Samsung 223BW monitor
  • Herve
    • Feb 2011
    • 7
    Hi guys,
    My 3 years old 22' Samsung gives me some trouble, for the last 2 months at least it had some trouble to display an image when the PC starts. I had to push the button on/off from twice to at least 10 times, with the screen flickering and turning black.
    I suspected some capacitor problem so i opened the beast and took a few pictures of hte power board
    First pic is a general view of the board, there is some white stuff from cap on left and right side of the board
    2nd pic : a closer look at the left side caps
    3rd and 4th pics are 2 view of the caps on the right
    and the last pic is the cap at teh back of the board
    Im not sure if the white stuff around the caps is normal or if they just exploded
    Any help would be appreciated
    Re: Samsung 223BW monitor
    The symptoms you describe match bad capacitors.
    The black gunk and slightly bulged vents is a blantant sign of bad capacitors; CapXon capacitors are widely known as CrapXon around here and are well known to fail. These should be replaced. It would also be advisable to replace the other capacitors at the same time, as you don't want to open your monitor in a few months to replace the rest. You should use low-ESR capacitors, like Panasonic FC, FM or FR.
    • retiredcaps
      • Apr 2010
      • 9271
      --- standard answer ---
      Capacitors (C designation on the PCB board) die from age, heat, and shoddy build quality. Capacitors DO NOT have to be visibly bloated in order to bad. They can be out of tolerance uF (a 1000uF measures 20uF) and/or have high ESR (ohm). A multimeter will be insufficient to test for ESR. For that you need an ESR tester which costs between $50 and $300.
      Most members here will recommend that you replace ALL capacitors with reputable brands from reputable sellers. Brands like Rubycon, Panasonic, Nichicon and United Chemicon are suggested. A list of recommended caps can be found at
      https://www.badcaps.net/forum/showthread.php?t=2280
      The one exception might be the largest capacitor on the power board which rarely, but not never, fails.
      Here is an example of how to choose capacitors with respect to capacitance, voltage, diameter, height, ripple and ESR.
      https://www.badcaps.net/forum/showpo...4&postcount=19
      --- end standard answer ---
      --- begin sig file ---
      --- end sig file ---
      • retiredcaps
        • Apr 2010
        • 9271
        PS. That white stuff is glue from the factory manufacturing process designed to hold the component in place while it is being soldered or assembled. Over time with age and heat, it can turn brown and become conductive.
        For now, the white glue is okay.
        • Herve
          • Feb 2011
          • 7
          Thx a lot for your fast and instructive responses guys,
          much appreciated !
          • m1ch43lzm
            by m1ch43lzm
            05-12-2025, 08:37 PM
          • ohren
            by ohren
            09-08-2023, 05:24 PM
          • C152Heavy
            by C152Heavy
            Summary for TL-DR readers:
            • VCC pin (18) of PFC...
            01-11-2023, 02:53 PM
            09-07-2024, 05:50 AM
