LG 42pc1d issues
  • QuantumCheese
    • Jan 2012
    • 35
    LG 42pc1d issues
    I have an LG plasma model 42pc1d which has issues.
    the whole screen is quite dim, the colours are, put simply, wrong and any areas that are dark turn complete black and then take a long time or a very bright picture to 'burn off'.
    I have already replaced 9 caps (3300uf 10v) on the main psu board the rest (of the big ones) test OK, the next cheapest thing i belive is a y-sus hybrid on the y-sus board, however all the info i can find on this model/fault is for total black screen with ok audio, whereas i have partial black with ok audio.
    and the failure mode for the y-sus appears to be 'with a bang' but in this case the fuses are fine and nothing seems to have visually popped - what do you think?
    Cheers.
    ps. (i'm new to plasmas but have fixed CRT's for many years)
    Re: LG 42pc1d issues
    This is a Z-sustain failure; the board opposite the Y-sustain. You will get a dim, purple tinted picture if this is failed. See this post for info on how to diagnose this problem.
    As it's an LG, it could be the hybrid. Or the Zbias supply. Or another problem. The hybrid is the most common cause.
    I have an LG 42PC1D and I simulated a Z-sustain failure by unplugging the Z-sustain power. I got exactly the same problem you describe, does your TV look a bit like this? (Excuse the camera shake.) Of course, in my case, I deliberately made it fail, but plugging it in fixed the problem immediately.
    • QuantumCheese
      • Jan 2012
      • 35
      Hi, thanks for the super quick response.
      Yea that looks a little like it. I'll try unplugging mine & see what changes!
      I was a little unsure if it was OK to power just bits of it without accidentally blowing up the 'other bits'!
      Cheers, dude.
        Cheers, dude.
        Most Plasma troubleshooting manuals suggest unplugging boards is okay. Wouldn't unplug the control connectors (small signal cable) without unplugging the power at the same time, as it could cause the board to go a bit crazy (but I've never tried it.)
        • QuantumCheese
          • Jan 2012
          • 35
          well, thanks for the info but that would appear to not be it!
          looking from rear. there is a board on the right that says z-sus on it. there is a board on the L which says Y drive. this is plugged into a board that look eerily similar to the z-sus board on the other side. don't worry, there is a point!
          i unplugged the board marked z-sus and half the screen went off-black (vertial split). the rest of screen stayed on and with same problem.
          so i unplugged the power to the "board on the left with no label" - the whole screen goes black.
          In the service manual i 'obtained' it shows a board all the way down the left (view from rear) and calls it y-drive. and shows a board on the R called z-sus. it also shows a board on the left plugged into the y-drive without a label - so i'm guessing it has two, one for each half of screen?
          In addition to original description it's not all purple in the distortion, the colour look a bit purple, but very solarised. luckily the snooker was on and for a short time you could make out that the table was green but it then deteriorated on the dark bits becoming permanent black. by changing channel to something brighter the screen starts to come back to life.
          (apologies for long description, it's really hard to describe!)
          I guess my point it though, it's not the z-sus! any more ideas?
          (or if it is it's not quite completely broke)
          • QuantumCheese
            • Jan 2012
            • 35
            If you can recommend one of these manuals & where to get it from i would appreciate that too - I must have spent a couple of hours trying to find a book on plasma internals today !
            • cliff_hootarski
              • Jul 2006
              • 411
              Go to http://elektrotanya.com/?q=keres type in you model. It looks like it's there.
              • QuantumCheese
                • Jan 2012
                • 35
                Thanks. the one there's a bit more detailed than the one i had.
                plenty of digital schematics, seems to omit the psu's though
                Definitely looks like a place worth bookmarking though - Cheers!
                • cliff_hootarski
                  • Jul 2006
                  • 411
                  You might also try LG training manual. Show quite a few.
                  • QuantumCheese
                    • Jan 2012
                    • 35
                    Thanks missed that!
                    "never be afraid to point out what is to you the bleedin obvious"
                    • QuantumCheese
                      • Jan 2012
                      • 35
                      if your familiar with the training manual it looks like the symptom described as
                      "The blue spreads on the screen (Mis-discharge)
                      and power off in 2 ~ 3 seconds.
                      If you turn on again, it will be same problem"
                      though the set doesn't turn itself off it does look a lot like that
                      • cliff_hootarski
                        • Jul 2006
                        • 411
                        Perhaps if you loaded up some pictures of the tv without the back cover on, we could try to determine which board is the Zsus.
                        • QuantumCheese
                          • Jan 2012
                          • 35
                          Thanks, I think i've worked out what a z-sus board is now. the rtfm would appear to suggest i look into the 'x board'. i'm just trying to work out how to get to it to test as it's in two parts & all the way along the bottom of the unit, and behind EVERYTHING!
                            No, the problem is most likely your Z-sustain. The Z-bias voltage can fail and sometimes just one of the two sustain fuses (each fuses a different supply, Vs or Va) could be blown.
                            • pecrie
                              • Nov 2011
                              • 182
                              it could be the x board ,if your picture on the screen ,is all very clear and with the right colours.And then you should have a good picture ,only half of the panel.
                              Since your screen image is not oke ,I would first investigate ,in the IPM`s.There are 2 of them ,on the Z - sus board and one on the Y - sus board.The board ,you said ,that has no name.
                              The IPM`s are attached to the big black ( or aluminin) heat sinks.In the training manual ,there probably is a part ,showing how to test the IPM for shorts.
                              Like Tom66 said ,it is probably the IPM on the Z-board ,which is at fault.But test it ,to be sure
                              good luck
                              • cadiman
                                • Mar 2010
                                • 397
                                Boards along the bottom will give you vertical bar or half a screen Left or right side.
                                (if unplugged).
                                As said above you most likely need a "z" board.
                                • QuantumCheese
                                  • Jan 2012
                                  • 35
                                  Thanks all for comments so far,
                                  I *had* ruled out the z board mainly because unplugging it just made half the screen disappear but also because the training manual (albeit for a slightly different LG plasma) had only one 'fault picture' that looked like the fault i'm seeing and it didn't link it to a z-sus fail but instead an x-board. I shouldn't rule out the training manual being wrong i guess as the service manual lists the pin-outs of two connectors on the psu the wrong way round!
                                  I've tested both the (white) fuses on both the boards. there all OK
                                  the Va and Vs voltages are within tolerance (0.5v) of the sticker on the set. also the 19V and the 3.4 and 12 are bang on. I can't find a 15V as the training manual suggests the slipping of which to 14V or lower will cause this issue.
                                  I was hoping it wasn't the 'IPM' as you call it, as there are two of them and there a £40 part - unless anyone out there knows cheaper? I couldn't see anything in the service manual about how to test them and the service manual only really goes to board swapping diagnostic levels anyway.
                                  I will try and upload a picture of a test card on it today
                                  If we go all the way back to the top of this thread and tom66's original suggestion of unplugging the z-sus board (the one on the right with the thick red and blue power feed) - i did and half the screen went black. by his logic it should have made no difference i believe?
                                    Do you have a scope & 10X probe?
                                    • QuantumCheese
                                      • Jan 2012
                                      • 35
                                      Some screen shots.
                                      1st one is an Full White test,
                                      2nd standard test card
                                      3rd standard test card on a working monitor for ref
                                      4th an image off the tv of i think a beach.
                                      it does look very purple on the full white now i look at it
                                      tom66 - scope & probe not a problem. if it starts to get serious, i have 2 scopes, 2 sig-gens 5 channels of bench supplies, 2 variacs and a 200w dummy load in my lab
                                        Jealous. Only one variac, one bench supply and two scopes .
                                        Set your probe to 10X and make sure probe is 600V rated. Probe the Z-drive FFC output and check if the waveform is present (set scope to 5V/div, 100ms/div.)
                                        • npielawski
                                          MacBook Pro late 2016 (820-00239) with multiple failure modes.
                                          by npielawski
                                          I will just preface all this by saying that I have a fairly technical background but have never attempted SMD electronics diagnostics and repair before, I really like the idea and want to learn.
                                          I have a MacBook Pro late 2016 that died maybe four years ago. Over the course of 30 seconds, it got slower and stuttered, until it froze for a second and died. No click from the trackpad anymore, nothing. I started getting interested in electronics repair and decided to give it a shot, so I opened it, removed the battery (one cell was puffy), took out the motherboard and experimented with...
                                          10-15-2025, 01:53 AM
                                        • gretti
                                          MSI Z370-A Pro, works but does not power off or reboot and USB issues
                                          by gretti
                                          I have a MSI Z370-A Pro. The board does not reboot or shut down from the Windows recovery console. USB communications stop and the status light on USB 1 stays on and does not blink. I have programmed a new BIOS with a CH341A programmer already, swapped RAM, PSU, CPU. The board will power off when the power button is held and resets when the reset switch is pressed, but it will not react to the reset switch if already told by software to shut down or restart. The board will reboot from BIOS after a save and exit command.
                                          The MSI BIOS included the ME firmware for the board. The size...
                                          10-16-2025, 02:14 AM
                                        • PlasMatt
                                          LG 60PV450 Possible Bad YSUS Need help confirming Diagnosis
                                          by PlasMatt
                                          I have an LG plasma that after reading through a bunch of posts and doing some testing I believe has a bad YSUS board. The problem is that that doesn't make sense to me for some of the symptoms. The problem started yesterday. While watching a movie the TV just shut down like I pressed power. I have it hooked to a PC and use RS232 to turn it off and on so I thought maybe something had glitched there. I turned it back on and finished the movie with no problems. The same thing happened today so I checked logs to see if something in the control glitched and sent an off command but it didn't, After...
                                          09-20-2025, 06:50 PM
                                        • legg
                                          LG 42PC3 buffer output doesn't follow YSUS
                                          by legg
                                          LG42PC3D -UD originally with green lamp but no display or audio.
                                          Owner says was working, then went 'pop'.
                                          All 5V caps bulging. replaced.
                                          All PSU output voltages within spec but -Vy is low on YSUS.
                                          One of three parallel fets between SUS_OUT and SUS_DN is zenering,
                                          eventually shorts DG. Replaced all 3 - -Vy now OK.
                                          Y scan buffer test point does not follow YSUS output below -50V
                                          Note: This unit seems to expect YSUS output to park at -Vy in between
                                          drive signal pattern periods. A replacement drive signal board confirms this....
                                          11-18-2021, 11:49 AM
                                        • puccovelli
                                          Dell 9310 Memory or RAM (Random-Access Memory) failure (2,4)
                                          by puccovelli
                                          Hi all, I hope this is the right place to post.
                                          I'm having a problem with a Dell 9310 which is posting 2 orange, 4 white lights on startup (hangs on Dell BIOS logo). The service manual says its a RAM failure.
                                          I've taken the motherboard out and noticed that one of what looks like an SMA 0805 resistor has blown (see photo). The board is an LA-J144P Rev 2.0(A01).
                                          1] Could someone confirm what the component that has blow actually is (and where I could get another from).
                                          2] Whether this component is likely to cause the RAM failure issue, and if replacing...
                                          10-11-2025, 06:30 AM
