Philips 47PFL5704D F7 No Power
    Re: Philips 47PFL5704D F7 No Power
    The voltage on pin 5 leads me to suspect the diode on the tertiary winding or the Vcc cap is shorted. As momaka said, this is a VERY simple circuit.
    PlainBill
      Could also be an open resistor in the charging circuit.
        Resistor R104 was showing 194k ohms before I replaced the chip now it shows about 33. k ohms with the new chip in.
        R104 -- 196k ohms
        All the above testing was done in circuit as well.
          I don't think so. 'resistor in the charging circuit' is ambiguous, there are two possible meanings. There is a high value resistor from the filtered mains voltage to pin 8. Given the reading at pin 8, that resistor is good. While it is not shown in the app note, there often is a series resistor in the tertiary winding - diode - Vcc cap circuit. If that resistor were open, the smps would start, then die as Vcc dropped below the threshold.
          PlainBill
            Question....can I test the caps and diodes for shorts while in the circuit or should I just pull them out and test them?
              You can test them in the circuit. If you get ambiguous results (a diode that shows 1K in both directions), it should be removed and tested. If you get a low resistance (less than 200 ohms) across a cap, SOMETHING is shorted and causing problems.
              PlainBill
                Check D107 and C121 out of circuit.
                D107 should show a reading only in the forward direction under diode test (i.e. red probe on anode and black probe on cathode (cathode is the side marked with a white stripe)).
                C121 should go open-circuit after holding the probes on it for a second or two.
                If those components are fine, measure the resistance between pin 5 (Vcc) and pins 1/2 (hot GND).
                  D107 is showing .452 and 0L in reverse
                  C121 has a reading for about 1 or 2 seconds then go to 0
                  The resistance between pin 5 and 1 is 15.5k
                  I blew the fuse (6.3ah 250vp) when I hooked it back up today to test for voltage I'm wondering if I can get one from radio shack?
                  Should I put these components back in?
                    D107 is showing .452 and 0 in reverse
                    Is that 0 or 0L on your multimeter? It makes a big difference.
                    --- begin sig file ---
                    --- end sig file ---
                      Sorry it goes to .0L on the meter when I test it with the diode tester on my fluke....did I test it correctly?
                        Yes, but lately a lot of people haven't been reporting what they see on their multimeter because they don't know how to interpret it.
                        a) 0L on an autorange multimeter means open loop or infinitiy or out of range.
                        b) 0.0 is a unit of measure.
                        c) On manual range meters, "1" on the left hand side means the same as 0L.
                        d) Some people report "no reading" when they see "1" on the left hand side. This is easily the #1 mistake.
                        e) Some people report the quantity, but not what they are measuring (volts, ohms, etc).
                        f) Some people report 1.00 ohm, but it is really 1K ohm, because they forget their dial is set on 2K.
                        PS. Your diode is good. If you had reported 0 (zero), then it would be bad.
                          I have an auto range meter and now I see what your saying...thanks for the tip.
                          So both seem to be good I assume....
                            on my fluke
                            Does you Fluke measure capacitance? If yes, measure C121 and see if it matches the sleeve value.
                              This one is s Fluke 75 series 2 Multimeter as no cap tester function on it. I tested the cap with the diode tester function and got those results are they good results?
                                Inconclusive. For example, a 1000uF cap might only be 680uF, but test "good" on a resistance test.
