LG 42pc1d issues
  • cliff_hootarski
    • Jul 2006
    • 411
    Re: LG 42pc1d issues
    I believe I recall seeing a way to test IPM's for shorts on Coppell's TV repair blog.
    http://blog.coppelltvrepair.com/2011...s-ipm-for.html
    • QuantumCheese
      • Jan 2012
      • 35
      Originally posted by tom66
      Jealous. Only one variac, one bench supply and two scopes .
      Set your probe to 10X and make sure probe is 600V rated. Probe the Z-drive FFC output and check if the waveform is present (set scope to 5V/div, 100ms/div.)
      Flat as a pancake. about 20V dc on it - I think we have a winner here?
        Yep, that's bad.
        Check if there is 5V DC past the SMD fuse and if there is a 15V supply check that. (I can't remember if the Z-sustain has a 15V supply; but the Y-sustain definitely does.) The 15V is generated from the 5V input, I think.
        • brogdan
          • 18
          hello
          i also have a problem with a LG 42PC1D
          it came with blown fuse and shorted hybrid on ysus
          i changed the hybrid and the fuse, all power supply voltages are ok, but still no image.
          do you have any ideea?
          \i saw that on the mainboard(digital) there are some LEDs: L300 is off and L500-503 are on
          • npielawski
            MacBook Pro late 2016 (820-00239) with multiple failure modes.
            by npielawski
            I will just preface all this by saying that I have a fairly technical background but have never attempted SMD electronics diagnostics and repair before, I really like the idea and want to learn.
            I have a MacBook Pro late 2016 that died maybe four years ago. Over the course of 30 seconds, it got slower and stuttered, until it froze for a second and died. No click from the trackpad anymore, nothing. I started getting interested in electronics repair and decided to give it a shot, so I opened it, removed the battery (one cell was puffy), took out the motherboard and experimented with...
            10-15-2025, 01:53 AM
          • gretti
            MSI Z370-A Pro, works but does not power off or reboot and USB issues
            by gretti
            I have a MSI Z370-A Pro. The board does not reboot or shut down from the Windows recovery console. USB communications stop and the status light on USB 1 stays on and does not blink. I have programmed a new BIOS with a CH341A programmer already, swapped RAM, PSU, CPU. The board will power off when the power button is held and resets when the reset switch is pressed, but it will not react to the reset switch if already told by software to shut down or restart. The board will reboot from BIOS after a save and exit command.
            The MSI BIOS included the ME firmware for the board. The size...
            10-16-2025, 02:14 AM
          • PlasMatt
            LG 60PV450 Possible Bad YSUS Need help confirming Diagnosis
            by PlasMatt
            I have an LG plasma that after reading through a bunch of posts and doing some testing I believe has a bad YSUS board. The problem is that that doesn't make sense to me for some of the symptoms. The problem started yesterday. While watching a movie the TV just shut down like I pressed power. I have it hooked to a PC and use RS232 to turn it off and on so I thought maybe something had glitched there. I turned it back on and finished the movie with no problems. The same thing happened today so I checked logs to see if something in the control glitched and sent an off command but it didn't, After...
            09-20-2025, 06:50 PM
          • legg
            LG 42PC3 buffer output doesn't follow YSUS
            by legg
            LG42PC3D -UD originally with green lamp but no display or audio.
            Owner says was working, then went 'pop'.
            All 5V caps bulging. replaced.
            All PSU output voltages within spec but -Vy is low on YSUS.
            One of three parallel fets between SUS_OUT and SUS_DN is zenering,
            eventually shorts DG. Replaced all 3 - -Vy now OK.
            Y scan buffer test point does not follow YSUS output below -50V
            Note: This unit seems to expect YSUS output to park at -Vy in between
            drive signal pattern periods. A replacement drive signal board confirms this....
            11-18-2021, 11:49 AM
          • puccovelli
            Dell 9310 Memory or RAM (Random-Access Memory) failure (2,4)
            by puccovelli
            Hi all, I hope this is the right place to post.
            I'm having a problem with a Dell 9310 which is posting 2 orange, 4 white lights on startup (hangs on Dell BIOS logo). The service manual says its a RAM failure.
            I've taken the motherboard out and noticed that one of what looks like an SMA 0805 resistor has blown (see photo). The board is an LA-J144P Rev 2.0(A01).
            1] Could someone confirm what the component that has blow actually is (and where I could get another from).
            2] Whether this component is likely to cause the RAM failure issue, and if replacing...
            10-11-2025, 06:30 AM
