Samsung 50 Plasma donated to me.
  • Ghssoccer1
    • Jan 2012
    • 21
    Re: Samsung 50 Plasma donated to me.
    Ok. perfect. thats what I needed to know, So I'm at least in the right place and moving in the right direction. I tested a little bit more last night and found this....The tv only has issues when its unplugged and plugged back in, OR when the Surge protector is turned off. As long as the power isn't disurupted at the source in anyway, it seems to be o.k.
      I would check the line filter or the power connector... bbjunkie seems to have found a plasma with a faulty one, they are reasonably cheap.
      • Ghssoccer1
        • Jan 2012
        • 21
        It will take me a bit to hit all the joints. But ill get it done. And what should i be looking for on the filter? Power connecter literally being where the plug comes in or?? Sorry for my electrical eptitude. Im more of a car guy, but luckily smart enough to feel i can do this.
          Have you got a multimeter?
          • Ghssoccer1
            • Jan 2012
            • 21
            Yes I do.
              Check if the voltage coming out of the line filter drops out when the picture goes blank.
              • Ghssoccer1
                • Jan 2012
                • 21
                #27
                The screen never goes blank really.. If its on, its on. It only has a problem when it warms up and you either unplug it or turn off the surge protector. In which case, it doesn't "click" when you plug it back in, it just sits. After a period of time to "cool" it will turn back on without issue.
                • Ghssoccer1
                  • Jan 2012
                  • 21
                  #28
                  Luckily I'll be able to flow that whole board this weekend.
                  • Ghssoccer1
                    • Jan 2012
                    • 21
                    #29
                    Redid the major spots on the board. seemed to work....or so I thought. still having an issue with it wanting to not "click" when I unlug it directly, or shut the power strip off.
                      Hmm. I had this problem on an LG Plasma except it would always click on/off and never wanted to stay on once it was on... first I thought it was bad caps but even after replacing them it was still stuck clicking... so I narrowed it down to the AC Detect pin on the power supply. Check this pin, it should be 5V when power is plugged in and 0V with no power.
                      • Ghssoccer1
                        • Jan 2012
                        • 21
                        #31
                        Today, i have nothing. No power. I have the red LED light up front telling me I'm getting power in, but as far as the rest. Nothing, no clicks, no sounds no screen nothing. Now what?
                          How are the output voltages in the fault condition?
                          It sounds a lot like bad caps or a bad solder joint.
                          • Ghssoccer1
                            • Jan 2012
                            • 21
                            #33
                            Well the time came where I just dropped this one off at the shop. Thanks for all the help guys. I simply just couldn't devote the time to this like I wanted. Work and school consumed me and it fell to the wayside. Again thanks for all the help. and Hopefully I can try again later. I'll post what the shop tells me upon its return.
                              Ah well. They will come back with a quote for far more than it's worth. Sell it on eBay or craigslist or gumtree.
                              • Ghssoccer1
                                • Jan 2012
                                • 21
                                #35
                                hahah I know. but at least then I can just tell someone "HEY, this is what they said"
                                • Ghssoccer1
                                  • Jan 2012
                                  • 21
                                  #36
                                  Digital processing board.
                                    Is it fixed? I think they mean main board but they could also mean T-con board (plasma TVs have T-con boards too but they are less prone to failing.)
                                    • Ghssoccer1
                                      • Jan 2012
                                      • 21
                                      #38
                                      Correct, fixed.
                                      • hsumer
                                        • Jul 2012
                                        • Istanbul,Turkey
                                        #39
                                        I have same TV with no Picture problem.TV is on and You can hear sound but screen is blank no back light
                                        • Asraf Atb
                                          Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
                                          by Asraf Atb
                                          Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
                                          Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
                                          I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
                                          01-27-2025, 05:02 PM
                                        • mrautom8
                                          Samsung TV UN75H6350AFXZC main board schematics?
                                          by mrautom8
                                          Schematics for the main board needed please. Sticker on board states BN94-07517A but the silkscreen says BN41-02157B. Cant find here or anywhere on the web.
                                          Backlights work when main boards disconnected. When connected and power button switched, the relay on the PSU board turns on for one second then back off.
                                          While relay is on, all voltage rails are present and steady (scoped) on main board.
                                          I love a good logic puzzle but getting lost without any schematics.
                                          No shorts on ANY capacitor main board.
                                          Thermal camera shows 3.3V inductor getting warm instantly but...
                                          10-19-2025, 06:32 PM
                                        • alltvrepairs
                                          Plasma Samsung PS-50C96HD Main board BN94-01223C switches off supply after few seconds
                                          by alltvrepairs
                                          I have this almost brand new Plasma was well stored. I would like to repair it for a friend of mine.
                                          I have noticed that it works for few seconds then switches Off the Power_ On signal. Have disconnected boards and left maion board and power supply and still the same. The power supply with PS_ON and VA signals On stays on so it is not a problem in the power supply.
                                          Any one met this problem in the past?...
                                          10-08-2025, 07:34 AM
                                        • Dani_2024
                                          by Dani_2024
                                          10-28-2024, 05:06 PM
                                        • ygorsan
                                          by ygorsan
                                          🧩 Problem Summary:
                                          • I
                                          07-28-2025, 08:34 AM
