted to do this but also thought that it would be fine, so I didn't pay too much attention to the colour of LEDs when I turned the power on again some 3 hours later,
    although there was defiantly some LED activity and some clicking this one time the set would not turn on.
    After unplugging it for 24hours, I get no LEDs and not even a click.
    What I have noticed which may or may not be relevant is
    Whenever I have connected the power cord I have heard ‘arcing' just before It is fully inserted
    When there has been a power cut in the past the TV has had to be unplugged and plugged in again before it has worked.
    Upon opening the back, what I have noticed is a light comes on briefly when I connect the power
    ‘5V ST CON' and the Coils - L1102, L11O3, L11O4.( 26UH 1UEWPHY 22.5TURN YL-9N 0.4) Look like they may have overheated?
    Any Help would be greatly appreciated
    Doogy
    Re: LG 42PX5D-EB ‘Power Issues' Please Help
    Those coils are probably fine; if the coil appears blackened it will not work (as the ferrite core stops being magnetic.)
    If you press the power button, what happens?
    Check the AC detect pin coming out of the power supply as well.
    • DOOGYREV
      • Jan 2012
      • 6
      Hi Tom,
      When I press the power button nothing happens.
      The AC Detect Pin, Is that the AC-ON that I have pointed out in the photo?
      If so, To check this Do I test the voltage between the AC-ON & GND?
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • PantherDave
        by PantherDave
        Hi all!
        05-29-2024, 02:01 PM
      • GLISIT
        by GLISIT
        01-16-2025, 02:29 PM
      • zlr8r
        Dell inspiron 17 (7786) - DP/N 09P7JP - odd power issues, starting with no power LED
        by zlr8r
        hey guys, hoping for some pointers to repair an eBay bought "faulty" laptop.
        Ill try and give as much info as I can.
        Dell Inspiron 17 (7786) Laptop
        Service Tag: 5J0NHT2
        Bios: 1.9.0
        When I received this , it would only flicker on the KB backlight for a second, then off and on.
        Then it started getting weirder!
        Sometimes when attaching the AC power supply, and pressing various pre-boot diagnostic keyboard keys... it did try to boot, in fact out of a hundred attempts, the laptop did actually boot into the Bios ! but never has...
        12-12-2023, 09:31 PM
      • sli4
        Original NES power issues
        by sli4
        I recently turned on my old NES to find the red light won't go on at all. When powered on it shows black bars on the tv and a loud buzz through the tv speakers. Powering it off, the buzz goes away and tv goes back to normal (white snow).
        I tested the power supply itself and it is outputting 9V as it should - first two solder joints on the board at the power port show the same.
        Here's where it starts getting funky - When powered on, one side of the 7805 voltage regulator is showing 18V and the other is about 8.7V (center 0).
        On the big blue connector I get...
        11-28-2024, 12:52 PM
