Samsung 50 Plasma donated to me.
  • Ghssoccer1
    • Jan 2012
    • 21
    Re: Samsung 50 Plasma donated to me.
    Ok. perfect. thats what I needed to know, So I'm at least in the right place and moving in the right direction. I tested a little bit more last night and found this....The tv only has issues when its unplugged and plugged back in, OR when the Surge protector is turned off. As long as the power isn't disurupted at the source in anyway, it seems to be o.k.
      I would check the line filter or the power connector... bbjunkie seems to have found a plasma with a faulty one, they are reasonably cheap.
      • Ghssoccer1
        • Jan 2012
        • 21
        It will take me a bit to hit all the joints. But ill get it done. And what should i be looking for on the filter? Power connecter literally being where the plug comes in or?? Sorry for my electrical eptitude. Im more of a car guy, but luckily smart enough to feel i can do this.
          Have you got a multimeter?
          • Ghssoccer1
            • Jan 2012
            • 21
            Yes I do.
              Check if the voltage coming out of the line filter drops out when the picture goes blank.
              • Ghssoccer1
                • Jan 2012
                • 21
                #27
                The screen never goes blank really.. If its on, its on. It only has a problem when it warms up and you either unplug it or turn off the surge protector. In which case, it doesn't "click" when you plug it back in, it just sits. After a period of time to "cool" it will turn back on without issue.
                • Ghssoccer1
                  • Jan 2012
                  • 21
                  #28
                  Luckily I'll be able to flow that whole board this weekend.
                  • Ghssoccer1
                    • Jan 2012
                    • 21
                    #29
                    Redid the major spots on the board. seemed to work....or so I thought. still having an issue with it wanting to not "click" when I unlug it directly, or shut the power strip off.
                      Hmm. I had this problem on an LG Plasma except it would always click on/off and never wanted to stay on once it was on... first I thought it was bad caps but even after replacing them it was still stuck clicking... so I narrowed it down to the AC Detect pin on the power supply. Check this pin, it should be 5V when power is plugged in and 0V with no power.
                      • Ghssoccer1
                        • Jan 2012
                        • 21
                        #31
                        Today, i have nothing. No power. I have the red LED light up front telling me I'm getting power in, but as far as the rest. Nothing, no clicks, no sounds no screen nothing. Now what?
                          How are the output voltages in the fault condition?
                          It sounds a lot like bad caps or a bad solder joint.
                          • Ghssoccer1
                            • Jan 2012
                            • 21
                            #33
                            Well the time came where I just dropped this one off at the shop. Thanks for all the help guys. I simply just couldn't devote the time to this like I wanted. Work and school consumed me and it fell to the wayside. Again thanks for all the help. and Hopefully I can try again later. I'll post what the shop tells me upon its return.
                              Ah well. They will come back with a quote for far more than it's worth. Sell it on eBay or craigslist or gumtree.
                              • Ghssoccer1
                                • Jan 2012
                                • 21
                                #35
                                hahah I know. but at least then I can just tell someone "HEY, this is what they said"
                                • Ghssoccer1
                                  • Jan 2012
                                  • 21
                                  #36
                                  Digital processing board.
                                    Is it fixed? I think they mean main board but they could also mean T-con board (plasma TVs have T-con boards too but they are less prone to failing.)
                                    • Ghssoccer1
                                      • Jan 2012
                                      • 21
                                      #38
                                      Correct, fixed.
                                      • hsumer
                                        • Jul 2012
                                        • Istanbul,Turkey
                                        #39
                                        I have same TV with no Picture problem.TV is on and You can hear sound but screen is blank no back light
                                        • Asraf Atb
                                          by Asraf Atb
                                          01-27-2025, 05:02 PM
                                        • Dani_2024
                                          by Dani_2024
                                          10-28-2024, 05:06 PM
                                        • ygorsan
                                          by ygorsan
                                          🧩 Problem Summary:
                                          • I
                                          07-28-2025, 08:34 AM
                                        • Lee M.
                                          Samsung UN75RU8000FXZA bad main board?
                                          by Lee M.
                                          When plugged in it will click and cycle the BL on and off, no pic and does not respond to remote. When I disconnect the cable from the PS board to the main board and then plug it in the BL will come on and stay on. There are only two boards in this set, the LVDS cables from the panel driver boards connect directly to the main board. Since the BL comes on and stays on I'm thinking the PS board is ok and the problem is on the main board. Should I order another main board or do I need to do more testing? thanks, Lee
                                          11-08-2023, 07:46 PM
                                        • dokma
                                          Samsung 50" plasma PS50Q97 with a dead main board
                                          by dokma
                                          Hello forum!
                                          This is my fourth post so I will try to start on the right foot by doing it properly right off the bat. I bought this plasma faulty to play around with. The main board is completely burnt. When I unplug everything but the power supply and the main board and I plug in the power chord I get plenty of smoke from the main board.
                                          Now, the model of the TV is a bit of a detective work. I couldn't find the model of the TV anywhere on the back cover or inside so I deduced it from the main board codes. SO I THINK this is PS50Q97.
                                          Now, since the board is...
                                          07-05-2020, 07:52 AM
