Philips 42PFL5432D/37
    Re: Philips 42PFL5432D/37
    1) Okay, on CN902 (power board), there is one red wire and a lot of white. Make red wire pin 1 and number the rest in order. It looks like pins 3 and 4 are 12V.
    2) Again, with the TV working, measure all the DC voltages (multimeter set on 20V DC). For the 24V pins, you will need to set it to 200V DC otherwise you will get a "1" on the left hand side. For the other voltages, set it to 20V DC.
    3) Measure them again when the TV picture goes out.
    Last edited by retiredcaps; 02-12-2012, 12:39 AM. Reason: found schematic for CN902
    --- begin sig file ---
    --- end sig file ---
      1) Okay, I'm off to bed soon, but if the CN902 connector shows a missing 12V when the TV goes off, then the prime suspect is that green Lelon cap still remaining.
      2) I snipped out the schematic that shows the board. C955 is the new Panasonic cap. C934 is the 47uF 25V cap just before the 12V test point.
      3) The little caps like C934 usually never bloat when they are bad or going bad. If this cap is bad, the 12V disappears and so does the voltage on the t-con. That is why I had you confirm VIN=12.00 when TV is working and VIN=0.45 when picture disappears in post #178.
      4) If you don't have a 47uF 25V spare, you can use 47uF 50V instead. If you have to order, get this
      http://search.digikey.com/us/en/prod...2923-ND/762833
      5) So if I'm correct, the t-con is fine under heat and it is C934 that dies under hot conditions. This is opposite of what I originally thought, but once I saw the schematic I think this scenario is more likely given the Lelon cap. It will be proven once you do test #1.
        6) I see another Lelon cap C958 (another 47uF 25V). You might as well replace that as well and whatever else is still an original cap.
        7) If changing these two Lelon cap's doesn't help, there is more to troubleshoot.
          Originally posted by PoteauPets View Post
          Just found this post in my local area. Wondering if this would be fixable or if I could use it for parts to fix mine. What do you guys think? I just sent her a message to see what her bottom dollar is. Here is her actual picture and description.
          ‎42' Phillips Flat Screen w/Ambulight for sale. Also comes with the remote.
          It has a black strip down the side of the screen other than that it works fine. My son uses it to play the 360 & watch movies on. Make me an offer.
          This is sometimes repairable, but sometimes not. It is a fault with the actual LCD screen. Still, it may be good for parts and the repair isn't too difficult. You have to disassemble the LCD panel and apply pressure to one of the faulty ribbons, then find a way of permanently applying that pressure for when it is assembled. Some people have had luck with sticky bumpers. It's a very common problem on some Sony and Samsung sets too, but often affects one half of the screen. It is not always repairable, sometimes the ribbon has gone too far.
            Testing in progress:
            With tv powered off this morning: (just for a starting ref)
            1=0
            2=12.10
            3=0
            4=12.1
            5=.4
            6=0
            7=0
            8=0
            9=0
            10=0
            With tv turned on:
            1=0
            2=12.31
            3=12.3
            4=21.4
            5=21.1
            6=24.4
            7=24.4
            8=24.4
            9=21.6
            10=24.4
            When tv lost picture
            1=0
            2=12.06
            3=12.1
            4=.4
            5=0
            6=0
            7=0
            8=0
            9=0
            10=0
            BTW, I have one 47uf35v cap here. Part # P11232-ND
            I have other caps, but not in the 47.
              1=0
              2=12.10
              3=0
              4=12.1
              5=.4
              6=0
              7=0
              8=0
              9=0
              10=0
              Is this CN902? I count 11 pins on CN902. This is the connector by the green Lelon cap. It has one red and 10 white.
                Yes, that is CN902, if you put one tester on the red, and then the other on each of the white ones, you get 10 tests. At least that is what I come up with, unless I'm doing it wrong.
                  Put your black probe on a ground screw and leave it there. Red is pin 1, the other white are pins 2-11. You should get 11 results.
                    Okay, I am driving from OK to IN, my mother has had a stroke. I will get back on this as soon as I return. Thank you so much for all your help.
                      I recently came across this website after my Philips TV had the same symptoms( same model as well). I am overwhelmed with the content of this post. It has been great reading these posts. From my learnings here I have managed to diagnose my issue and i ordered my caps (should be here Monday). Having zero experience with anything like this, I went to the Radio Shack and bought my soldering supplies. I managed to remove all bad caps and am anxiously awaiting the new ones. Thanks to everyone who contributed to this and I am looking forward to many more posts!
                      Aaron
                        Funny how this TV keeps popping up on the internet with the same problems over and over. I have the exact same one and now I am having the "no picture/no sound" problem. The light on the front stays on and the backlights come on. I've replaced the caps on the PSU, and mainboard. Still nothing.
                        There's not much more I can add to the troubleshooting here that hasn't already been said (10 pages and counting) although I can note one thing...This TV runs extremely hot. Compared to every other LCD that I've come in contact with, this thing blazes.
                        T-con board maybe?
                          I came to that conclusion a while back when caps on the logic board are bloating. Normally the caps on the logic board don't undergo the same stress as those on the power board.
                          T-con board maybe?
                          1) Check the fuse on the t-con. A good fuse should measure less than 1.0 ohms.
                          2) If the fuse is good, see if you get 12V DC voltage.
                          3) Do you have a source hooked up to the TV? If you have no sound, that could be an indication the problem is on the main board.
                            The VCC feeding the T-CON board is fed through a switched transistor (this is very common set up used in the TV and monitor t-con power supply section), so when the TV is off, the CPU will send the command to turn off the backlights inveter, T-con board, tuner section, and anything that does not need power to be on to save power.
                            By the way those three caps on the main board were for the switching power supply and the connector next to it are the connector for the T-CON, large IC is for the Class D audio amp section, you can see the speaker cables (RED and BLACK) on the two connectors close to the IC.
                            When T-CON has no VCC, you can see the screen glow in the dark if you look in the darkened room because the backlights are still on, some time it is hard to see the glow because some LCD has very high contrast so the screen is very dark when the LCD is off.
                            I suspect she is loosing the VCC for the T-CON or the T-CON is dying.
                            http://s807.photobucket.com/albums/y...m/LCD%20panel/
                              If you are refering to PoteauPets, her TV has had multiple problems.
                              1) Obviously bad Capxon caps on the main board.
                              2) The 24V DC disappearing on the inverter boards due to bad Capxon caps (not bloated).
                              3) Overheating causing the picture to disappear. If a fan is pointed at the back of TV, then it works greats.
                              Right now, we are left with the two options you mentioned above.
                              1) There are still some Lelon caps that need replacing on the power board that are part of the 12V rail.
                              2) I did mention the chimney affect back in post #109 and how that might be causing the t-con to fail.
                              https://www.badcaps.net/forum/showpo...&postcount=109
                              I'm sure she (and the regular members here) will welcome any suggestions that you might have.
                                The last symptom I see it being mention is that the backlights and sound stay on but not pictures on the screen, so I would suggest to verify if she is loosing the vcc to the T-CON board or not, if the 12v is still there on the T-CON fuse, then I would use cold spray on the T-CON to see if the pictures will come back on.
                                  This post is real exciting to find out the outcome.
                                    Yes it is!
                                    Who knows, maybe those crappy capxons would have lasted longer if that PSU wasn't kickin' out so much heat. If we do manage to get these tv's fixed, do you think it would be possible to wire in a fan or two? I've got plenty of old PC fans laying around.
                                    Anyway, when I have time this weekend I'm going to have a closer look at all the boards. And since I assumed it was only the Capxons that were bad, I'll probably be looking to replace all of the other caps just to rule those out. Caps are cheap and I could always use the practice with soldering anyway.
                                      I did something like that on a Samsung 40" LCD. Found a switched 12V (actually 13V) output of the PSU, fed that into an adjustable voltage regulator which runs a 80mm fan on the back of the TV, blowing straight down onto the PSU.
                                      Temps have dropped dramatically (from burnt fingers down to handwarm), even though the fan just runs at about 3.5V (starts up on its own at 2.8V + a bit of headroom)
                                      The back of the TV looks a bit ugly / hackjob-ish but hey.. that's not what you're supposed to look at
                                        That's exactly what I was thinking. Like cutting a hole right in the back of the TV and mounting a fan directly over the power supply. Just to try to prevent any further hardware from failing.
                                        I had some time to take a closer look at the T-con board and I see an SMD with what appears to be some slight burning on the PCB beneath it. I can't tell what it is (maybe a diode) there are no identifying marks on it. On the PCB right next to it is "C69".
                                        My camera really sucks, if I can get a decent pic of it I'll post it. Hopefully someone will know what it is.
                                          Okay, I don't think it's a diode. I'm no expert here. And I hope the pics aren't too big. My camera doesn't really have a macro setting, so I did the best I could...
