Toshibia 40rv525u Green Blinking light and questions about Caps!!
  • ComputerGeek
    • Oct 2011
    • 262
    Re: Toshibia 40rv525u Green Blinking light and questions about Caps!!
    Okay using the resistor to pull the pwr pin up to the +5v rail. I was getting a measurement that fluctuated between 0.16 then went up to 0.58 so there is no question that there is a problem with the standby part of the psu.
      Yes; either that or the pre-charge for the primary (it depends on the topology.)
      I've got to go now, but I'll post another test soon.
        Okay, let's try and make future tests easier:
        Unplug all power to TV, let it sit for a couple of minutes.
        Check the voltage across each big capacitor. Does it drop to nearly zero? This is for safety reasons. I want to know if it is safe for you to handle the board after it has been sitting for a couple of minutes.
        Now, we need to find the common ground for the primary. I suspect it will be the negative lead of the capacitor closest to the AC input, but I'm not certain. So, with the board still switched off, check the resistance from each lead of each capacitor on the 200 ohm range to pin 10. One should give nearly zero ohms.
        Oh, and double check you are definitely probing the pins I've highlighted which are 10 and 12 and not some other strange pins. Don't worry, I've done it too many times before :/.
        • ComputerGeek
          • Oct 2011
          • 262
          Hey, Thanks! Glad to see were getting somewhere in the testing.
          1. Yes the voltage across each big capacitor drains to about 5 volts in around a minute. And after a while the 5 volts drains too.
          2. Using the pin with the black arrow pin 10 I tested to the different Pins of the caps and found that the pin of C120 circled in the picture read 0.5ohms but touching my probes read about the same so it is basically 0ohms. Also that pin of the Cap is connected to ground by CY103 as you can see in the picture, which I believe is a cap.
          Also I probed pin 12 and noticed that it was also connected to the pin of C120 circled in the picture and that it read 5.5 ohms or around 5ohms with the probes taken out does this indicate a short?
          3. Double Checked that it was pins 10 and 12 still got a reading the was unstable going from 0.16 to 0.57 or so.
          Originally posted by tom66
          Okay, check the voltage between these two pins with PSON both high and low using the resistor.
          You should get around 9 to 16V if it is working okay, typically when PSON is high. When PSON is low, it might drop below 9V. If the voltage here isn't high enough, it points to a problem in the pre-charge or the standby power part.
          Also if I understood right you just wanted me to pull up the PWR pin with the resistor attached to the +5v rail is that correct?
          Thanks!
            Yes; that seems to indicate something is not right. Check the ohms resistance on the 200 ohm range between 10 and 12, if that shows up as about 5 ohms then it's probably failed. It's a fairly common failure with power supplies.
            Looks like the part is $4 on eBay: http://www.ebay.com/itm/L6599D-L6599...item415e5ae292
            or from DigiKey: http://search.digikey.com/us/en/prod...9-1-ND/2021190 + ~$3 shipping in USA. This part will arrive quicker.
            You will also need solder wick to remove the original and a steady hand to replace it. It might be a good idea to use a bit of glue to secure the new chip down whilst you try to solder it.
            Thanks!
            Yep. 5V standby.
            • ComputerGeek
              • Oct 2011
              • 262
              OK it 5.5ohms across the pins. Would this just fry by itself?
              Should I get more than one In case the new one frys, too? How can I tell if there isn't another problem?
              Also, what other components would you hold suspect? Since its cheaper to buy and have them all shipped in one shot what would you get?
              Thanks!
              • ComputerGeek
                • Oct 2011
                • 262
                Oh and what size and type solder wick should I get?
                  They do seem to do that. I'm guessing a mains surge might be responsible, or if they are operated for a long time near their limits. Or sometimes there can be a defective chip off the factory line.
                  That would be a good idea.
                  Thanks!
                  I don't think anything else at the moment is up. That short is a clue.
                    1.5mm is fine, make sure it has flux added. (Solder wick without flux is essentially copper wire and is useless for desoldering.)
                    • ComputerGeek
                      • Oct 2011
                      • 262
                      Is this right?
                      http://media.digikey.com/Photos/Multicore/M293366.jpg
                      Or do i get one with rosin?
                      http://search.digikey.com/us/en/prod...1087-ND/350542
                      • ComputerGeek
                        • Oct 2011
                        • 262
                        Ok if I pull the chip and the pads on the board still read 5.5 ohms does that mean there is a short on the board instead?
                          Yes, most likely. But the only path to ground is through that chip; unless Toshiba (or more likely, FSP, the people who designed it) have used a different circuit design.
                          • ComputerGeek
                            • Oct 2011
                            • 262
                            For desoldering wick Is this right?
                              First one is fine, second one is not found?
                              • ComputerGeek
                                • Oct 2011
                                • 262
                                I don't know what happened there,
                                http://search.digikey.com/us/en/prod...148-ND/2498946
                                w/rosin
                                I take that no clean has flux, since they have unfluxed?
                                  The Multicore stuff is all you need.
                                  • ComputerGeek
                                    • Oct 2011
                                    • 262
                                    Good news! I pulled the chip and its measuring 5.5 ohms without being in the curcuit. The board reads out of range. The new one is on order.
                                    • ComputerGeek
                                      • Oct 2011
                                      • 262
                                      I am getting my list together.
                                      I think I am going to replace a couple of the Caps when I have it apart.
                                      What is suggested as a replacement?
                                      I was only going to replace these Caps on the board.
                                      Replacing List
                                      All are Nippon Ky Series 105C Capacitors
                                      One 1000uf 25v
                                      Three 1000uf 35v
                                      Two 100uf 25v caps.
                                      One 10uf 50v
                                      One 22uf 50v
                                      One 47uf 25v
                                      Leaving List
                                      All Film/Mylar Caps
                                      All Ceramic Caps
                                      The Two Main Filter Caps
                                      The two 1500uf 10v YXG Series 105C Rubycon's
                                      Is that OK should I order any of the other ones?
                                      Also, I was just going to combine the 1000uf 25v
                                      and 1000uf 35v Caps and just get a lot of 25 or so of 1000uf 35v Caps is that ok?
                                      What is suggested as a replacement, should I get the same Series and Brand? I would like to try to get them all at Digi-Key, and the smaller Ky Series caps aren't in stock right now and i don't feel like waiting. Thanks!
                                      Thanks!
                                        There is really no need to replace the caps as the originals are very high quality United Chemi-Con and Rubycon - probably the two best capacitor manufacturers in the world. Don't fix something that's not broken . Toshiba obviously spent a few pennies extra to make the TV last longer, same for another Toshiba I have.
                                          Just remember when replacing the chip to make a note of which way around it goes - the little black detents should match up.
                                          • jxrepman
                                            Asus X453MA won't turn on and green led light blinking
                                            by jxrepman
                                            Hi there,
                                            I have this ASUS X453MA Laptop that's not turning on. When I plug in the charger, the green light just keeps on blinking and pressing the power button does nothing.
                                            I have checked the charger and it is giving 19+ V
                                            I have disconnected the battery and pressed power button for 30 seconds.
                                            I tried another RAM stick.
                                            Tried disconnecting the keyboard and touchpad.
                                            Tried disconnecting the HDD and the wifi adapter.
                                            The problem persists.
                                            Hope you could help me out on this one. Thank you.
                                            12-14-2024, 06:40 AM
                                          • MOSSEP
                                            Monitor Audio RSW12 - Green light, but no sound
                                            by MOSSEP
                                            Hi
                                            Im hoping someone might be able to give me some idea of what may be wrong with my Monitor Audio RSW12 Sub.
                                            Ive owned it since new in around 2002, so would really like to keep it running if I can, it was the first ‘decent' bit of audio equipment I ever purchased and is a little sentimental.
                                            The issue I had was that it would power up with the red light, but sometimes the green light would not come on and I would get no bass from it. If the green light did come on though, I would get sound out of it.
                                            I have already tried replacing all of the...
                                            01-26-2025, 08:33 AM
                                          • MOSSEP
                                            Monitor Audio RSW12 - Green light but no audio
                                            by MOSSEP
                                            Hi
                                            01-26-2025, 08:18 AM
                                          • lcdcaps1
                                            820-2610-A Sys onewire help, no green light. Please help from the gurus
                                            by lcdcaps1
                                            Hi
                                            I have an 820-2610-A motherboard that has no green light.
                                            I have noticed is when I do a SMC reset the light on the Magsafe blinks.
                                            From My understanding, the sys onewire circuit is responsible for the green light on the magsafe
                                            The sys onewire circuit on this model and others is more involved
                                            I was hoping if anyone knows about this and how it works, can reply and let me know
                                            I know this is an old model but I am sure there are people who still works on these or knows about them
                                            I get 1.1v on the C7771 capacitor and will replace...
                                            11-06-2023, 01:28 PM
                                          • naddaw000
                                            Toshiba 55U7863DG - green light blinking (17MB130S)
                                            by naddaw000
                                            Hello, I am trying to bring back to life my Toshiba 55U7863DG, which has never been the most reliable device - keep on annoying me with its slowness and some random start-up/shutdown issues requiring to unplug the AC. But yesterday it finally said goodbye and decided to not turn on again. Green light is blinking, I've seen this behaviour before and thought that these are some temporary whims again, but unfortunately not this time.
                                            I have checked that my TV is build based on the 17MB130S board, which seems to be quite popular and easy to buy as a used one. Still I would like to ask...
                                            12-02-2023, 01:35 PM
