Will a S42AX-YD01 screen work with a Magnavox 42MF438B/27??
  • Paul678
    • Nov 2011
    • 402
    Someone has asked me about my replacement
    screen.
    Shopjimmy.com has the part numbers of the boards,
    but not the screens. Is there a website that has
    this info, or does this person need to at least take
    the back of the TV off to see?
  • PlainBill
    • Feb 2009
    • 7034
    Re: Will a S42AX-YD01 screen work with a Magnavox 42MF438B/27??
    Elektrotanya probably has the service manual for the TV. Philips (owner of the Magnavox brand name) usually has very retailed parts lists, and I would expect them to include the manufacturer's part number for the plasma panel - they did on other sets.
    PlainBill
    • PlainBill
      • Feb 2009
      • 7034
      One thing that continues to appall me is the lack of resourcefulness on the part of some people (others dazzle me with their ingenuity and persistence).
      Googling 42MF438B/27 I find it is an 1080P LCD TV. The S42AX-YD01 is a 720P Plasma TV. The panels are not interchangeable.
      PlainBill
      • Ryan.man
        by Ryan.man
        02-04-2025, 12:23 PM
      • benek123
        RedmiBook 15 pro 2023 Ryzen - after replace LCD screen work only in windows
        by benek123
        I replaced the screen and LCD ribbon in Redmi Book 15 Pro Ryzen 2023. After replacing, the image on the screen is only visible in Windows 11 - when the AMD drivers are loaded.
        The screen is backlit but there is no image in: bios, post, when loading windows, in linux (ubuntu boot from usb), windows 10 PE.
        When I disconnect the EDP connector from the board and connect the HDMI cable, the image is visible everywhere good, in the BIOS you can see 2/3 of the image, i.e. 1920 pixels out of 3000 pixels.
        I checked the EDID with the old screen - it is identical.
        What...
        09-24-2024, 03:28 PM
      • reformatt
        by reformatt
        07-31-2025, 08:37 PM
      • smic717394
        by smic717394
        07-25-2024, 10:16 AM
      • ronaldopdias
        A3113 corrosion to LAS = No keyboard, yet screen and trackpad work fine
        by ronaldopdias
        Hi All.
        I have a A3113 MacBook Air 13" (M3) that had minor liquid damage. The screen remains on if the lid is closed, the keyboard doesn't work, but trackpad and Touch ID does.​
        The LAS was corroded, but I have tested it on an A2681 (M2) and it functions fine. Anyway, I ordered a new one and replaced it and calibrated it with Apple.
        I have checked the main voltages going to the daughterboard and they are present. Diode mode reading on the LAS line which goes direct to the SoC is also correct, no short.
        So then I replaced the daughterboard, and...
        06-16-2025, 03:12 AM
