Philips 47PFL5704D F7 No Power
  • kolpro
    • Jan 2012
    • 17
    Hello all and thanks in advance....
    I have been on this site for a few days now researching my problem and kind of have an idea of what my problem is. Long story short I have a Philips 47PFL5704D F7 and when it's plugged up I get no power at all. I opened the back and looked for the usual suspects being the caps and all seem to be good. But I did come across a IC chip (U101) labeled FVK31 "bottom line" FSQ510. This chip has 7 legs and the side with 3 legs is blown the leg is blown off the chip, so I think maybe replacing this chip may solve my problem. Then I begin to think what would have caused this problem and if I replace the chip will it blow again. So any help would be gladly appreciated.
    I also tried to find the chip and it seems that I can order off ebay from China for really cheap but do anyone know where I can get this from closer maybe radioshack? I live in Chicago.
    Thanks again.....
  • PlainBill
    • Feb 2009
    • 7034
    Re: Philips 47PFL5704D F7 No Power
    What the heck is going on here!!!! We had a bunch of threads that opened with something like "My TV dont work. how d o i fix itt?"
    Now you come along and give a great description, and provide excellent pictures. It's great.
    Sorry, you only get a silver star. If you had Googled buy FSQ510 you would have discovered Mouser Electronics in Texas has them available for $1.18, shipping will run $5, and you should have it on Saturday.
    PlainBill
    • retiredcaps
      • Apr 2010
      • 9271
      findchips.com is fast easy way to find parts as it searches all the major distributors for you.
      http://www.findchips.com/avail?part=FSQ510
      --- begin sig file ---
      --- end sig file ---
      • kolpro
        • Jan 2012
        • 17
        LOL.....Thanks for the fast response I googled FSQ510 but not "buy FSQ510" I should have thought of that.
        again
        • retiredcaps
          • Apr 2010
          • 9271
          Datasheet is at
          That pin looks like the Drain from figure 3. The description says high voltage power SenseFET drain connection.
          • kolpro
            • Jan 2012
            • 17
            Yep I just check that datasheet as well does this give you a flag as to maybe why it blew and maybe if I should be checking something else as well?
            • kolpro
              • Jan 2012
              • 17
              Thanks much I just ordered the part from Mouser Electronics and once the part comes in I'll post the results. I went ahead and ordered 2 just for the heck of it only cost me $11 bucks with shipping.
              • retiredcaps
                • Apr 2010
                • 9271
                I would check the following for potential shorted components:
                - bridge rectifier
                - power mosfet
                - all diodes in and around U101
                - R104 - see if it matches its color band
                Good call on ordering 2.
                  If it's the drain it's tied directly to the internal fet, so it's likely the fet died in a spectacular fashion. Causes include a power surge, high temperature, peaking drain voltage (exceeding 700V is okay once or twice... but not too many times) or a chip that was just on it's last legs (e.g. from being operated near it's limits continuously, like in a current limit mode.)
                  I would expect the mains fuse to blow; check that (including the plug fuse.)
                  • kolpro
                    • Jan 2012
                    • 17
                    - bridge rectifier
                    - power mosfet
                    Do I need to check these components out of the circuit or can I check them in place for the short?
                    • bbjunkie
                      • Dec 2011
                      • 301
                      Check in circuit, if any shorts show up then remove and re-test to confirm.
                      • kolpro
                        • Jan 2012
                        • 17
                        Ok I tested for shorts and here are the results so far.
                        D101--.554
                        D102---.558
                        D107--.458
                        D111---.460
                        D301--.193
                        D510--.458
                        D501--.457
                        D203--.164
                        If I test the in opposite direction I get 0 for all D***
                        R104 -- 196k ohms
                        tested the Bridge and no shorts it tested good
                        Please let me know if I'm missing something.
                        • retiredcaps
                          • Apr 2010
                          • 9271
                          Power mosfet? It usually is a 3 pin IC that is mounted on a heatsink. Measure the resistance between pins 1-2, 1-3, and 2-3.
                          • PlainBill
                            • Feb 2009
                            • 7034
                            There isn't one. It's been integrated into the FSQ510.
                            PlainBill
                            • retiredcaps
                              • Apr 2010
                              • 9271
                              Ahh, yes, now I remember. Too many balls in the air today.
                              • kolpro
                                • Jan 2012
                                • 17
                                Ok I installed the FSQ510 chip and still no power to the TV........
                                  master hoarder
                                  • May 2008
                                  • 12175
                                  • Bulgaria
                                  With the FSQ510 chip installed in the circuit, measure the voltage on pin 3 (Vfb), pin 5 (Vcc), and pin 8 (Vstr). Post what voltages you get. Use pin 1 and 2 (GND) as ground or use hot ground (the "-" of the bridge rectifier on the primary).
                                  Try to perform the test fairly quickly (i.e. don't apply power to the TV for too long). This is to prevent anything else from going bad.
                                  • kolpro
                                    • Jan 2012
                                    • 17
                                    Here are the readouts.....I used pin 1 as ground
                                    pin 8 -------147 volts
                                    pin 5 ------- 0 volts
                                    pin 3 ------- 0 volts
                                    Thanks again!
                                    I was trying to find a schematic of this board but can not.
                                      master hoarder
                                      • May 2008
                                      • 12175
                                      • Bulgaria
                                      Interesting...
                                      Pin 5 (Vcc) needs to be at least 8.7V in order for the FSQ510 to start and continue to be no less than 6.7V for the FSQ510 to keep operating. Should there be a fault, data sheet says the voltage will fluctuate between 6.7V and 8.7V. The fact that it's not suggests that perhaps Vcc is being pulled low by a shorted component.
                                      The voltage on Pin 3 (Vfb) should also be close to 2.8V when the PSU is operating normally and 4.7V when in overload protection. Getting zero for this one likely means the PSU is not even trying to start.
                                      If possible, post a few more pictures of the PSU - one capturing the underside of the whole board and 1 of the topside again capturing the whole board. The FSQ510 data sheet has a sample circuit on page 2. It looks pretty simple. I think we should be able to figure out the circuit in your PSU without a schematic pretty easily. Just need good pictures.
                                      • kolpro
                                        • Jan 2012
                                        • 17
                                        Thanks again I just posted multiple pics to make sure that you can see them good.
                                        • acedogblast
                                          by acedogblast
                                          11-02-2024, 05:13 PM
                                        • DynaxSC
                                          ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
                                          by DynaxSC
                                          Hi
                                          I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
                                          08-04-2025, 12:20 PM
                                        • Troystain
                                          Help EZP2023+ updated chip database for w25q256jveq?
                                          by Troystain
                                          Hello, anyone here have updated ezp2023+ chip database in .dat file format.
                                          I need to add w25q256jveq chip but I do not know what data should I type.
                                          I'm using the ezp chip dabase editor posted from here https://www.badcaps.net/forum/troubl...ro-programmers
                                          The currenty unit model that I am trying to detect is HP elitebook 640 g9 which is currently locked on admin bios....
                                          11-25-2024, 12:53 AM
                                        • inck243
                                          Acer e15-e5-576g-5762 bricked. Bios chip won't interface in AsProgrammer.
                                          by inck243
                                          Thanks for any help. The board version is DAZAARMB6E0 REV: E. The bios chip is winbond 25Q64JVSIQ1736. W25Q64JV is not available in AsProgrammer -- only BV CV FV or FW_1.8c. The chip won't interface with asProgrammer and a CH341A. When I have this chip on the board, the laptop will not post but when I plug it in to power, the blue LED lights up, also the orange when the battery is connected. When I push the power on button, keyboard backlight turns on and the fan starts briefely then turns off. But I can't do anything to program this bios chip so I bought another one.
                                          The BIOS...
                                          07-25-2024, 09:17 AM
                                        • thxd43
                                          Lenovo laptop does not turn on, what does this number mean in a BIOS chip?
                                          by thxd43
                                          Hello, first of all, excuse me, I am using the translator, English is not my native language.
                                          I have a Lenovo ideapad 330S - 14IKB laptop.
                                          The tablet did not recognize me when I connected it, so I checked the device manager and I realized that there were many with the exclamation mark, so one by one I began to update their drivers until the sign disappeared of admiration, I even updated the BIOS, and the laptop rebooted normally and worked, so far so good, but the tablet still did not recognize me, I read on the internet that it could be due to a...
                                          02-23-2023, 08:37 PM
