Zenith Z50PG10 - Voltage Discrepancy 60V vs 5V ?!
  • gopro25
    • Jan 2012
    • 23
    Re: Zenith Z50PG10 - Voltage Discrepancy 60V vs 5V ?!
    Originally posted by tom66
    Where are you? I picked up a good 20 MHz analog scope for £60 including one 10X probe. I use that for all my plasma TV repairs because it has a 400V rated input. (I have a second scope for bench stuff only.)
    I'm in Tucson, az, US
    Just so I have something to try to work out before I get the scope, which boards, would you say, are the most likely culprits, in order, to be causing the lack of screen display?
    Thanks very much for your help so far.
      Y-sustain followed by Z-sustain followed by power supply followed by everything else.
      • gopro25
        • Jan 2012
        • 23
        Until I get the scope, is there any way that I can narrow down the options with just my multimeter?
          Check the voltage between these pins, should be close to 5V.
          • gopro25
            • Jan 2012
            • 23
            Yup. It varies slowly between 4.98 and 5.01 according to my tester.
            Also, here are some admittedly bad pictures of the Z-sustain and main boards.
            If clearer images are needed, I can try tomorrow in the sunlight.
            I circled the two fuses I found on each board. All tested good.
            On the main board, the wires that lead to the Y-sustain and Z-sustain tested as follows while unplugged:
            Vs:193.6V
            N. C: Goes from 0-197V increasing at a rate about 20-30V per second
            Va: 59.6V
            M5v: 5.06V
            On the main board, the wires that lead to the input board tested as follows:
            16v: 16.41V
            12v: 12.07V
            5v: 5.09V
            AC_DET: 5.07V
            5V_DET: 5.07V
            VS_ON: 3.27V
            RL_ON: 4.57V
            AUTO: 0
            M5V_ON 3.27V
            On the Z-sustain board, I don't see much to measure.
            I did see a little green resistor marked VZb+.
            That measured 98.3V.
            • gopro25
              • Jan 2012
              • 23
              #26
              Also before you mention it, I found the 3rd fuse on the Z-sustain board. It's good too.
                Okay, so it looks like the supply voltages are okay. Do you hear any buzzing from either sustain board? Unplug one to confirm. It will be faint, high pitched whining, if the board is working.
                • rpgruss
                  • Jan 2012
                  • 124
                  You can also touch the heatsinks on the y and z sustain boards. They will be warm if the board is working.
                    I would avoid this while it is running - you cannot be sure if the heatsinks are connected to any part of the sustain board electrically. If it's off (unplugged), that's fine.
                    • gopro25
                      • Jan 2012
                      • 23
                      #30
                      Upon powering on Y-sustain starts off sounding like a very quiet scanner for half a second then goes to the high pitched ringing seemingly coming from the yellow transformer.
                      Z-sustain groans. Deep, Higher, Deep, Distorted.
                      Does this mean Z sustain is the problem?
                        Upon powering on Y-sustain starts off sounding like a very quiet scanner for half a second then goes to the high pitched ringing.
                        That suggests a faulty Z-sustain. Is that with Y-sustain unplugged?
                        • gopro25
                          • Jan 2012
                          • 23
                          #32
                          Ah, right.
                          With Y-sustain unplugged, the Z-sustain growling falls silent.
                            Ah, right.
                            That suggests that the boards are synchronised in some way, I suspect the Z-sustain to be failed, but they usually go silent when faulty.
                            If you unplug the Z-sustain you should get a very faint, but visible image. It might only be visible in the corner of the screen, and it will likely be very motion blurred.
                            Also, check any diodes and MOSFETs that are visible on the board, if you can. You can use your multimeter's diode check. Check all combinations of pins. Diodes should conduct one way (dropping 200 - 800mV) and not the other. MOSFETs should appear completely open circuit.
                            • gopro25
                              • Jan 2012
                              • 23
                              #34
                              I am confused.
                              I unplug the Z-sustain board, but I get no image change on the screen. It remains unlit and without picture.
                              Also, I just noticed, the main power board makes a deeper humming sound too.
                              I am confused testing the MOSFETS...
                              This page gives relatively clear instructions...
                              http://www.sentex.ca/~mec1995/gadgets/mostest.htm
                              It also says that I need to have a multimeter with a diode test voltage of 3.3V or more... Looked mine up, it's 1.5.
                              Does this mean I can't test?
                              Each one seems to do something different.
                              Between source and gate on the ones I see:
                              .551
                              .613
                              .000
                              .830 big one
                              .830 big one
                              .559 big one
                              .559 big one
                              .000
                              When I switch the positive to the drain pin I get no connection sometimes and other times wonky numbers again.
                              Also, I don't see anything that looks like a diode.
                              help...
                              • gopro25
                                • Jan 2012
                                • 23
                                #35
                                bump
                                  Sorry, I missed your post - if you're getting zero between source and gate that signifies a problem with the MOSFET. Check between source and drain too.
                                  • LeeElectrode
                                    • May 2012
                                    • usa
                                    #37
                                    My name is Lee and I'm new to this forum. I picked up a Z50PG10 free off of Craigslist and thought I would give the repair a shot. I've been in electronics and computers all my life so I'm pretty at home around components. I have a scope an am ready to dive into this beauty. This thread seems to have just dropped off and I'm wondering if Tom66 ever got the unit fixed and what was the solution. Anyone have any news?
                                    Lee
                                      Lee
                                      Not my unit - no idea if it got fixed - OP just stopped posting.
                                      I would suggest you start a new thread, and take some nice, clear pictures of the boards. Also, are your symptoms the same (no picture?) Any sound? Does the screen glow, even slightly? etc.
                                      With a scope, it is much easier to debug a plasma.
                                      • electronicsurplus
                                        • 210
                                        Has anyone ever seen a YSUS with ONLY the top being defective? I have tried several Upper Buffers and the same result. (With the upper removed I have bottom but, no top
                                        When Upper Buffer is installed there is no backlight nor video
                                        Any ideas?
                                        This Forum absolutely the best and, the most helpful forum I have ever found anywhere. thanks to all the fantastic members here
                                        Help keep these from the landfills
                                        • newtothis
                                          • Mar 2013
                                          • 1556
                                          • england
                                          #40
                                          All buffers received free from shorts on check?
                                          • legg
                                            LG 42PC3 buffer output doesn't follow YSUS
                                            by legg
                                            LG42PC3D -UD originally with green lamp but no display or audio.
                                            Owner says was working, then went 'pop'.
                                            All 5V caps bulging. replaced.
                                            All PSU output voltages within spec but -Vy is low on YSUS.
                                            One of three parallel fets between SUS_OUT and SUS_DN is zenering,
                                            eventually shorts DG. Replaced all 3 - -Vy now OK.
                                            Y scan buffer test point does not follow YSUS output below -50V
                                            Note: This unit seems to expect YSUS output to park at -Vy in between
                                            drive signal pattern periods. A replacement drive signal board confirms this....
                                            11-18-2021, 11:49 AM
                                          • howardc64
                                            by howardc64
                                            07-24-2025, 05:17 PM
                                          • Fernon@Repair
                                            Gigabyte Z490 Gaming X Motherboard No VCORE Voltage
                                            by Fernon@Repair
                                            i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
                                            VCCIO voltage ok
                                            VCCSA Voltage OK
                                            VCCPLL Voltage OK
                                            Ram Voltage ok
                                            RamVTT OK
                                            VPP 2.5 OK
                                            But No Core Voltage
                                            and i want to this vrm ic datasheet or pinout (ISL69269)
                                            anyone have this ic pinout voltages?...
                                            06-25-2025, 07:19 AM
                                          • electron_jj
                                            Panasonic TH-L42D25A checking the PSU output voltage
                                            by electron_jj
                                            Hi Everyone, I am new to this forum. I have a Panasonic LED TV which doesnt turn on and is blinking 4 times repeatedly when I turn on the switch. The TV does not respond to the remote control so I had to turn on using the physical switch on the side of the TV. When I turn on the switch the 4 x blinking starts and repeat itself until I turn off the TV. There is a black screen. I turned off the light in the room to check the panel and I think there is no backlight as far as I can tell.
                                            I have been inspecting and testing the capacitors and diodes in the power supply board to try to...
                                            08-29-2021, 08:13 AM
                                            Trip light 2400 watt line conditioner bought used issue with low voltage oscillation going on between relays
                                            by sam_sam_sam
                                            I found two capacitors on the board and one of the leads on one capacitor had bad soldering joint and the other joint connections not much better and there were several soldering joints that way to much flux around the joint redid several of them
                                            The capacitors were a non brand that I did not recognize they got replaced and now it does not oscillating between relay but what concerns me a little bit is when the voltage is a little bit low the output voltage is around 130 volts and then drops down to 115 volts this happens around 105 to 108 volts if remember correctly
                                            Now...
                                            06-09-2024, 10:57 AM
