V042L no picture, but sound, bad MOSFET?
  • djsmith
    Solder Fumes
    • Jan 2012
    • 13
    I have a Vizio V042L. It's about 4 years old, and I had one inverter board replaced by a local repair shop about a year ago when it exhibited the same symptoms as these threads:
    https://www.badcaps.net/forum/showthread.php?t=14667
    https://www.badcaps.net/forum/showthread.php?t=18010
    Now it's happening again: no picture, but all other functions in tact, including audio, but my problem seems different from those other threads (hence the new thread).
    When I plug the set into the wall, the Vizio logo illuminates orange. When I press the power button, the Vizio logo illuminates white, but no picture. I tried the flashlight test, and can't see if there's any picture there at all, but there's definitely no backlight. About 2 seconds after powering on the set, a blue LED illuminates quickly on the master inverter board. After about 1 second, it slowly fades to dark over the course of another second.
    So far, it seems the same as the other threads, right?
    The devil's in the details here. I think my problem is different. Read on for the exciting ending!
    After reading the very helpful information on those threads (and a few others), I began troubleshooting the set.
    Here's what I found:
    GOOD: Power supplies appear okay. 5v standby voltages are good when turned off, and all voltages are good when turned on. No capacitors appear puffed or smoked. The ICs and leads look good on each inverter board, but I graciously defer to the more masterful eyes on this forum to review my photos (attached, hopefully high enough resolution).
    BAD: I measured the resistance across each of the 8 MOSFETs, 4 per inverter board. At least, I believe these are MOSFETs--please correct me if I'm mistaken. They all read 8.5 Kohm, except one MOSFET on the slave inverter board (circled in red), which reads in the 10s of Ohms (seems way too low compared to the other 7).
    So I am suspecting this one MOSFET (circled in red).
    My question to you, oh great masters of Badcaps:
    1. Am I on the right track in diagnosing this problem?
    2. If so, can this MOSFET be replaced?
    3. My inverter boards are marked as Rev 1.2. Should I just buy 1.3 replacements anyway?
    I have soldering experience, and this looks within my ability (the IC looks a lot harder by comparison).
    Thank you in advance for lending your time and expertise.
    Last edited by djsmith; 01-02-2012, 05:28 PM. Reason: Added version of inverter boards
  • retiredcaps
    • Apr 2010
    • 9271
    Re: V042L no picture, but sound, bad MOSFET?
    1) First, thanks for a detailed post and uploading pictures using manage attachments.
    A great change from the "help, it doesn't work" threads where the OP has no pictures, no model number, no punctuation, no grammar, no paragraphs, etc.
    2) Yes, that mosfet is shorted. Desolder and retest out of circuit to verify. If it is not shorted out of circuit, then something on the board is shorted.
    3) Yes it can be replaced. You need a decent solder tip size (chisel or bigger probably).
    4) You may want to order more than 1 in case these mosfets work in "pairs". If one is shorted, the other may be next to go.
    a) If the part number is K4075, that is a 2SK4075 made by NEC.
    b) You can get 2 of them for 99 cents + free shipping on ebay.com. Better yet, get 4 or 6 for that price in case it fails again.
    --- begin sig file ---
    --- end sig file ---
    • djsmith
      Solder Fumes
      • Jan 2012
      • 13
      I attempted to desolder the MOSFET for the purpose of measuring its resistance out of circuit. I'm embarrassed to say that my tools were not up to the task (certainly, my soldering skills couldn't be questioned, right!).
      I used a wide-tip soldering iron, untinned (woops), and by applying a little too much torque to the leads to lift them from the pad while applying heat, I actually *broke* the leads free from the mosfet.
      In doing so, I appear to have damaged the pad and trace where the leads connected. Photo attached. In the photo, you can see that one of the pads is actually gone, exposing a white material below (appears non-conductive).
      Have I bricked this inverter board? Is there something I can measure to determine the extent of my damage?
      There does not appear to be an emoticon to express my disappointment in myself.
      • Scenic
        o.O
        • Sep 2007
        • 2642
        desolder the rest of the MOSFET with lots of solder and the iron at the tab.
        Try to re-tin the pad that looks like it's ripped off. Doesn't actually look like it's ripped off, more like cracked-away dull solder.
        If the center part of the pad is really gone, you could scrape off the protective top layer on the surrounding area with a small flat bladed screwdriver (carefully!) till you see the copper, and tin that, making sure it does make contact to the resistor (?) at the right and the other part of the trace that goes under where the legs would have been.
        It's not pretty, but fixable (except the MOSFET itself)
        • retiredcaps
          • Apr 2010
          • 9271
          IF the 2 inverter boards are symmetrical, you can "ohms" out the various pin connections to make sure you didn't damage anything when you install the new mosfet.
          Maybe?
          Of course, just having a bit of fun. No disprect intended.
          • bbjunkie
            • Dec 2011
            • 301
            To help a user in another thread, can you tell me the values (or colors) of R202 and R206 on the PSU board near the bridge rectifier?
            Thanks!
            Jim
            • djsmith
              Solder Fumes
              • Jan 2012
              • 13
              So what do you think about this mosfet site now that I removed the mosfet?
              I added a little solder to the two pads and the mosfet site itself. I took this photo with my iPhone through my microscope (thought that was pretty cool).
              • djsmith
                Solder Fumes
                • Jan 2012
                • 13
                bbjunkie: here's the photo you requested of R202 and R206 (unrelated to this problem for future readers).
                • retiredcaps
                  • Apr 2010
                  • 9271
                  It looks okay to me, but my soldering skills aren't the greatest.
                  At worst, if you damaged something, you might be able to run jumper wires to the nearest component that is in same circuit path. That was my suggestion for "ohms" out.
                  I had to do that once for a Benq monitor. Not pretty, but it works.
                  • djsmith
                    Solder Fumes
                    • Jan 2012
                    • 13
                    The plot thickens!
                    I received my MOSFET by mail today and soldered it on to the board. When I measured the resistance across the two leads, it measured the same as before (much lower than the others), which concerned me. And sure enough, the TV still exhibits the same symptoms.
                    What could this mean?
                      With the MOSFET removed, did you check the resistance?
                      These MOSFETs are ESD sensitive - handle them carefully. If you touched it too much, it could have shorted. Then again, I've only seen small signal MOSFETs go short circuit; bigger ones are more robust (but not completely immune.)
                      • djsmith
                        Solder Fumes
                        • Jan 2012
                        • 13
                        Before soldering the new MOSFET on to the board, I believe the two pads (where the MOSFET leads connect) actually read low resistance between them. That surprised me, but I am an electronics newb, so I let it go.
                        Would that indicate a problem somewhere else (not the MOSFET)?
                        • caphair
                          • Nov 2011
                          • 1249
                          Sounds like something else is shorted giving a low ohms reading at the MOSFET. I'd trace back from the leads to any corresponding components and test for shorts.
                          • kc8adu
                            • Nov 2003
                            • 8832
                            • U.S.A!
                            the ic bd9897 is bad.it looks to have been replaced before.
                            there is a mod out there to fix the repeat failures.
                            • djsmith
                              Solder Fumes
                              • Jan 2012
                              • 13
                              kc8adu: How can you tell that IC is bad? It looks fine to me.
                              • retiredcaps
                                • Apr 2010
                                • 9271
                                In post #2, point 2, did you verify that the original mosfet was shorted out of circuit?
                                • djsmith
                                  Solder Fumes
                                  • Jan 2012
                                  • 13
                                  No, because I damaged it during removal.
                                  • kc8adu
                                    • Nov 2003
                                    • 8832
                                    • U.S.A!
                                    experience in fixing these.design flaw will cause repeat failure.i will try to find the mod.
                                    • PlainBill
                                      • Feb 2009
                                      • 7034
                                      As a gesture of appreciation, this thread has a link.
                                      PlainBill
                                      • djsmith
                                        Solder Fumes
                                        • Jan 2012
                                        • 13
                                        How can I tell if the IC needs to be replaced? Also, if I do the mod linked above by PlainBill, will I still have to replace the IC?
                                        • Jane
                                          How do you test MOSFET in laptops ?
                                          by Jane
                                          I tried to use this method:
                                          Testing an N-channel MOSFET:
                                          Step 1: Discharge the Gate (turn off the MOSFET)
                                          Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
                                          Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
                                          Step 2: Charge the Gate (turn on the MOSFET)
                                          Now, place the red probe on the Gate (G) and the black probe on the
                                          09-27-2024, 03:31 AM
                                        • Tr0ll
                                          by Tr0ll
                                          Original T-con:
                                          First replacement T-con:
                                          10-07-2023, 07:48 PM
                                        • Nooy
                                          VGA MOSfet permanently shorted and loss of MOSfet pad
                                          by Nooy
                                          Hello everyone, I recently found this badcaps site and super Learn Electronics Repair youtube channel. And I wanted to learn how to troubleshoot power supplies and VGA cards and how to practice soldering, since I already have a properly defective piece of them. I am currently trying to solve two problems:
                                          I have a Gigabyte GV-RX460WF2OC-4GD type card. I managed to find the faulty MOSfet (AON6414A) on it, which I replaced. The card starts up, but after about half a minute, the MOSfet in the same position will be shorted again. Is it possible that the PWM controller driving the MOSfet...
                                          02-14-2024, 02:26 AM
                                        • JJAAMM
                                          by JJAAMM
                                          Problem
                                          07-06-2023, 06:01 AM
                                        • TR103
                                          by TR103
                                          - it keeps rebooting
                                          01-22-2025, 04:12 PM
